Old 07-22-2014, 12:39 AM   #141
Slysdexia
Slysdexia's Avatar
Drives: '14 Monogram 6MT FR-S - Hot Lava
It's reasonably easy to trigger the coils, though a cheap multimeter won't catch the output spike. Load up the primary with 12v, give the secondary somewhere to ground, and pull power from the primary. As the primary magnetic field collapses, it should trigger the secondary.
You'll also want to measure the resistance across the primary and secondary coils.
Sent from my hand computer using radiation.
Slysdexia is offline   Reply With Quote
Old 07-22-2014, 10:04 AM   #142
MAPerformance
Drives: Asphalt FRS
The Okada coils are sold as a complete set. I can't comment on their heat tolerance as I have yet to try/test these out on our car.
Originally Posted by gramicci101 View Post
Those are actually GM LQ9 coils that Mojo builds brackets to use with various engines. I'm not having any luck finding physical dimensions for the injectors to see if they'd fit though.
@MAPerformance, are the Okada coils priced individually or as a pack of four? Are they any more tolerant to heat than the OEM coils?
Cusco's are too expensive. Alternately, you could contact Accel, MSD, or similar companies about making some.
MAPerformance is offline   Reply With Quote
The Following User Says Thank You to MAPerformance For This Useful Post:
gramicci101 (07-22-2014)
Old 07-22-2014, 10:37 AM   #143
ja1217
Drives: 2004 Toyota RAV-4 5M
This may have been discussed earlier in the thread, but would an oil cooler help prevent coil/direct injector seal failures?
I'm actually going through the process of getting the P0351 code fixed (probably bad coil pack and I'm getting the popping noise under some conditions so the DI seals are probably having issues as well) and just started logging my oil temps when I track the car. This weekend they were consistently in the 270-280f range while on track, so I think an oil cooler is going to be my next upgrade.
ja1217 is offline   Reply With Quote
Old 07-22-2014, 10:44 AM   #144
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Don't "think" it will be your next upgrade, do it ASAP.
The oil cooler will help prevent the CP failure. It will also help prevent DI failure too (if it has already failed, nothing left to do).
Also, are you tuned? If not, I recommend getting one to fix the DI failure issue. (You can also flash the newest calibration with fix with a tactrix cable for free).
Old 07-22-2014, 10:53 AM   #145
ja1217
By next upgrade, I mean it will be done before my next track event. Still on stock tune, I think it was flashed around May last year with whatever was the most recent flash, so I'm not sure it has the DI fix or not. I'll look into getting a tune in the near future, but wanted to hold off until I upgraded exhaust.
The Following User Says Thank You to ja1217 For This Useful Post:
Sportsguy83 (07-22-2014)
Old 07-22-2014, 11:24 AM   #146
gramicci101
Off Topic
OFT stage 1! You can bump to stage 2 once you get your exhaust done, but stage 1 is still a decent improvement over stock and gets rid of the DI issue.
Old 07-22-2014, 11:28 AM   #147
Sportsguy83
Drives: Limited BRZ
Well good. But also like I said, with a tactrix cable a friend can lend you for an hour or so, you can flash and fix the DI issue if indeed you need it and don't need to pay a dime for it.
Old 07-25-2014, 10:32 AM   #148
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Originally Posted by ATL BRZ View Post
No issues yet on the drivers side.
That's a good understanding of what's happening, but nobody knows with certainty if that's the true cause of failure. Go back a few pages in this thread and you'll see some heat shield ideas that I thought of and came to concept thanks to @gramicci101
I've already gone through coils A and C, and recently started to see a CEL for B. A and C were replaced under warranty at the same time, along with direct injectors, about 6 months ago. Car is currently at the dealer for Coil B, and I just got a call from them telling me they are replacing all 4 spark plugs and coils, because supposedly there are some updated parts. The service adviser could be feeding me BS, but when I pick the car up, I'll inquire about part numbers and possible TSB info and post an update here.
raul is offline   Reply With Quote
The Following 3 Users Say Thank You to raul For This Useful Post:
ATL BRZ (07-25-2014), gramicci101 (07-25-2014), SPCorBUST (07-28-2014)
Old 07-28-2014, 09:38 AM   #149
raul
Lap time enthusiast
raul's Avatar
@ATL BRZ @gramicci101
Got the car back. No TSB, but they replaced 4 spark plugs and ignition coils. Hopefully the SEC makes oil coolers legal for STX for next year because I'd like to continue tracking and autocrossing with the same car.
Old 07-28-2014, 11:21 AM   #150
gramicci101
Off Topic
I thought that was already legal? Or at least, being very actively discussed and favorably looked upon by the rules people?
Old 07-28-2014, 11:49 AM   #151
raul
Lap time enthusiast
raul's Avatar
It's under review with a positive outlook, but hasn't been fast tracked yet, to my knowledge.
Old 07-28-2014, 11:51 AM   #152
ja1217
Finally got the Toyota dealer convinced there might be a problem with the DI seals. After a ride along with me reproducing the popping noise and the mechanics call with Toyota headquarters with logs from the ride along, they are going to inspect the seals. Oil cooler is also on the way so hopefully I won't have to deal with this problem again after the cooler is installed and a tune.
Old 07-28-2014, 11:52 AM   #153
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
It's not legal YET but it is 99% sure to go through.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 07-28-2014, 12:13 PM   #154
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Please stay on topic in this thread, which is for ignition coil failure and the subsequent CEL codes related to it.
We don't want people reading this and thinking that P0351 or similar codes mean their DI seals have failed. The two problems are NOT known to be directly related.
Threads for DI seal failure discussion:
http://www.ft86club.com/forums/showthread.php?t=36008
http://www.ft86club.com/forums/showthread.php?t=42849
The Following User Says Thank You to ATL BRZ For This Useful Post:
Kido1986 (07-28-2014)
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 05:29 PM
