Old 07-16-2014, 08:51 PM   #253
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by SkAsphalt View Post
You front end could be diving more because your bias is off, many people note that installing the STI rears throws off your bias and actually reduces the effectiveness of the rear braking (thus more nose diving)
I've actually overcome that issue by fitting higher friction rear pads. So I've got Stoptech in front, and Project Mu B-Spec in the rear. I'm no expert, but I can feel the 'front dive' effect has reduced somewhat.
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
SkAsphalt (07-18-2014)
Old 07-30-2014, 01:02 AM   #254
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I got mine from NASIOC, but there were not many to pick from especially when looking for the newer 08-13 Brembos so that you don't have to do this:
That makes the 04-07 Brembos a bolt on affair, and there are a couple companies that sell the brackets required already.
Is it the same bracket for wrxs doing an sti swap?
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 07-30-2014, 09:59 AM   #255
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
What year WRX? I don't know how the rear hubs have changed on WRXs over the year.
Old 07-30-2014, 10:03 AM   #256
protpibe
protpibe's Avatar
The brackets are for 02-05 WRX's so that Brembo callipers will bolt directly on
http://www.fastwrx.com/products/rear...-kit-02-05-wrx
Kartboy also makes a bracket
http://www.rallysportdirect.com/Kart...ot-Rear-Subaru
Old 07-30-2014, 12:00 PM   #257
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Not sure about those two, but I can confirm that the KNS ver2.0 bracket definitely works for pre-08 rear brembo calipers.
Old 07-30-2014, 01:47 PM   #258
protpibe
protpibe's Avatar
Thanks for the info
Old 08-03-2014, 08:37 AM   #259
mkivalex
Drives: 13 Scion FRS, 93 JDM Toyota Supra
Does anyone know if they will clear Enkei nt03 18x9.5 et 40?
mkivalex is offline   Reply With Quote
Old 08-22-2014, 09:52 AM   #260
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Had my calipers painted yellow, and got myself some nice lightweight rotors in front too.
Old 08-24-2014, 05:37 PM   #261
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
I'm going with 04 STI front and rear calipers. I'm currently using 57 extreme 19x8.5 face 1 with a +45 offset and 9.5 rears with +42 offset. Does anyone know if it will have trouble clearing the STI calipers?
Tye300 is offline   Reply With Quote
Old 08-24-2014, 09:22 PM   #262
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Yes 8.5" with a +45 will clear the front calipers. I looked into getting that size before deciding on a different wheel.
Rears will have tons of space. It's only the front clearance that matters.
Tye300 (08-25-2014)
Old 08-25-2014, 01:24 AM   #263
Tye300
Tye300's Avatar
Thanks!
Old 10-29-2014, 10:41 PM   #264
disgruntld
Less than pleased...
disgruntld's Avatar
Drives: '13 BRZ Ltd SSM 6MT
Better idea....sell the rear brembos and use the smaller Subaru rear 2 pot instead. Smaller rotor BUT more brake torque and better bias.
I don't actually know if that caliper will clear your spokes to be honest, I just think it's the better way to go...
- Andy
Interesting idea actually. Since we use the same bracket to mount the STI brakes, the WRX rear 2 pots should bolt straight up right? My only question would be regarding the e-brake. The 08+ rear STI rotors have the same parking brake dimensions as the twins, can anybody speak to the WRX rotors? Also, for those looking for new caliper bolts amayama.com has the Subaru branded ones for $2.50 a piece. Some guy said his dealership was charging $9...
disgruntld is offline   Reply With Quote
Old 10-31-2014, 09:23 AM   #265
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Any one has any suggestions about the brake bias??
I got Stoptech Street front and rear now; however the brake bias is really bad. I think probability because the Sti Brembos are not designed for our car, so you can not use the same pads front and rear. At hard brake I can feel the rear end of my car not stable. I think the rear brake is a little bit weak relatively. Am I correct? Or the brake bias is not that bad it is just my personal feeling a stronger pads rear will not change alot?
Now I got Carbotech Bobcat 1521 pads front and rear not installed yet. I went 1521 because they might have less brake dust. I am thinking to keep the 1521 front and to get a relatively strong pad on the rear.
Any one has any suggestion on this? A Street pad like 1521 will be preferred.
Thank you!
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 10-31-2014, 09:45 AM   #266
protpibe
protpibe's Avatar
Thank you!
Are you saying that it's too strongly biased to the rear or not strong enough?
will the sti brembos fit fr-s/brz? driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-12-2014 02:25 PM
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 02:06 PM
