#1065 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
I'm switching to Carbotech XP12 for track pads in the rear to most evenly match the CL RC6's in front.
Thanks @CSG Mike! |
| The Following 2 Users Say Thank You to ATL BRZ For This Useful Post: | chanomatik (07-21-2014), CSG Mike (07-22-2014) |
#1066 | |
If you swap coils with another cylinder, the code will go away (for a while), but it wil lnever appear in the other cylinder... |
#1067 |
#1068 |
Negative, but we've seen it fairly often on customers that track their cars. Swapping the coil is enough to alleviate the problem, and the code is always for cylinder 2 (front passenger side).
#1069 | |
Looking straight at the engine it's 1 (PF), 3 (PR), 2 (DR) , 4 (DF) For the Check Engine Lights, respectively: P0351 = Cyl/Coil #1 or "A" = Passenger's side front (Most common failure) P0352 = Cyl/Coil #2 or "B" = Driver's side front P0353 = Cyl/Coil #3 or "C" = Passenger's side rear (Second most common failure) P0354 = Cyl/Coil #4 or "D" = Driver's side rear Last edited by ATL BRZ; 06-09-2015 at 04:14 PM. |
#1070 | |
You are correct, I usually see P0351. Brain fart moment. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | ATL BRZ (07-22-2014) |
#1071 |
Finally received two new coils and replaced the #3 in the nick of time this afternoon.
![]() Ready for some banked Nascar turns tomorrow at AMS! |
#1072 |
Shacked up in the Nascar garages.
![]() ![]() Dis gun b gud
| The Following User Says Thank You to ATL BRZ For This Useful Post: | gramicci101 (07-26-2014) |
#1073 | |
Drives: GTI, BRZ
#1074 | |
It's a $91 part so you'll want to have them replace it if you can. |
| The Following User Says Thank You to ATL BRZ For This Useful Post: | Lawn_Mower (07-28-2014) |
#1075 | |
Drives: GTI, BRZ
![]() I'll hit up my dealer and see what they'll do, the engine is stock so I don't really think it should be too much of a problem. I should probably pull the numbers off before Taking it in though lol |
#1076 |
weekend recap
Very eventful weekend full of new experiences coupled with the hottest air we've had all summer. Saturday I was at AMS and Sunday I went white water rafting down the Ocoee river and had a blast.
Atlanta Motor Speedway was amazing. I loved the facility and being able to use the Nascar garages. The track was a ton of fun. The infield road course was a little bumpy but the new pavement is good at promoting grip. The Nascar oval was just incredible when I got the car up on the high banks and redlining 5th gear at 125mph and taking 6th around Nascar 3 and flooring the throttle and white knuckling the steering wheel. The new suspension and braking gear worked perfectly. The BBK is amazing and the race pads are loud as hell after bedding with any amount of pedal besides threshold braking. The brakes are now so damn thermally efficient that I couldn't keep heat in them going around the oval and into turn 1. After a few laps I noticed significantly less bite into turn 1 than anywhere else around the course since they cooled off too much around the oval, so I started braking extra early there. My RCE T2 coilovers and Raceseng shock tops are providing a tremendous amount of mechanical grip at speed and I'm now able to say they are absolutely worth it. The car felt more nimble and capable than ever out there. I wasn't able to get as much track time as I had hoped for since there were some delays due to a couple fluid spills and one incident on track, but I was still able to have lots of fun in both my car and my student's. I will definitely be back at the next AMS event. It's a great track for spectators as well, probably the best around Atlanta since you can see so much of the track right outside the garages in the infield. My GoPro footage is uploading now and probably wont be edited together and ready until tomorrow, but I did receive some pretty good photos today so I'll start off with the first 10: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#1077 |
NASA SpecE30 Racer
Pics look good. I still keep hoping NASA will run an event at AMP or AMS one of these years. Might have to take my soon to be track car there to add those tracks to my list.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | ATL BRZ (07-28-2014) |
#1078 |
Second set of photos from AMS 7/26/14
| The Following User Says Thank You to ATL BRZ For This Useful Post: | Sportsguy83 (07-28-2014) |
| Tags |
| jdl turbo, mazworx, racecomp engineering, track build, verus engineering |
| Wnt3d's 86 - Turbo E85 Daily/Track Build | wnt3d | Member's Car Journals | 77 | 07-17-2017 04:35 PM |
| No Limit Motorsport Full Blown BRZ Build | No Limit Motorsport | Member's Car Journals | 16 | 07-08-2014 01:46 PM |
