Old 07-30-2014, 08:22 PM   #6889
DAEMANO
Time Traveller
Originally Posted by silent runner View Post
Just a note back to the issue of some problems. I had an early issue in my testing, and Rob was also fantastically good about straightening it out! Now I have had an issue with the parts I developed for my prototype installation.
With multiple days of running around in temperatures, in the 31C (mid 90's F) range, one of my intake system hoses has split open. (a big beafy piece made by Mazda originally) After 7 months of reliable operation, I have to replace this piece, and re-assess how it can be made more durable! This is one simple, rubber hose... not a whole system. I totally get the challenge!
Wait, I'm confused. Is this still for the Camry from Hades or another make/model?
Old 07-30-2014, 09:00 PM   #6890
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
BTW: those who missed it (like me, my page was cached) the 6AT E85 1.5dump tunes are available. Clear your cache if you don't see them!
Stoked to get back on the corn...
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
The Following 3 Users Say Thank You to enwave For This Useful Post:
DAEMANO (07-30-2014), raven1231 (07-30-2014), WRB5titch (07-31-2014)
Old 07-30-2014, 09:02 PM   #6891
raven1231
You will be pleased
Old 07-30-2014, 09:24 PM   #6892
DriftHappens
Drives: '14 FRS White
I'll be in the area of Pikes Peak in a month, who wants to send me an ESC to test? LOL
DriftHappens is offline   Reply With Quote
Old 07-30-2014, 09:26 PM   #6893
fenton
You would probably have to pry it from the cold lifeless hands of its current owner lol.
I know I wouldn't give mine up lol. One day for dealer visits is almost too much..
fenton is offline   Reply With Quote
The Following 2 Users Say Thank You to fenton For This Useful Post:
enwave (07-30-2014), Gums (08-02-2014)
Old 07-30-2014, 09:34 PM   #6894
enwave
enwave's Avatar
Seriously though. I switched mine off today just to be reminded what my car used to be. I only lasted a few minutes that way haha.
The Following User Says Thank You to enwave For This Useful Post:
Old 07-30-2014, 10:12 PM   #6895
Urmyson
Can we run E85 if were still on the ESC 1.0 with a stock header? There's has to be others besides just me who haven't upgraded.
Urmyson is offline   Reply With Quote
Old 07-30-2014, 10:16 PM   #6896
Winjr
Drives: 2013 Subaru BRZ Premium
Originally Posted by DAEMANO View Post
E85 amplifies the beauty of the Phantom ESC like slapping stilettos on the end of Stacy Kiebler's already ridiculous legs.
LOL! This is all I need to know!!!
But the analysis and breakdown is equally excellent. Thank you!
Winjr is offline   Reply With Quote
The Following User Says Thank You to Winjr For This Useful Post:
Old 07-30-2014, 10:20 PM   #6897
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
I think that should be the phantoms new tag line.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Old 07-30-2014, 10:22 PM   #6898
Winjr
Took my car in to repair an exhaust leak (aftermarket), but before I did I removed the compressor and the wiring to the battery because I didn't want anybody in the garage screwing around with the system.
The Following 2 Users Say Thank You to Winjr For This Useful Post:
DAEMANO (07-30-2014), enwave (07-30-2014)
Old 07-30-2014, 10:39 PM   #6899
Winjr
About gunk in your D.I.s. I have not read about this issue yet on the board. I'd love to hear more about it though.
The DI for #3 was so fouled that I was basically running on just 3 cylinders. I'd enter a hill at 70 mph and by the time I got to the top I was at 50. When this started, fearing that I'd blow the car up by activating the ESC, I simply removed it until the problem was diagnosed and fixed.
So I sent out the DI to one of those outfits that clean your DI's for $25 a pop. He calls me and says "Sir, what the hell did you do to your DI? Did somebody put sugar in your gas tank?" Whatever the process is for cleaning - boiling, ultrasonic sound waves, whatever the piss they do - didn't work. He couldn't get the DI to spray at all.
Well, sugar in the gas tank apparently is mostly an urban myth, so I'll rule that out. Some logs I did showed that cylinder 2 was starting to act up, and from that day forward I've been putting nothing but BP gas (93, as always) in the tank. I can feel the gradual improvement, to the point where I don't feel even the slightest shudder at idle, unlike before. BP is a "top tier" gas, lots of detergents.
My son has a friend who works in a lab where the gunk can be analyzed, to some extent. Maybe I'll find out what it really is.
Old 07-30-2014, 10:55 PM   #6900
Urmyson
Do you believe this due to e85 or just crap gas? Just a heads up, I worked at a petroleum transportation company. They get all the gas from the same rack.
Old 07-30-2014, 11:04 PM   #6901
DAEMANO
Time Traveller
I think there's an ESC e85 package of maps in the oven. Still, this question is best left for @Shiv@Openflash to answer.
Old 07-30-2014, 11:31 PM   #6902
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
FWIW, you should be able to run single dump ESC set-ups successfully with the OTS 1.5 dump maps. It was just the other way around that was iffy
Shiv@Openflash is offline   Reply With Quote
The Following 6 Users Say Thank You to Shiv@Openflash For This Useful Post:
DAEMANO (07-31-2014), enwave (07-30-2014), Gums (08-02-2014), Sojhinn (07-30-2014), Target70 (07-31-2014), Urmyson (07-31-2014)
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
