Old 08-01-2014, 07:43 PM   #9115
chas3wba0
chas3wba0's Avatar
Drives: Yes
Originally Posted by MstrSHAKE View Post
Installed my Invidia Test Pipe and nameless axleback yesterday. (Yes, i'm late to the parade)
Anjunabeats
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
The Following User Says Thank You to chas3wba0 For This Useful Post:
MstrSHAKE (08-01-2014)
Old 08-01-2014, 08:05 PM   #9116
kberkel
kberkel's Avatar
Plugged the sound tube today. Sounds so much better in the high RPMs
It always sounded simulated, and made a weird noise when I let off the gas to shift.
kberkel is offline   Reply With Quote
Old 08-01-2014, 08:21 PM   #9117
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
How exactly does it affect the sound of the motor?
B-R-Z is offline   Reply With Quote
Old 08-01-2014, 08:24 PM   #9118
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
Installed my Tom's today. love em!
shaynek is offline   Reply With Quote
The Following User Says Thank You to shaynek For This Useful Post:
WuTangWindu (08-03-2014)
Old 08-01-2014, 08:33 PM   #9119
kberkel
kberkel's Avatar
down low sounds almost the same to me.
Around 3-6k RPM it was kind of "derrrrrrrrrrrr!" (rolling r) and now it's like.. "rooooooooooom!" That's the best way I can describe it
And when I used to shift.. as soon as I would push in the clutch it would make some weird OHM noise unless I backed off the throttle before pushing the clutch in.. like "rrrrrrrrrrrrOHM!" But now that's pretty much gone.
Definitely quieter, I want real exhaust now.
Old 08-01-2014, 08:47 PM   #9120
B-R-Z
B-R-Z's Avatar
Why is everyone trying to reduce the nice engine noise
Old 08-01-2014, 08:57 PM   #9121
kberkel
kberkel's Avatar
I would love an axleback I never heard the weird sound coming from the right side, so I didn't think the soundtube would do much, but it did.
Old 08-01-2014, 09:10 PM   #9122
uEih
Drives: CBS Subaru BRZ Limited
Reducing that sound tube was probably the best thing I've done, it's more of an engine sound instead of some generic sound. From what i remembered without the sound tube plugged it made it sound like you're going really fast when you're not.
uEih is offline   Reply With Quote
Old 08-01-2014, 09:42 PM   #9123
Mr.
Supra Senior Member
Mr.'s Avatar
Drives: AE86 & BRZ
made my hood open higher. [ame="https://www.youtube.com/watch?v=sd6Yxue40iY"]How to make your hood higher BRZ FRS GT86 No need hood struts - YouTube[/ame]
Build Thread
YouTube Channel
IG - Fwankyhong
Subscribe
Mr. is offline   Reply With Quote
Old 08-01-2014, 10:00 PM   #9124
kberkel
kberkel's Avatar
It's weird, since when I did aftermarket exhaust on my last car, it added almost no horsepower, but it made it feel like I was faster with the sound. I loved it.
But somehow the sound tube just felt unnatural I guess. Like on the highway, you expect wind noise to drown it out, but it was just as loud. Then when you get in a tunnel and rev it up, it's silent. Like
Old 08-01-2014, 11:31 PM   #9125
uEih
The thing with the exhaust is it gives a rumble/vibrations that actually changes the feel. That sound tube does nothing but gives that sound.
Old 08-02-2014, 12:25 AM   #9126
DG-86
DG-86's Avatar
Drives: 17' WRB BRZ Limited P.P. 6MT
Finally installed my JPM Coachworks Alcantara Kneepads and Perrin Shorty Antenna. Name:  ImageUploadedByTapatalk1406953484.058272.jpg
Size:  295.0 KBName:  ImageUploadedByTapatalk1406953507.039066.jpg
DG-86 is offline   Reply With Quote
Old 08-02-2014, 03:37 PM   #9127
wrb
frank
wrb's Avatar
Drives: Subaru BRZ WRB
changed out fog lights to LED.
now the colors match!
took less than 15 min. from going down to the garage, getting stuff ready, and to install.
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA
Build Photo Album - http://bit.ly/brz_wrb
SoCal LA 86 Club Member
wrb is offline   Reply With Quote
Old 08-02-2014, 04:27 PM   #9128
B-R-Z
B-R-Z's Avatar
Installed Tsudo UEL header. It sounds amazing with no rasp at all. I do hear the flow of air at some rpms that others have reported. I might get a wrap for the header, I heard it helps.
Exhaust system consists of Tsudo UEL header and Top Speed Pro-1 axle-back, everything else is stock.
I tried taking videos but the sound was way off, it came out better using the sound recorder on my phone.
Stock header: https://dl.dropboxusercontent.com/u/...tockHeader.mp3
UEL Header: https://dl.dropboxusercontent.com/u/...Z/TsudoUEL.mp3
The Following User Says Thank You to B-R-Z For This Useful Post:
GGVF (08-02-2014)
