Old 07-25-2014, 11:39 AM   #841
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Originally Posted by EquiFox View Post
If we talked by email, then I am crazy and I can't remember it haha.
My name is not jordan, confusing me with someone else ?
Should I contact you by email to get a spot in the waiting queue ?
Ill PM you.
JDLAutoDesign is offline   Reply With Quote
Old 07-26-2014, 12:43 PM   #842
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
So....the dyno.....when can we see it?
Fizz is offline   Reply With Quote
Old 07-27-2014, 05:43 PM   #843
nelsmar
erhm... oop sorry its been a horribly busy week! I'll post dyno's of the header today once I get a little more caught up. The catted header did fairly decent up top, the torque dip was a bit to be desired but having that cat that close to the engine really doesn't help when a header is designed for higher RPM power. Overall gains were fairly decent and the audible part of the header was extremely pleasing, I have a clip somewhere i'll upload to youtube today/tomorrow.
My flickr - Canibeat
Local magazine scout
Old 07-27-2014, 08:53 PM   #844
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
No worries, I was just teasing. So I gather then that the catted header doesn't perform as well as the uncatted header in terms of bumping up the torque dip area? Hmmm....wonder if I should pay extra for the catted or just go with catless header.
Old 07-27-2014, 08:56 PM   #845
DarkSunrise
DarkSunrise's Avatar
The odd thing is, it appears based on a few independent dynos that "the other" catted UEL header seems to eliminate the torque dip completely. Wonder what the secret behind their design is.
2022 BRZ Build
2013 FR-S Build
Old 07-27-2014, 08:56 PM   #846
nelsmar
I would go catless if you dont need the cat, or if you need the noise reduction get the catted. The torque dip was still quite apparent but the mid RPM and high RPM was quite nice. It seemed as if the catted UEL made more power from 4-5k RPM than the UEL. But significantly less from 3,600 to 4,600. Top end was very similar on the catted edition though!
Old 07-27-2014, 08:57 PM   #847
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Was this on the stock tune?
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8
the new guy is offline   Reply With Quote
Old 07-27-2014, 09:05 PM   #848
nelsmar
Different runner length & collector style. There is a lot involved with how scavenging affects work. The car I tuned this week made something like 10-15% WHP gain at peak from just the header. FT86speed factory posted a dyno of theirs making less than 10% iirc. I dyno tuned before and after the header install (no other changes)and if anything the tune was more conservative with the header...
The engine load in the torque dip was fairly low so I am going to guess the scavenging was not so efficient in the torque dip with the catted header. Mind you this was a prototype... I was pretty disappointed at first until we pulled up the finished results and i was actually surprised at the fact it made a fairly consistent torque increase at nearly every RPM and it really didn't fall off much up top. I think if I would have played with the VVT a tad more up top i might be able to hold and extend the power to a higher RPM than I usually tune for. possibly usable power upwards of 7,800-8,000RPM even on pump gas. However I obviously don't recommend revving to 8,000 as it hasn't been thoroughly tested in extreme conditions.
Old 07-27-2014, 09:18 PM   #849
nelsmar
I have attached the catted UEL plot bellow. But before you jump to conclusions based on numbers...
The car already had a perrin 3" exhaust, nameless catted FP/OP combo, and a drop in filter. This car was an automatic. This dyno reads extremely low (something like 20-25% lower than a dynojet). Auto's run 120-130WHP on this, manuals are 130-140WHP.
The baseline was his exhaust, FP/OP, and drop in filter after dyno tuning, the header was installed the next day and re-tuned using similar techniques. The baseline peak was 132WHP. This was consistent through multiple pulls. The final numbers ranged from 147-150WHP so I plotted one of the more "average" results rather than the highest. (It was pretty warm out, even though this dyno does great at compensation when you break into 110F weather the car likes to start to give you hell).
If you notice the power gains were at nearly every RPM... so yes there was a torque dip but there were gains in the torque dip. But from what I have seen the UEL headers from multiple companies are giving nearly no gains at about 5kRPM where as this one is giving a stead 2-5WTQ through that entire region.
I forgot what the peak WTQ was on the tuned baseline but it was a WTQ gain of ~10-11%. The WHP gain was 16WHP netting ~12% WHP gain. This is actually quite decent... This car was starting to get closer to a lot of the tuned manual cars peak gains, and as you can see the tq was barely falling at 7,500RPM. Overall this header is actually quite decent. Even if you look at just the WHP gains considering this is an automatic and you compare it to higher reading dynos this is still a very decent gain.
The Following 2 Users Say Thank You to nelsmar For This Useful Post:
DarkSunrise (07-27-2014), Fizz (08-04-2014)
Old 07-27-2014, 09:25 PM   #850
nelsmar
For those of you wondering how much of the torque dip was elminated here is a plot with one of hte stock roms with the OEM header. I flashed the stock rom with the advanced multiplier set to 1.0 and did some constant load driving for 5-10 minutes and started doing pulls. It was losing power every pull. I pulled one of the middle pulls. This came in at 128WHP. The lowest I got was 124WHP and it was still losing power on every pull... I was guessing it was going to land 121-123WHP with the stock rom after learning fully kicked in. I figured I would just get one of the middle plots so that way it doesn't look like I am "fluffing" my numbers up. The torque dip was basically cut in half. The header gave a weird torque bump at a really low RPM making the illusion of the torque dip even worse (but in reality it just had an odd resonance gain at the lower rpm??)
Old 07-28-2014, 03:28 AM   #851
wizzo
Drives: 2014 Toyota 86
Seems like the JDL EL has had the best results so far judging my Nelsmars dynos
wizzo is offline   Reply With Quote
Old 07-28-2014, 01:15 PM   #852
nelsmar
If you are only judging the torque dip elimination yes it is. When it comes to power gain the UEL makes more. But I haven't tested an EL on anyone with an OP at this point...
Old 07-28-2014, 11:43 PM   #853
wizzo
Ive always known that 4-1 and EL are more top end orientated, was this not your finding? My car might be the first JDL EL you tune with a full 2.75 inch exhaust
Old 07-29-2014, 03:53 AM   #854
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
@nelsmar thank you for being complete and thorough with all your testing glad to see tuners like you working on the platform and this forum
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
The Following User Says Thank You to calmtigers For This Useful Post:
nelsmar (07-29-2014)
JDL Auto Design ft_sjo User/Vendor/Sponsor Reviews, Feedback, Comments 58 04-28-2017 10:13 AM
JDL Auto Design alexand3r User/Vendor/Sponsor Reviews, Feedback, Comments 4 12-11-2013 12:05 PM
New Scion FR-S products by Coverking are now at TAP Auto parts TAP Auto Parts Interior Parts (Incl. Lighting) 9 06-06-2013 07:43 AM
Check out some of the new products from Auto Finesse DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 05-08-2013 08:42 AM
JDL Auto Design...What We Do JDLAutoDesign Announcements, Contests, Giveaways 21 10-30-2012 09:05 PM
