Old 07-31-2014, 12:11 AM   #1849
Jcl
Drives: 2014 BRZ
Anyone have problems with the car not holding idle after kws map?
Jcl is offline   Reply With Quote
Old 07-31-2014, 01:19 AM   #1850
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Did you change the map sensor to the KW map sensor and not the denso one that originally came with kit?
mit_peid is offline   Reply With Quote
Old 07-31-2014, 05:20 AM   #1851
zERoTu
Drives: 1st RBv2 10 Series FRS
I have same problem too. And there is a kw map sensor? I got the denso one.
zERoTu is offline   Reply With Quote
Old 07-31-2014, 09:38 AM   #1852
Jcl
Drives: 2014 BRZ
This is what came with.
Old 07-31-2014, 01:30 PM   #1853
captain_jack
captain_jack's Avatar
That's the one included in the kit, it doesn't look like mine but I have an earlier kit. The newer kits have that one. I'd call them if it were me.
Old 07-31-2014, 08:21 PM   #1854
Jcl
Drives: 2014 BRZ
Thanks to Joe @KraftWerks I am up and running. Looks like the map sensor they sent was a 2.5bar vs their regular ones.
The Following User Says Thank You to Jcl For This Useful Post:
Freeman (07-31-2014)
Old 07-31-2014, 08:50 PM   #1855
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Glad we could help!
KraftWerks is offline   Reply With Quote
Old 07-31-2014, 10:48 PM   #1856
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Anyone have pics of the oil cooler kit installed? Thanks...
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 07-31-2014, 11:00 PM   #1857
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Kraftwerks Supercharger Owners Thread
Size:  249.7 KBName:  ImageUploadedByTapatalk1406861994.210667.jpg
That's all I got for now
If you need me to snap some more I can try
Also the instructions don't mention it, but clamp the ends of the lines. Otherwise lines will pop off....
Freeman is offline   Reply With Quote
The Following User Says Thank You to Freeman For This Useful Post:
zoth (08-01-2014)
Old 08-01-2014, 12:47 PM   #1858
KraftWerks
KraftWerks's Avatar
Originally Posted by Freeman View Post
Attachment 86727Attachment 86728
@Freeman - The line and fittings are rated to up to 250psi without a clamp. You should not have any issues with these while running without clamps.
Old 08-01-2014, 01:09 PM   #1859
Freeman
Freeman's Avatar
And according to the instructions the lines and fittings are supposed to come pre-assembled. Mine weren't so I assembled myself. I should have put hose clamps on them, rookie mistake. Then this happened....
Attachment 86803Attachment 86804Attachment 86805Attachment 86806
... So I say again, good idea to put hose clamps on.
Old 08-01-2014, 06:18 PM   #1860
Calum
That Guy
Drives: 2013 asphalt FRS MT
The link is broken.
Old 08-01-2014, 08:05 PM   #1861
CSG Mike
CSG Mike's Avatar
Key words.. "up to". Not "at least".
Old 08-01-2014, 08:31 PM   #1862
KraftWerks
KraftWerks's Avatar
We're not quite sure what your motor is referencing but the average pressure on one of these motors at operating temperature would be something like 80-105psi at a maximum? This would not come close to even an 'up to' rating.
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
