| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#99 |
Drives: 2004 Subaru Forester 2.5XT
Mike - I'm surprised the viscosity for this oil took such a hit since 300V is such a robust oil. Is this before you added the oil cooler? TBN was high so the oil had plenty of life left in it.
It should be the newest formulation as that came out at the end of 2012 (Ester Core). -Dennis Last edited by bluesubie; 08-01-2014 at 11:00 AM. |
#100 | |
We will report back after the next oil change which will have 70/30 split using no cooler and the 2015 DIT cooler. Mike |
#101 |
Drives: Stock
Really depends on how often you want to overhaul... assuming ethter / pao or paraffin oils with right additives (my understanding is that it really is the additives if you have constant operating environment)...;
1) 0W-16 if you can overhaul anytime 2) 40 grade, if you intend to run for couple of years, maybe like 10,000km/year, with intervals (i.e. HPDE or multiple race weekends / tests) 3) 60 grade, if you are doing 24hr endurance I've used 0W-40 Mobil1, run 95℃ - 105℃, changed every weekend of racing / tests, and run 12,000km this year on track. I expect to overhaul next year, based on how other cars failed with similar use profile. Expensive hobby indeed. |
| "Come Race Me Bro" Encounters | GH05T | FR-S / BRZ vs.... | 2565 | 02-28-2023 09:34 AM |
| New 4-2-1 Long Tube Header | Anorexic 86 | Engine, Exhaust, Transmission | 28 | 08-25-2013 03:28 PM |
| WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset | GC GTS Aero Kit | Australia Classifieds | 16 | 03-22-2013 05:49 AM |
| Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
| Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
