Old 08-04-2014, 11:13 PM   #29
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Love my AP Sprint BBK. Takes a pounding on track and asks for more. Pads are cheap and thickest around. No boots to burn up and the calipers are cheap/easy to service
I think you'll be happy with it. The best BBK available for a track application. Talk to @CSG Mike about Sprint vs Endurance kits and see which one you'll want to go with.
Over 400whp may necessitate the Endurance kit if you get lots of track experience and need extra thermal capacity and cooling ducts.
Old 08-04-2014, 11:14 PM   #30
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Thanks Ian.
What pads do you run?
Old 08-04-2014, 11:24 PM   #31
ATL BRZ
ATL BRZ's Avatar
Originally Posted by Reaper View Post
Thanks Ian.
Track: CL RC6 front (came with BBK) and Carbotech XP12 rear
Street: Carbotech Bobcats (1521) front and StopTech Street performance rear
The Following User Says Thank You to ATL BRZ For This Useful Post:
CSG Mike (08-05-2014)
Old 08-04-2014, 11:37 PM   #32
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
This, although I would say 'will' instead of 'may' if you're really using the car on the track.
dradernh is offline   Reply With Quote
Old 08-05-2014, 12:59 AM   #33
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Tapering is a result of caliper flex, which is common on floating piston calipers, but not monoblock calipers. It's impossible for a liquid to distribute force unevenly over a flat surface, like a brake piston.
Imagine prying a caliper apart... that's what happens when you brake hard and the caliper is really hot. That's why the upper/outer edge of the pad wears faster under harsh conditions
interesting, so are you suggesting that 6 pot caliper design has no advantage over the 4 pots ? because all things being equal 6 pot should provide more pressures zones
and the cost advantage on the Wilwoods are huge IMO, $1400 vs $2100 ..it will be a tough decision when the time comes
glamcem is offline   Reply With Quote
Old 08-05-2014, 05:26 AM   #34
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
As an added bonus the Essex Sprint Kit lose 4.5 kg per side over stock. Win!
Old 08-05-2014, 05:54 AM   #35
CSG Mike
CSG Mike's Avatar
More pressure zones does not equate to more pressure area. If the area is increased with the same total brake force coming from the master cylinder, then bias is being changed.
The Wilwood SL6R caliper is virtually identical to the AP Racing 8350.... I wonder why that is.
Old 08-05-2014, 08:06 AM   #36
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
ok so the sprint kit has no boots, which kit has boots and is powdercoated. I mixed them up in my head. I DD my car and those are features I want.
Don't get overly concerned about dust boots. If you generate enough heat on track you'll just melt them anyways (which is why race calipers don't bother with them).
I've used the Sprint kit for about 17,000 miles I think, street and a fair amount of track use. They are perfectly streetable. They will make noise with track pads, but there are some street pads that are pretty quiet and you can get non j-hook rotors which should help the noise also (but I haven't tested it since I don't drive my BRZ anymore).
If you are looking for pretty calipers, well I think gray aluminum is pretty, but the AP formula kits, the stillen kits and the stoptech are all good options.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
ATL BRZ (08-05-2014)
Old 08-05-2014, 08:10 AM   #37
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
But Wilwood calipers do flex more than APs. Talk to some dirt track guys, they can show you some Wilwood tacos...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-05-2014, 08:10 AM   #38
Reaper
Reaper's Avatar
Drives: violent
I think I'm decided on the sprint kit and if the winter looks like its going to be bad ill just put the stock brakes back on. What pads do you run? @Dave-ROR
Old 08-05-2014, 08:10 AM   #39
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by AZFA20 View Post
Another viable option is Baer brakes. The only thing is they are 14" rotors in the front so 17" wheels that would fit are scarce. It would require an 18". Pads are readily available in just about any compound since they are corvette pads. Essex and Stoptech are obviously good choices too but this gives you another option. They utilize 6P (6 piston) front calipers with piston seals and S4 (4 piston) rear calipers also with piston seals. I personal'y run the Baers and have been for 1.5 years now. I have owned several Baer products (mostly BBKs) and have never had a failure. I can tell you the Baers on this platform literally make me sick to my stomach under full brake from 120+ mph coming into a turn from straights.
The fact that they are 14" means that aren't a serious consideration beyond looks. Unless you like slowing your car down... when you aren't using the brakes.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-05-2014, 08:11 AM   #40
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Do you like the RC6 as much as I do?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-05-2014, 08:17 AM   #41
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
More pistons will generally mean better modulation and better pad life if they are differential (more piston area in the direction of travel to prevent tapering in the longitudinal direction). AP 4 pots used in the Essex kit are diff too and I've only noticed very slight tapering.
The rest comes down to piston area to determine how the brakes would feel and what their effect would be at a given line pressure.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-05-2014, 08:19 AM   #42
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Well noise doesn't concern me, I have track pads on every car I own.. soo..
I use Project Mu 999's (from @CSG_Mike) and CL RC6 and RC6E from @JRitt
Actually the RC6 might be on one of the Integras, hard to remember anymore.
For street use I'd look at the blanks instead of J Hook and the street/autocross Carbotechs. They are cheaper than track pads though so get good expensive pads at the $25 rate and buy those separately
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Deciding on LCA's. natesparxxx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 61 08-17-2014 01:33 PM
Need help deciding on Exhaust DannyFRS Engine, Exhaust, Transmission 1 02-23-2014 05:10 PM
Deciding on an exhaust JohnAyySays Engine, Exhaust, Transmission 32 12-28-2013 11:31 PM
What other car did you consider before deciding on the BRZ? txeng86 BRZ First-Gen (2012+) — General Topics 132 10-30-2013 03:49 AM
Deciding between... (help appreciated) rainmonkey Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 08-27-2013 03:53 PM
