Old 05-30-2014, 02:38 PM   #421
R2
I replaced the stock fluid with Redline MTL in January and wanted to wait until the summer to report on my experiences. Given the large temperature range in my part of the world, -40C to +35C, I've experienced a huge change in the feel of the car. So, now that it is summer and we've had some hot days, here's the summary of results:
Winter(Stock fill)
-Similar results to everyone else, the transmission was extremely stiff until driving it for 30 min or more, then it would become fairly smooth. It would whine at temperatures below -30C, kind of sounded like it had straight cut gears. At temperatures below ~0C it would consistently refuse to allow a 1->2 or a 3->2 shift, and double clutching provided only a 50% success rate. Plenty of grinding on the 1->2 shifts that were successful, but this always improved with about 5-10km of driving. The result of this was I almost never used 1st gear in winter, 2nd was the go to at lights and stop signs.
Winter (MTL fill): 1->2 and 3->2 shifts NOT improved at all, still got the lock out feel and plenty of grinding. Double clutching had the same success rate as the stock fill. Shifting effort was reduced though, initially it didn't feel as good but I learned to like it. The biggest benefit was that it felt like it was much warmer at any given temperature than with the stock fluid, so the lower viscosity at low temperatures was obvious.
Summer (Stock fluid): At temperatures above 20C it felt great all the time. Below 20C I'd get the occasional grind on 1->2 shifts. When the transmission was warmed up from driving, shifting felt perfect.
Summer (Redline MTL): Shifting feels "lighter" at temperatures above 0C, and feels great at temperatures above 20C. When the transmission is warmed up from driving, shifting feels perfect - perhaps this happens a bit quicker than when on the stock fluid.
As it turns out the stock fluid (after ~14,000km) has a similar viscosity as MTL fluid @ 100C. http://www.ft86club.com/forums/showthread.php?t=62288
TLDR: Summer - not much difference, winter reasonable and worthwhile difference.
R2 is offline   Reply With Quote
Old 05-30-2014, 06:02 PM   #422
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
NVMD
In God We Trust - Hold No Faith That Violates Reason
SpeedyJay is offline   Reply With Quote
Old 06-01-2014, 05:21 PM   #423
Calle
Calle's Avatar
Drives: Toyota GT86 SWP
I replaced my stock transmission oil during the weekend with Redline MTL and shifting greatly improved. I live in Sweden and temperatures are between 5 and 20C at the time. The car has rolled about 7800km and there wasn't much metal on the drain plug magnet.
I never experienced grinding with the stock oil but the shifts between 1 and 2 was quite stiff and notchy. With the Redline oil the shift feel is probably one of the best I've tried to date.
The next step is to replace the differential oil but I'm not expecting a major difference.
On a side note the underbody panels are quite cool, didn't expect to see them on my EU GT86.
Calle is offline   Reply With Quote
Old 06-08-2014, 09:22 AM   #424
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by PMPB View Post
I think I've come to the conclusion that Motul Gear 300 is no better than the stock fluid. It's summer here now, and second gear is still crunching for the first 4-5 shifts, and once the car is fully warmed 2nd still feels really stiff.
I may also have developed a new to me click/nick with 3rd gear. Also, first is now impossible to get if the car is rolling over 5km/h (I'd never try over 8-9km/h). So it's easier to slam on the breaks, pop it in first and blast out of there after the traffic starts honking at you.
Gear 300 may in fact be WORSE than the stock fill so much for that idea... Ontario is still not 'stinking' hot yet, so I have some hopes it'll get better through the summer. I fully expect that this fall I'll be voiding my warranty with Pentosin.
Unless you're going to run and tell them to note what you're using or can't somehow change b4 you take in "if there was an actual problem" can't see why you would void anything. Some folks around here with tranny problems not related to oils at all have had the P oil in there and dealers did not void anything..
Suppose depends on your dealer...lots of folks running this Tranny oil zero issues, it's only an improvement.
Old 07-28-2014, 03:22 PM   #425
ML
ML's Avatar
Drives: 13 White MT FR-S
These are my options for fluid locally. Kinda confused about which one for the trans, and which one for the diff.
http://www.pepboys.com/product/detai...r_oil/gear_oil
Old 07-28-2014, 08:38 PM   #426
roddy
roddy's Avatar
Drives: '13 Ultramarine
If that is what you want to use, Synchromax for the trans and Max Gear for the diff. You'll need 3 (~2.3) for the trans, and 2 (~1.2) for the differential.
Old 07-30-2014, 07:16 PM   #427
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
2nd one..
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 07-30-2014, 09:58 PM   #428
ML
ML's Avatar
Originally Posted by zoth View Post
2nd one..
For both?
Old 07-30-2014, 10:40 PM   #429
zoth
zoth's Avatar
For both?
yeap
Old 08-05-2014, 10:55 PM   #430
qqzj
Drives: MDX, Camry
Just want to make sure. Are we talking about this from Amazon?
[ame="http://www.amazon.com/Pentosin-MTF2-1L-75W-80-Transmission-Fluid/dp/B00JMAQ39G"]Amazon.com: Pentosin (MTF2-1L) SAE GL-4 75W-80 Transmission Fluid - 1 Liter: Automotive[/ame]
It is about 22 bucks. Why I saw people paying $80+ for it? Am I missing something? Thanks a lot.
qqzj is offline   Reply With Quote
Old 08-06-2014, 12:09 AM   #431
ML
ML's Avatar
Might want to watch this thread
http://www.ft86club.com/forums/showthread.php?t=71516
Old 08-06-2014, 08:49 AM   #432
stevo585
Drives: White 2014 BRZ
I'm running the Gear 300 here in Florida and its hot of course 90-95F. Its still notchy when cold but once warm it feels nice. But really not much better than the factory fill.
What I noticed the most is the cold diff "chatter" is gone.
stevo585 is offline   Reply With Quote
Old 08-26-2014, 08:02 AM   #433
surcy
Drives: 2014 BRZ Limited
After reading through all of this, I decided to replace my 6sp manual transmission fluid (2700 miles). My transmission had the 2nd gear change difficulty when cold and also random changing difficulty. As info, the factory fluid looked like new and there was a very small black build up on the magnetic drain plug--no metal particles.
I wasn't sure what to use; however, I had 3 liters of BMW MTF-LT-2, SAE 75W-90, API GL4 left over from a 2004 M3 trans fluid change, so I decided to try this. I understand that this is the same as the Pentosin fluid.
Initial impression is that the trans shifts very smoothly--much improved over the factory fluid. No second gear issues whatsoever. I will evaluate over time and report back on results.
surcy is offline   Reply With Quote
Old 08-26-2014, 08:05 AM   #434
surcy
Correction in the last post: The BMW fluid was SAE 75W-80
Official Australian Toyota 86/Subaru BRZ Owners Thread Maj3sty AUSTRALIA 148 09-02-2017 06:55 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
Must-read for Top Gear fans Sport-Tech Other Vehicles & General Automotive Discussions 16 03-28-2012 09:38 AM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
Will FT-86 have Synchro Rev Match? Dark Scion FR-S / Toyota 86 GT86 General Forum 56 05-27-2010 11:05 AM
