Old 07-24-2014, 04:27 PM   #71
johnnyfast11
Drives: none yet
After driving this for 3 days.
This mod made the whole car feel completely alive. this is definitely the best mod i've ever had. and i've done it all besides motor mounts.
johnnyfast11 is offline   Reply With Quote
The Following 2 Users Say Thank You to johnnyfast11 For This Useful Post:
ATL BRZ (08-14-2014), Mikepage (07-24-2014)
Old 07-27-2014, 07:47 PM   #72
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Originally Posted by Coheed View Post
That's why I'm curious. I had urethane insert motor mounts and they stiffened up quite a bit in comparison to the WindoWeld mounts.
The Urethane cures into a rather low durometer material. I can't imagine it will be nearly as stiff as inserts or urethane replacements. But I feel this could possibly be a solution to the movement without being overly harsh on NVH.
I've used several types of motor mounts, but the Windo Weld'ed stock mounts were my favorite. Perhaps I will try this just to see how it does.
Originally Posted by chutrain View Post
I removed the diff inserts and they removed the sound. This is with leaving the outriggers in. I think I will try to put just the bottoms of the diff inserts in to slightly stiffen it up but leave a little isolation from diff and frame, in theory that is. Will report when I get a chance.
Any updates? I made a thread about window weld mounts and nobody did it on our cars yet.
I could probably deal with a clunk, but I wouldn't be able to handle constant gear whine on the freeway.
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 07-27-2014, 07:59 PM   #73
jvincent
jvincent's Avatar
I don't notice any whine on the highway.
The Following User Says Thank You to jvincent For This Useful Post:
Mikepage (07-27-2014)
Old 07-27-2014, 08:00 PM   #74
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Over 100/110km/h?
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 07-27-2014, 08:01 PM   #75
jvincent
jvincent's Avatar
Yep. Usually doing 120/125. I have Motul Gear 300 in my differential, so that may be a factor.
Old 07-27-2014, 08:17 PM   #76
Mikepage
Mikepage's Avatar
I hâve also changes my oil for Amsoil severe gear sae 75W-90 GL5 and i have gear sound.
Maybe your oil is better? I don't think so... But maybe...
o= FR-S =o
Old 07-27-2014, 08:37 PM   #77
jvincent
jvincent's Avatar
Could be. Or I might just be deaf at that frequency now.
The Following 2 Users Say Thank You to jvincent For This Useful Post:
fx35s (04-11-2016), Mikepage (07-27-2014)
Old 07-27-2014, 10:55 PM   #78
Hawk77FT
Drives: GTS 86
i hear a hum, like is metal on metal type thing, in the 5th at about 60-70 km/h. Is that normal? It sounds like is coming from the diff, but i am not sure.
Hawk77FT is offline   Reply With Quote
The Following User Says Thank You to Hawk77FT For This Useful Post:
nickmerronesucks (06-01-2016)
Old 07-28-2014, 08:10 AM   #79
Mikepage
Mikepage's Avatar
Yes, If you have all bushings we have, then yes it's probably normal.
o= FR-S =o
Old 07-31-2014, 07:24 AM   #80
Brinks
Brinks's Avatar
Just installed this tonight. Anybody else notice a vibration from 4-5k that you can feel in the pedal? Its almost like the drive shaft is not balanced correctly.
Brinks is offline   Reply With Quote
The Following User Says Thank You to Brinks For This Useful Post:
Old 07-31-2014, 07:41 AM   #81
Mikepage
Mikepage's Avatar
Mmm i don't think i have vibration in the pedal.
You have only rear diff bushings?
o= FR-S =o
Old 07-31-2014, 07:51 AM   #82
Brinks
Brinks's Avatar
Rear Diff, Rear subframe, ForcedFab/Whiteline transmission mount and shortshifter/polly bushings.
Hopefully I didn't tweak something during the install. I did the rear sub frame at the same time, I had some issues with that install and was raising and lowering the rear subframe quit a bit. Its a weird vibration, Cant tell if its from the drive line or the engine itself.
Old 07-31-2014, 09:19 AM   #83
jvincent
jvincent's Avatar
No vibration here.
Old 07-31-2014, 09:29 AM   #84
Mikepage
Mikepage's Avatar
I can confirm from my morning ride, no vibration with my setup.
o= FR-S =o
DIY - Whiteline Rear Crossmember Mount Insert Bushings F1point4 DIY (Do-It-Yourself) Guides 91 01-17-2021 02:23 AM
Whiteline crossmember bushing insert review Mikepage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 11-09-2016 03:30 PM
Rear Shifter/Transmission Mount Insert Bushings TheseColorsDontRun Mid-Atlantic 7 08-30-2013 10:29 AM
Whiteline diff bushings and trans mount insert. Simmons Transmission and Driveline 7 06-09-2013 08:45 PM
WhiteLine Positive Shift and Rear Subframe Bushings Review @ Pure Automotive Pure Automotive Mid-Atlantic 5 01-16-2013 05:15 PM
