| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#30 |
Drives: 2015 Subaru WRX
215/50-16 be odd rather than 205/55-16 ?
#31 |
Drives: s2000
I think sticking to 17s would be best for this car. The car doesn't command a ton of HP/TQ so if you're looking for performance only, going wider and lower profile is the way to go. 245/40/17 on 17x9 is what I'm looking to do.
#32 |
Drives: BRZ(sold), STI
Useful thread on tires should not require people to download some pdf. And should have a lot more info. Here's a good example, that's also relevant since base LGT has the same tire size (different stock offset on wheels though)
#33 |
First86 / boat thief
Drives: MKIV Supra
#34 | |
Drives: MKIV Supra
#35 | |
Drives: MKIV Supra
The main point was to help educate people so they don’t put way to big a tire on and then wander why their car was so slow. |
#36 | |
Drives: MKIV Supra
#37 | |
Drives: 2006 Scion tC RS 2.0
Brake. Turn. Accelerate. Repeat as necessary.
#38 | |
Default User Title
#39 |
Drives: Nissan Versa
Useful tool for compairing tire size from 1010tires.com. It gives you % difference in diameter among other things. Attached a screenie of potential winter tires for 16" wheels.
http://www.1010tires.com/TireSizeCalculator.asp Oh and hello from a noob ^^ Edit: whoops just realized OP's source for the pdf is the same site/shop... and forgot the link :p |
#40 |
Drives: 2017 Subaru BRZ PP
Hi Noob! Cute cat!
I'm going to put Bugatti Veyron size tires on there. Should give me at least 50 more horsepower. But seriously, as I recently said in another post, I wish it came with 225/45/17 tires and 17x7.5 wheels. They'd give you enough space for Brembo calipers and a little more tire for stability and a little more sidewall for comfort and grip. However, I am against increasing the stock diameters unless it were a matter of 1-4 mm. So I'll keep it stock size and keep the stock calipers but replace the tires with Michelin Pilot Super Sports and possibly replace the wheels with the BBS RF in the same size/offset. |
#41 | |
Drives: MKIV Supra
#42 |
Frickin' Genius
Drives: GBS BRZ 6sp, 2002 ts wagon WRX swap
225/50/16 all around is what I'll be doing for a track tire (RA-1 or NT-01 most likely)
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 09:11 AM |
| Toyota 86 first drive review (Car Guide) | a6ela | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 03-14-2012 12:34 PM |
| Feature Guide | slizoth | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 01-19-2012 08:32 PM |
| Consumer Guide, 2012 Celica, 6/29/11 | 1660 | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 08-08-2011 07:55 AM |
