Old 03-04-2014, 02:12 PM   #15
Alain
FRSKEE
Alain's Avatar
Drives: 2014 Monogram Series Whiteout
I just replaced the OEM Scion spoiler with a TRD on my Monogram 2 weeks ago. Yes it covers all the holes but you will have to drill 2 new ones as previously said. Just have a lot of time and patience to take off the OEM one because they sure used a lot of double-sided tape. Also if you bought a new TRD spoiler, it comes with some vinyl overlays to stick over the old holes. Enjoy!
Originally Posted by Choob View Post
I believe the TRD you don't bolt anything. Its all double sided tape.
@Choob check above. Real TRD you have to drill two new holes hence the bolts
Alain is offline   Reply With Quote
Old 03-04-2014, 06:34 PM   #16
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
I can confirm this has to be done -- unless you're like me and you completely rip the two bolts out of the spoiler. Heat gun with some vice grips and rip apart -- took about 40 mins to do, then you can just seal the holes and just put the 3m tape on.
I've had mine for about 8 months now -- no problems.
CamryDS is offline   Reply With Quote
Old 03-05-2014, 09:05 PM   #17
FRSHunter
Drives: Asphalt FRS
Got mine from a member here. I believe he got it thru jonmotoring.
Also mine is for sale. Painted Asphalt/Dark Gray.
Is the DGM one still for sale?
FRSHunter is offline   Reply With Quote
Old 03-05-2014, 09:19 PM   #18
Alain
FRSKEE
Alain's Avatar
Yes. Same exact color. I saw your pm. Ill send you the picture thru there
Old 08-04-2014, 07:12 PM   #19
exE36M3
Hey guys - where did you end up buying the OEM/TRD wing? I got the knock-off version Stivo and it won't stay put. Does Toyota sell the TRD wing?
exE36M3 is offline   Reply With Quote
Old 08-04-2014, 07:31 PM   #20
STV3
Señor Member
STV3's Avatar
Got mine from Nigel JDM.
Also I too ripped the two tabs off the TRD wing and have it mounted with just the 3m.
STV3 is offline   Reply With Quote
Old 08-05-2014, 02:43 PM   #21
CrazyWookiee
Drives: Whiteout FR-S
Same. Had mine on for over a year and a half and still super snug.
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
FS: OEM Scion Spoiler Raven N_A Exterior Parts (Aero, Lighting, Etc.) 8 04-14-2014 11:16 PM
Options for replacing the Limited's spoiler Flow Cosmetic Modification (Interior/Exterior/Lighting) 15 02-10-2014 12:12 AM
WTB: OEM Scion or TRD Trunk Spoiler Hope10Series Canada Classifieds 3 10-02-2013 08:19 PM
rear spoiler on scion frs Ravenft86 Cosmetic Modification (Interior/Exterior/Lighting) 20 01-26-2013 09:26 PM
Replacing the Scion FR-S seats bloomy116 Scion FR-S / Toyota 86 GT86 General Forum 36 11-09-2012 12:41 PM
