Old 08-02-2014, 09:57 PM   #29
steve99
Drives: FT86
Originally Posted by Virtual86 View Post
Question, are us guys in OZ better using stage 1 98ROM or 91ROM? a little confused with one of the past post replies.
When the V2xx tune are available for G rom I would load up the 91 (USA MON) roms and see what the knock looks like on out 98 RON fuel. If it looks ok then load up the 93 (USA MON) ROM's and check knock again.
My experience has been that the USA 93 fuel is superior to our 98 RON, I currently use United Petroleum 100 RON fuel all the time.
Old 08-02-2014, 10:01 PM   #30
steve99
Drives: FT86
Originally Posted by Silver Ignition View Post
@steve99 you should also include Recommended and Required mods for each tune
check the "release note" file that comes with the downloaded tune files
Old 08-02-2014, 11:49 PM   #31
s2d4
s2d4's Avatar
Most likely due to ethanol content.
Old 08-02-2014, 11:51 PM   #32
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
of course but it should be in the FAQ as well
EDIT: just saw it…first post is growing, I LOVE it!
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
The Following User Says Thank You to Silver Ignition For This Useful Post:
steve99 (08-03-2014)
Old 08-03-2014, 03:01 PM   #33
Foobar
SLO NO MO
Foobar's Avatar
Figured this is as good a place to ask as anyway - Does OFT offer a package with a Vortech Super Charger tune? I checked their site and I only see a package bundled with the Super Charger and their Header, and their OTS library doesn't show anything for forced induction.
For those of us who already have Vortech with ECUTek - is there an available option to buy the OFT and get a Vortech tune for it?
Old 08-03-2014, 03:47 PM   #34
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
PM or emailing Shiv is probably your best bet.
Old 08-03-2014, 03:49 PM   #35
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
yes, we do offer a Vortech-based package with the OFT (OFT300). We will also offering a SBD Turbo-based package with the OFT as well (yet to be advertised on the website). So that may be worth looking at since it offers the same power level, with less boost and more low-end/midrange torque. Feel fee to email sales@vishnutuning.com for more info
Shiv@Openflash is offline   Reply With Quote
Old 08-03-2014, 04:04 PM   #36
Foobar
SLO NO MO
Foobar's Avatar
Thanks - tried that, he must be blocking me or something
Thanks Shiv - Sorry for the confusion, I actually already have a Vortech, but I'm interested in what options I have as far as buying an OFT and getting a Vortech tune for it to replace my ECUTek setup. Is that something you sell - just the tablet and a Vortech tune to go with it?
Old 08-04-2014, 02:58 PM   #37
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Cool
Originally Posted by HercMax View Post
Thanks guys. If even the missus notices a big difference then that's as good as an endorsement as any. Looks like I'll wait for the V2.0 OFT to be released for international markets and take the plunge. Never noticed knock on stock tune or maybe my ears aren't sensitive enough.
When is V2 OFT set to be released? I am on the fence about purchasing this and would like to get the latest release...
Chad86 is offline   Reply With Quote
Old 08-04-2014, 03:13 PM   #38
Shiv@Openflash
Drives: 2013 FRS
Sorry mate, email is definitely the best way to reach us (sales@vishnutuning.com). I'm hopelessly behind on PMs.
If you already have a Vortech kit, you can certainly purchase an OFT and use our OTS OFT300 map. Just as long as you are using the 2.5 bar maps sensor (provided by Vortech) and stock injectors, our OTS map should serve you well
Old 08-04-2014, 03:14 PM   #39
Shiv@Openflash
Drives: 2013 FRS
Our v2.0 maps have already been released and support USDM (and Canadian) cars
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Chad86 (09-12-2014)
Old 08-06-2014, 12:08 AM   #40
username_taken
Drives: Subaru BRZ Limited
might be worth a few notes in here on enabling/using Launch Control and FFS... that other thread isn't obvious on exactly what is supported OOTB and what needs modifying.
username_taken is offline   Reply With Quote
The Following 2 Users Say Thank You to username_taken For This Useful Post:
JB86'd (08-06-2014), ThisGuyRett (10-08-2016)
Old 08-06-2014, 09:17 AM   #41
steve99
Drives: FT86
added the following spiel to original post
Launch Control -LC
Basically a second RPM limiter that is active when the vehicle speed is below the threshold speed set regardless of clutch in/out.
Launch control Disable speed = speed at which Launch RPM is disabled (ie you revert to normal red-line RPM limit 7600) default = 6mph (aprox 10KmH)
Launch Control RPM Delta = Amount to subtract from your Red-line RPM to get you Launch RPM e.g. if LC RPM Delta = 3600 your Launch RPM will be 7600-3600 = 4000 RPM
To disable Launch Control set LC RPM Delta = 0
Flat Foot (no lift) Shift -FFS
Is Another RPM limit activated when the Clutch is depressed (it does not monitor that the throttle is flat or 100%) for this reason it can activate on downshift.
Flat Foot Shift RPM Delta = Amount to subtract from your Normal Red-line RPM to get FFS RPM limit eg if you set FFS Delta = 2000 your FFS RPM limit will be 7600-2000= 5600 RPM so when up-shifting with foot on accelerator RPM will be limited to 5600 RPM as soon as you depress clutch even though your foot is on accelerator. Note its does not need the accelerator/throttle to be 100% or flat to activate its activated of Clutch switch only. This can sometimes cause issues on downshifts if you set the RPM to low for Flat foot shift.
Old 08-06-2014, 09:37 AM   #42
Kodename47
Kodename47's Avatar
Drives: UK GT86
7600-2000= 5000
Really?? :p
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
Mooseknuckle44 (08-06-2014), steve99 (08-06-2014)
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
