Old 07-29-2014, 09:39 AM   #393
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by blackfireball5 View Post
I have a custom setup. It's a 19 row Mishimoto cooler. How thick is your cooler? Mine is fairly thick and the inlet nozzle is almost touching the turn signal bulb connector, and the back is just about flush with the fender liner, maybe even pushing it out a little. Maybe i'll see if I can mount it a little better one of these days.
I have a custom setup too with a B&M core. Also sits in the FBM location and almost touches the BRZ fog light but the fender liner on the back is not pushed out.
Old 07-29-2014, 12:01 PM   #394
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I have the FBM cooler which is also 19 row.
The bracket that it comes with mounts it so that it doesn't touch the fender liner or fog light, but just barely. I've ordered some fog light delete housings to get rid of the fogs and maybe hollow the passenger side out to allow direct air flow.
I also found this:
Unfortunately, the 19 row is dual inlet. If there's enough room with the fog light gone, I may get it
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 08-01-2014, 02:30 AM   #395
toekneehair
toekneehair's Avatar
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
Originally Posted by protpibe View Post
I just ordered some fog light delete bezels for my BRZ. The plan is to modify the passenger side one to allow air flow.
Part numbers:
57731ca260 and 57731ca250
This is exactly what I did and then I took a dremel and removed the plastic behind it to open up the air flow. worked great and very stock looking you would never know it was modified to allow air flow. I actually did both sides to keep it consistent. If I remember to I'll try to take photos and post them
toekneehair is offline   Reply With Quote
Old 08-01-2014, 02:34 AM   #396
toekneehair
Originally Posted by sw20kosh View Post
What were your oil temps on the hill climb?
I never made it up the hill unfortunately so I am not sure. I haven't had time to run it crazy and I put FBM oil pan on but I didn't tighten the bracket enough so I have a small leak so I am watching how I drive it until I can fix it.
Old 08-01-2014, 10:52 AM   #397
protpibe
protpibe's Avatar
Awesome, I would love to see some photos when you get a chance. My plan was to cut out the backing and put in some mesh behind it
I'm also thinking of adding a fan to one side of the oil cooler and wire it to my fog lights so that I can turn it on with the switch inside when in traffic. I need to find the amperage rating of the fog light vs what a small fan would be, but I don't think I would have to use a different relay.
The Following User Says Thank You to protpibe For This Useful Post:
BRZPDX (08-01-2014)
Old 08-01-2014, 12:01 PM   #398
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Has anyone tried just removing the weather strip under the back of the hood? This gives a 1/2 inch gap to maybe let heat escape.
Lunatic is offline   Reply With Quote
Old 08-01-2014, 12:04 PM   #399
protpibe
protpibe's Avatar
I don't know if that would do anything unless there's a low pressure area behind it to pull the hot air out.
Old 08-01-2014, 01:23 PM   #400
BadBRZ
Drives: Subaru
There is a low pressure are at the base of the window...
BadBRZ is offline   Reply With Quote
The Following User Says Thank You to BadBRZ For This Useful Post:
Reaper (08-01-2014)
Old 08-01-2014, 03:40 PM   #401
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I've posted this multiple times in multiple threads. Yes it works. There is also two small flaps on the sides you can remove. For more venting remove the piece by the battery but your interior will smell like an engine bay.
The Following User Says Thank You to Reaper For This Useful Post:
Darryljr11 (08-02-2014)
Old 08-01-2014, 03:46 PM   #402
sw20kosh
Drives: 2013 Black FR-S
@mkivsoopra said a 3" hole at 60 mph speeds will flow 1000 cfm. A small fan on the cooler will flow 300-400 cfm.
Old 08-01-2014, 03:56 PM   #403
protpibe
protpibe's Avatar
That's good info, thanks.
The only time I see abnormally high oil temps is in city traffic on a really hot day. I'll take 300-400cfm over 0cfm any day.
The FBM oil cooler is 19 row so I'm thinking put a fan on one side then leave the other to have direct flow from the fog light opening at speed.
Old 08-01-2014, 04:33 PM   #404
CSG Mike
CSG Mike's Avatar
Please don't do that. It's a high pressure zone, and you will *suck in* air through that gap, resulting in less air going through the radiator.
This is precisely why the AC air intake is located there, and why muscle cars have hood cowls for induction.
Old 08-01-2014, 05:10 PM   #405
AJPG
Drives: 22RE, FA20, 4G63
Hi
2 mocal oil coolers of 16 rows each and mount in the front, highest temp ever recorded was 215f and it drop really fast if you stop (trafic) normal DD temp 190-200f. Need to mention that use 7.5qts of oil.
Coolant 195-205f with the koyo rad and heavy use; yes FI.
AFR 14.5 at idle and 12.0-12.5 at WOT.
Ambient temp 75-95f.
AJPG is offline   Reply With Quote
Old 08-01-2014, 05:18 PM   #406
protpibe
protpibe's Avatar
Originally Posted by AJPG View Post
Hi
Have you run it on a track?
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
