Old 07-25-2014, 03:25 AM   #29
mtsui
Drives: 135i
I paid for a pad and I need to fix it? what is wrong with this market? if they refund it back to me and let me have it, then i will mess around with it
mtsui is offline   Reply With Quote
Old 07-25-2014, 03:36 AM   #30
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by rice_classic View Post
Centric makes some of the absolute best rotors money can buy. They are worth 2x what we pay for them. Just outstanding.
I will let you know how the 45's do regarding rotor wear. To me, rotors are $35 a piece so I only care that they last just 1 weekend. The 42's say they're almost identical in hot rotor wear but that's not true at all the 42's almost seem like they add material to the rotor, they really are the friendliest race pad to rotors I've ever run. Tim said the 42 is the most expensive compound for Raybestos to produce too. The 45 is the successor of the 41. Tim said if the 43 isn't enough then you should jump the 45 as opposed to the 41.
and that's exactly why I don't mind using ST43s for the street
I seriously considered ST42s in my Corvette before the ST43 since as you can see in the first field/column it's somewhat easier on the rotors ..after the ST43s I might try ST45s too
glamcem is offline   Reply With Quote
Old 07-25-2014, 03:39 AM   #31
glamcem
glamcem's Avatar
@mtsui
Skills schmills.. Go buy a $50 grinding wheel from Sears, some safety glasses and have at it. Seriously. Mark what you need to remove with a sharpie and just hold it to spinning grinding wheel until that part is no longer there. It takes literally no skill at all. Even the part that may contact the rotor hat, take that off too. Don't trust yourself? Grab a metal piece of something you don't care about and start grinding to get a feel for it.
The $49.99 one is all he needs 1/6th HP
http://www.sears.com/craftsman-1-6-h...2&blockType=G2
Or for the same price get the 3/4 HP one from Harbor Freight:
http://www.harborfreight.com/garage-...der-39798.html
I might actually just get one of these and play with it, I wish I had these when I was working on the backing plates it would make the job 100x easier
Old 07-29-2014, 12:05 PM   #32
86ft.lb
86ft.lb's Avatar
Drives: orange fr-s MT
I got really curious about ST43 everyone is raving about. I am running XP12 F/R and brake bias is on front, with/without pedal dance.
Does ST43 has similar friction compared to XP12? Swapping front only is the cheapest option for me, but I don't want more front bias or too much shift to rear.
86ft.lb is offline   Reply With Quote
Old 07-29-2014, 01:26 PM   #33
glamcem
glamcem's Avatar
You may as well get the rears so that you would be running the same compound pads to make sure, rears only add about $130 to the total cost and since these pads will last a lot longer than the XP12s it will make up the difference IMO
The Following 2 Users Say Thank You to glamcem For This Useful Post:
86ft.lb (07-30-2014), MyRx (08-01-2014)
Old 07-29-2014, 01:59 PM   #34
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Before we could buy them from Raybestos and knew their real name, we had to buy them from a private reseller and they were originally known throughout the paddock as the "miracle pad". It still holds true.
Adare Motorsports miracle pad?
Sleepless is offline   Reply With Quote
Old 07-29-2014, 05:04 PM   #35
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
That's the one.
SCCA T4 - FRS
Old 07-30-2014, 03:55 PM   #36
86ft.lb
86ft.lb's Avatar
Yep, just ordered both. Now I have 5 different compounds F/R - more freedom to mix and experiment
The Following 2 Users Say Thank You to 86ft.lb For This Useful Post:
glamcem (07-30-2014), MyRx (08-01-2014)
Old 07-30-2014, 04:24 PM   #37
glamcem
glamcem's Avatar
I should be receiving my ST43s today can't wait to put them on and do the bedding procedure ..woot!
The Following User Says Thank You to glamcem For This Useful Post:
MyRx (08-01-2014)
Old 07-30-2014, 05:13 PM   #38
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Looking forward to your impressions. I still have two sets of XP12s to burn through ...
The Following User Says Thank You to Sleepless For This Useful Post:
Old 07-30-2014, 05:34 PM   #39
glamcem
glamcem's Avatar
I will keep you updated, are you planning to come to August 19th event at RMP (CMS)?
Old 07-30-2014, 07:14 PM   #40
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Yes. And the 5th and 8th. Just upgraded to Ohlins so gotta test, er, play
Old 07-30-2014, 07:19 PM   #41
glamcem
glamcem's Avatar
5th and 8th ? I didn't see them ..CMS at Rmp?
Old 07-30-2014, 08:26 PM   #42
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
5th is Metropolitan Detail
8th is Turn 2
Torque RT700 - DOT 4 Racing Brake Fluid - Review CounterSpace Garage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 121 06-05-2023 10:23 PM
Touge Factory Brake Cooling Kit Review smbstyle Tracking / Autocross / HPDE / Drifting 70 04-03-2015 03:03 PM
Winmax W2 brake pad review? BRZPDX Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 06-10-2014 10:40 PM
DIY/Review: Dezod SS Braided Brake Lines TheBatman DIY (Do-It-Yourself) Guides 2 10-14-2013 01:48 PM
Brake fluid review opportunity CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 09-30-2013 07:42 PM
