Old 07-27-2014, 02:08 PM   #253
C130NAV
C130NAV's Avatar
Drives: Whiteout 6Sp FR-S
Mine are doing fine with 4k miles no issues.
C130NAV is offline   Reply With Quote
Old 07-27-2014, 02:20 PM   #254
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
No Issues, great product
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 07-27-2014, 05:08 PM   #255
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
Winjet HID from Winjet
Before I changed the Carbon fiber wrapped hood to look like ... this one down below...
Only issue I have is SOMETIMES....1 of the lights won't turn on...it's random. The HIDS were installed directly from Winjet so I paid a bit more...but it's not a huge issue...just turn the lights off then back on and POW!!! they are fine...
Celigts is offline   Reply With Quote
Old 07-29-2014, 09:49 AM   #256
tonystewart
Celigts, which connector (straight D2S or Amp to D2S) do you have for your bulb?
Old 08-11-2014, 09:46 PM   #257
SunkenFRS
Sideways & Smiling
SunkenFRS's Avatar
Drives: 2013 Raven FRS
heres mine
2013 Raven FR-S
Flossy - Fortune Auto - ESM - Project Kics - Borla - Berk - TRD - HT Auto - Winjet - P3 - Koyo - CarolinaDyno - Mocal - FIC - FBM
SunkenFRS is offline   Reply With Quote
Old 03-01-2016, 06:31 PM   #258
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Bump
Instagram: trevor.parque
Old 03-14-2016, 01:45 AM   #259
MisterSheep
Killed Scion
Im looking at getting chrome and painting them black to match the oem ones.. any tips on getting it done without messing them up too badly?
Old 03-14-2016, 04:38 PM   #260
BAMF86
much slow
BAMF86's Avatar
Drives: 13 Raven FRS, 05 Rio Yellow S2000
I followed this guide
Pretty happy with the way they turned out, just be patient when taking apart the headlights and when removing the painters tape.
The chrome comes off SUPER easily if using light painters tape, i'd recommend just using newspaper to cover the chrome and tape around the edges. Might as well do a retrofit while you're at it cause the winjet projects aren't that great.
BAMF86 is offline   Reply With Quote
Old 03-14-2016, 04:49 PM   #261
MisterSheep
Killed Scion
that guide does everything needed? thanks for the help!
Old 05-28-2016, 09:40 AM   #262
D5teph
Automotive Enthusiast
D5teph's Avatar
Drives: Zenki 86
Originally Posted by NorCal_Guy View Post
Damn, I need to get me a set of Winjet's. Are there any issues installing these or condensation issues?
Btw, what front lip is that you got on? It looks really good!
D5teph is offline   Reply With Quote
Old 05-30-2016, 12:08 AM   #263
Kazuya
Kazuya's Avatar
Drives: Takumi
I'm probably the only one who likes chrome winjets
Kazuya is offline   Reply With Quote
Old 04-22-2017, 05:16 PM   #264
Nonstopper0
Nonstopper0's Avatar
Drives: 2013 Grey Varis Widebody FR-S
Nonstopper0 is offline   Reply With Quote
Old 03-15-2021, 01:02 PM   #265
DarkSunrise
DarkSunrise's Avatar
Pretty good for the money. Not as good as other OEM xenons I’ve had, but much better light output, visibility and cutoff than stock halogens. Had a bit of fogging driving up to the canyons in 40 F weather, but didn’t affect visibility.
2022 BRZ Build
2013 FR-S Build
Old 03-20-2021, 08:53 AM   #266
SP86
2S Crew
SP86's Avatar
Drives: a 2013 FR-S
Originally Posted by SP86 View Post
Got mine in today. Much more of a clean look vs oem imo.
Didn't realize I've had these 2014. Time flies! Just as an update; I still have them installed. No issues aside from the clear coat eroding. But that was easy enough to fix.
My 2013 FR-S
SP86 is offline   Reply With Quote
Winjet Headlights and HIDs HakunaMiata Cosmetic Modification (Interior/Exterior/Lighting) 27 07-18-2017 10:24 PM
New Winjet Headlights LED FLICKER?! Jeremehh Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2016 03:26 PM
Winjet Headlights - Installed, Compared, and done up the FT-86 SpeedFactory Way! FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 42 03-24-2014 11:08 PM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 08:28 AM
Norcal GB: Winjet JDM Style Headlights 86_ZN6 Northern California 2 12-11-2013 03:31 PM
