Old 06-09-2014, 01:12 AM   #57
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Originally Posted by Tye300 View Post
Finally installed the bushings. I was not able to install the rear ones because I have the diff brace already. The outrigger inserts definitely stiffened up the diff as I can hear the noise the other guys are talking about.
Thanks for your feed-back!
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 06-09-2014, 08:06 AM   #58
mid_life_crisis
Drives: FR-S 10 #103 AT
I'm beginning to wonder if the factory bushings aren't prone to wearing out. There was a mount on my Mazdaspeed 3 that I had to replace twice because the bushing in it wore out so badly.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 06-09-2014, 09:49 AM   #59
Mikepage
Mikepage's Avatar
The mazda, the engine is placed on the wrong side then more stress on the engine mounts... If you speak about engine mounts.
o= FR-S =o
Old 06-09-2014, 11:58 AM   #60
mid_life_crisis
I consider it more of a transmission mount. It was kind of a pork chop shaped thing that mounted to the back, not one of the ones over the wheels. Guys would upgrade the piece that connected to the car's frame but I never saw where anyone else replaced that piece. The bushing in mine wore out twice.
Old 07-21-2014, 05:40 PM   #61
johnnyfast11
Drives: none yet
http://www.ft86club.com/forums/showt...t=64364&page=3
regarding tye300's post above,
he installed the differential inserts after his rear brace.
he mentioned that he did not hear any noise with the rear brace and without the different inserts,
then when he installed the inserts he started hearing the noises.
I've installed the outrigger inserts and the diff bushings.
I am now hearing the "clunk" when i shift 1st and 2nd.
I do not care about the whine, i am just bothered by the "clunk"
I am wondering if i remove the diff inserts, but leave the rear outrigger in, will the "clunk" go away?
johnnyfast11 is offline   Reply With Quote
The Following User Says Thank You to johnnyfast11 For This Useful Post:
nickmerronesucks (06-01-2016)
Old 07-22-2014, 08:14 AM   #62
Mikepage
Mikepage's Avatar
Whiteline differential insert bushings review
Probable yes, but the clunk will not broke anything.
Maybe try it and let us know, and if that works, I will maybe do it also...
o= FR-S =o
Old 07-22-2014, 07:24 PM   #63
chutrain
chutrain's Avatar
Drives: WRB BRZ
I removed the diff inserts and they removed the sound. This is with leaving the outriggers in. I think I will try to put just the bottoms of the diff inserts in to slightly stiffen it up but leave a little isolation from diff and frame, in theory that is. Will report when I get a chance.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
The Following User Says Thank You to chutrain For This Useful Post:
Mikepage (07-22-2014)
Old 07-22-2014, 10:51 PM   #64
Mikepage
Mikepage's Avatar
Thank you for you feedback, it's appreciate!
o= FR-S =o
Old 07-23-2014, 08:32 AM   #65
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
I think the clunk happens because the diff transfers movement to the subframe itself with all the rigidity. The sound then is more perceptible because the subframe is connected to the cars chassis. It is unnerving at first, but you'll get used to it. LOL
Tye300 is offline   Reply With Quote
Old 07-23-2014, 09:22 AM   #66
Mikepage
Mikepage's Avatar
For me its also from the 2 to 3, its like this for you too? I think it's almost in all gears.
The sound come from the front, from the clutch engagement. I can avoid the sound if I really care when I shift and when I release the clutch pedal.
o= FR-S =o
Old 07-23-2014, 09:30 AM   #67
jvincent
jvincent's Avatar
Adding some data points to the thread, I have the diff bushing inserts installed as well and I get the clunk going into 2nd and 3rd as well unless I am super gentle on slipping the clutch.
I also have the rear sub-frame bushings.
Old 07-23-2014, 12:50 PM   #68
johnnyfast11
Drives: none yet
yes ive gotten used to it. I really like how the car drives now. like, I REALLY like how it drives.
yes. its in all gears. its the sound of clutch engaging. like 2 pieces of metal slapping eachother making a "clunck" sound. Im sure its always been there before. We just hear it now. In all cars, and when the metal plates engage there's ALWAYS this sound.
Im not worried about it anymore. its just "unnerving" haha
like everybody said. "cause race car"
Mikepage (07-23-2014)
Old 07-23-2014, 06:07 PM   #69
Mikepage
Mikepage's Avatar
Haha I like you comments!
Guy's don't worry about this anymore it's mechanic!
o= FR-S =o
The Following User Says Thank You to Mikepage For This Useful Post:
johnnyfast11 (07-23-2014)
Old 07-23-2014, 06:16 PM   #70
johnnyfast11
Drives: none yet
i'd actually be worried if there is no more "clunk" sound. if your clunk sound is gone that means your clutch is slipping at all times. lol
DIY - Whiteline Rear Crossmember Mount Insert Bushings F1point4 DIY (Do-It-Yourself) Guides 91 01-17-2021 02:23 AM
Whiteline crossmember bushing insert review Mikepage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 11-09-2016 03:30 PM
Rear Shifter/Transmission Mount Insert Bushings TheseColorsDontRun Mid-Atlantic 7 08-30-2013 10:29 AM
Whiteline diff bushings and trans mount insert. Simmons Transmission and Driveline 7 06-09-2013 08:45 PM
WhiteLine Positive Shift and Rear Subframe Bushings Review @ Pure Automotive Pure Automotive Mid-Atlantic 5 01-16-2013 05:15 PM
