Old 07-31-2014, 04:07 PM   #15
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
The code goes away after two starts of the car and then it will come back. no idea why
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 07-31-2014, 05:40 PM   #16
SilverFoxBRZ
BRZ Jockey
Drives: 2013 BRZ LTD 6MT Sterling Silver
Are you back on 93 octane?
SilverFoxBRZ is offline   Reply With Quote
Old 07-31-2014, 05:56 PM   #17
feldy
feldy's Avatar
Been back on 93 ever since I got those codes last fall. Never had the code again.
Old 07-31-2014, 09:42 PM   #18
Carban
Grease Monkey
Carban's Avatar
Drives: Whiteout FR-S
CEL back on today for the same code. Checked gas tank underneath everything looks fine. Removing rear seats right now to check wiring.
@feldy sorry if i barged in on your thread. lmk if i should update my situation somewhere else.
R.I.P. '92 Honda Prelude you will be missed
Carban is offline   Reply With Quote
Old 08-03-2014, 12:51 PM   #19
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
I am getting the check engine light with code B14A1 when I drive hard with the AC on. Anybody getting this? The check engine light goes away but comes back if I drive it hard with the AC on. Just started getting this in the last month. I have a ECUTEK tune by dynotronics.
tripjammer is offline   Reply With Quote
Old 08-04-2014, 12:00 PM   #20
SilverFoxBRZ
BRZ Jockey
My code went away once the E85 was gone and I flashed to the Stage 1 v2.0 OFT 93 tune. The P0463 is clearly related to E85 is most documented cases which is disappointing.
Old 08-06-2014, 12:40 PM   #21
SilverFoxBRZ
BRZ Jockey
Aaaaanndd.... it's back. Off to the dealer on Monday.
Old 11-21-2014, 11:07 AM   #22
amilleri
Drives: 2010 Scion xD
Just got this code wednesday when I was heading to lunch. I only have 5400 miles, I guess it is related to bad gas.
amilleri is offline   Reply With Quote
Old 02-05-2015, 03:59 PM   #23
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Just threw the P0463 code. Running on 91 gas and tuned with OFT 91 octane stg1 map. Any ideasa? Is it serious? Always refilling on Cheveron, about 27k miles, gas light is on when the code went off.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 02-05-2015, 06:08 PM   #24
steve99
Drives: FT86
does not seem to be tune related suspect the P0463 code is due to problem with fuel level sender in tank or bad connection or wiring to fuel level sender. Never had that code myself.
http://www.obd-codes.com/p0463
Old 04-29-2015, 12:57 PM   #25
D-VO
Drives: Whiteout FR-S, Evo 8 RS
I've got the p013f after installing my wideband in the secondary o2 slot. I turned all the codes off that I thought related to the secondary when this one showed up after a few cycles. Is anyone else with this code tuned?
D-VO is offline   Reply With Quote
Old 04-30-2015, 12:31 PM   #26
sirsol66
Drives: 2013 FRS- Hot Lava
Did you ever figure this out?
sirsol66 is offline   Reply With Quote
Old 09-16-2015, 03:03 PM   #27
dolph
Drives: 2013 BRZ, 2004 WRX
Cross-posting my experience with this issue since there are multiple threads: http://www.ft86club.com/forums/showp...45&postcount=7
dolph is offline   Reply With Quote
Old 12-14-2015, 10:28 PM   #28
Carban
Grease Monkey
Carban's Avatar
No, this light still comes on from time to time when my fuel gets low. Nothing seems wrong with the fuel system, and car is operating normally as it always has.
Another CEL code whitefrs Forced Induction 20 11-27-2019 11:27 AM
CEL code P0172 jonbonazza Issues | Warranty | Recalls / TSB 18 11-25-2013 08:35 PM
p0300 code... Anyone else?? NickFRS Engine, Exhaust, Transmission 1 09-05-2013 11:33 PM
BRZ WRB code color PPG Trap63 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 06-18-2013 05:50 PM
