#29 | |
OP if your state is similar, the other driver should automatically be at fault. That said, I probably wouldn't have submitted that video to your insurance unless the other driver denied changing lanes right before the intersection. That video makes it look like you were about to run that red.
2022 BRZ Build 2013 FR-S Build |
| The Following 3 Users Say Thank You to DarkSunrise For This Useful Post: |
#30 | |
There are only two applicable vehicle codes.
At the same time, that was pretty bonehead to try to beat the yellow light that. 45 mph road has a yellow light for 5.0 seconds (the minimum yellow is 3 second for a slower speed road). You weren't anywhere close. |
| The Following User Says Thank You to retoocs For This Useful Post: | chas3wba0 (07-30-2014) |
#33 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
You will be fine... but my feelings in regards to accidents like this one is it takes two people two crash. You are both at fault ( I think you slightly more than him though) He was at fault for the lane change for sure... but you clearly sped up at the yellow and wouldn't have made it anyways.... His lane change wouldn't have made a difference if you were driving more defensively. Everyone around you was braking (one of these things is not like the others)
| The Following User Says Thank You to Cockatoo For This Useful Post: | chas3wba0 (07-30-2014) |
#34 |
I think he is at fault. I think it can be argued that he made an illegal lane change at an intersection without checking his mirrors with no signal.
Maybe I am missing something, but did the police give you a ticket? And yes, I do agree with many here that you had no business trying to make this light... Last edited by thill; 07-30-2014 at 10:25 AM. |
| The Following User Says Thank You to thill For This Useful Post: | chas3wba0 (07-30-2014) |
#35 |
Drives: 2013 GBS BRZ Limited
A few things:
1 - He was at fault for: No turn signal, failure to signal lane change for at least 100 feet before lane change (so even if he HAD signaled, then he was still guilty of not doing it far enough in advance) 2 - What were you on Valium? Yor response time was WAY too slow, and you didnt even engage the ABS! It barely looks like you even applied the brakes 3 - Yes you are a jackass for trying to make that light. If someone had been trying to clear the intersection during the yellow from the oncoming left turn lane, it would have been worse. 4 - Why was your first reaction to NOT turn off the music? That is just an automatic response for most humans when something out of the ordinary happens. You will be fine. and the damage looks purely cosmetic. |
| The Following User Says Thank You to stugray For This Useful Post: | chas3wba0 (07-30-2014) |
#36 |
Technically the car didn't cut you off on a yellow. It was red when it started going into the lane.
#37 | |
Drives: Yes
As for response time... I don't usually go to work that early, so that's what I get for doing morning commute on not enough sleep. I thought I was driving pretty mellow up until that point, so mellow that I wasn't ready to react to a stunt like this.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#38 | |
Drives: Yes
Maybe I had planned to stop right at the line but him cutting me off made that impossible. That's how I would rebut anyway, but you're right my intent at the yellow/red light was questionable
#39 |
TALLY FT86
Yeah reaction time above all was pretty bad
#40 |
While the other driver is definitely at fault, you should probably thank him/her for keeping you from running a red light in your half-asleep haze.
| The Following User Says Thank You to stugray For This Useful Post: | Cockatoo (07-30-2014) |
#41 |
Drives: 2014 FRS - Whiteout - 6spd MT
the vehicle changing lanes will be held at fault, they're generally 100% at fault regardless of the speed that your vehicle was travelling at.
| The Following User Says Thank You to illicitstylz For This Useful Post: | chas3wba0 (07-30-2014) |
#42 |
Drives: '14 SWP BRZ Limited
If I was the insurance agent I'd rule it no fault. They had no business changing lanes that close to the red (plus without a signal) and you had no business approaching a red light at that speed. It's red plenty before he moves over and you should have been going much much slower at that point.
Sorry, but I think you contributed to that as much as the other driver did. Maybe more given that if you had been approaching at a proper speed and not driving impaired (not awake) you could have easily avoided that by breaking slightly harder.
| The Following User Says Thank You to Ouhei For This Useful Post: | chas3wba0 (07-30-2014) |
| Brake Light Switch Fault - TSB Fix | Dezoris | Issues | Warranty | Recalls / TSB | 4 | 01-07-2025 10:13 AM |
| Brake Switch Fault | TSB FIX | Dezoris | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 06-11-2014 10:11 PM |
| MOAR fault codesss! | jonbonazza | Engine, Exhaust, Transmission | 2 | 09-20-2013 02:47 PM |
| Torque fault codes help | derka-derka | Issues | Warranty | Recalls / TSB | 2 | 05-24-2013 09:07 AM |
| CEL/Idle Fault - Toyota GB Statement | Kodename47 | Issues | Warranty | Recalls / TSB | 5 | 10-25-2012 08:27 AM |
