Old 07-14-2014, 01:54 PM   #1989
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by dabocx View Post
Finally getting some 265s and going to try and head out to the track.
Whats everyone go to method for launching the manual? Im at 370whp with my e85 map so im hoping mid 12s
I didn't have launch control on my ROM when I went to the track with my 265 street tires. I just tried to keep the revs at between 2000 RPM and 3000 RPM and leave without getting wheel hop. I wasn't very successful though.
Old 07-15-2014, 12:34 AM   #1990
Boba_kz
Boba_kz is offline   Reply With Quote
The Following User Says Thank You to Boba_kz For This Useful Post:
ericvanderwoodsen (07-15-2014)
Old 07-15-2014, 01:53 AM   #1991
xwd
Originally Posted by mike the snake View Post
Got a chance today to do some final fine tuning on my car. I'm tuned with the Hydra standalone ECU with the Hydramist WMI system.
I am happy with the Hydra and Hydramist. My car runs great now, hauls the mail, and runs perfectly even when it's hot out, with the AC on.
Soon I'll be ramping things up. Presently I'm running with just wastegate spring at 10lbs.
If I were wanting to just stick with wastegate spring, what spring should I choose for more/max power on CA 91 and meth injection?
I'm thinking I could install the 14 pound spring and tune for that safely?
The Hydra can control a solenoid and do closed loop boost, I would just do that.
Old 07-22-2014, 07:17 PM   #1992
PolishFrs13
building life
PolishFrs13's Avatar
Drives: Raven Black, 6MT
Has anyone had a leak at the oil pressure area? from the black 90 degree black piece that contacts to the stainless steel oil line?
Sent from somewhere
PolishFrs13 is offline   Reply With Quote
Old 07-22-2014, 10:06 PM   #1993
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Sent from somewhere
Is it leaking from the pipe thread side or AN? If the pipe thread side then you need to use high temp sealant. If it is from the AN (cone shape) then you need to tighten it more.
FullBlown is offline   Reply With Quote
Old 07-22-2014, 10:20 PM   #1994
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by Dipstik-sportech View Post
Launch control @4000rpm and preload then ride the clutch out a bit to minimise spin
4500 might be a tad better since every time i hooked up on 4 grand it bogs haha
Old 07-22-2014, 10:27 PM   #1995
PolishFrs13
building life
It's leaking from the black 90 degree angle/line threading.. Name:  ImageUploadedByTapatalk1406082416.209110.jpg
Size:  129.5 KB this piece
Sent from somewhere
Old 07-22-2014, 10:48 PM   #1996
FullBlown
FullBlown's Avatar
Drives: Scion FRS
so its leaking out of the stainless end? If so, grab the 90 degree fitting with a wrench and tighten the hose end. It relies on compression to seal
Old 07-22-2014, 10:53 PM   #1997
Dipstik-sportech
Dipstik-sportech's Avatar
Mine spun like crazy at 4500
Old 07-22-2014, 10:55 PM   #1998
PolishFrs13
building life
Will do tomorrow morning. Thank you
Sent from somewhere
Old 07-26-2014, 09:18 PM   #1999
John Rambo
John Rambo's Avatar
Drives: Turbo BRZ Limited 6MT
Hey guys. So the other day I swapped out the full blown 270 pump that came with my kit for a deatschwerks 265, because I was having issues with hard starting and every time the car was idled for a while it would start to die. I saw someone else had a similar issue on the forum and they said their fuel pump was just bad. We both had an issue with the fuel pressure dropping off after a while.
The new pump fixed the hard starting and issue with the car dying at idle, but now I have a problem with starting on steep hills, and the issue is repeatable. Every time I try and start on a steep hill, the revs get so low and I can put my foot to the floor but the car doesnt want to go (stays at like 4-6 mph and makes some shuttering noises), and the last time I tried it I think I heard the engine knock The only way I can start off a hill is by dumping the clutch at past 2.5k revs, maybe even higher. Going up hills is fine when I'm already moving, the car is fine WOT as well, it's just actually starting. I can start fine on flat ground or when the car is going down a hill. I even tried backing up a steep hill and had the same problem. I never had to start off a steep hill when I was running the full blown pump so I'm not sure if it happened then too.
I also have issues when I cruise at a steady rpm and randomly the car jerks, although I think I had this one with the full blown pump too.
Any ideas? If it helps, the car is still running the base tune (and pretty rich by the looks of it). Going to get it tuned next week. Could it just be an issue with the throttle mapping or something?
John Rambo is offline   Reply With Quote
Old 07-27-2014, 12:17 AM   #2000
limitedblkwrx
Ultimate Member
limitedblkwrx's Avatar
Drives: 2014 Satin White BRZ
Sounds like the fuel pump pickup isn't sitting right in the gas tank, I would pull it out and make sure everything looks right.
limitedblkwrx is offline   Reply With Quote
Old 07-27-2014, 02:15 AM   #2001
John Rambo
John Rambo's Avatar
Hm. That's interesting - I used 3 o rings when I put it together and it all snapped in properly. I guess I could check one more time....
Old 07-27-2014, 02:42 AM   #2002
limitedblkwrx
Ultimate Member
Did you reuse the stock collar with the o-rings?
Looking at the below video and forum looks like that part can be an issue for many.
There may be air getting sucked up instead of fuel, because the o-rings aren't sitting right, which would make sense if your pump isn't full submerged in gas while on a hill. Hope this helps.
[ame="https://www.youtube.com/watch?v=GLTP7KxgjPs"]FA20CLUB FR-S BRZ Fuel Pump Install Guide - YouTube[/ame]
http://www.ft86club.com/forums/showthread.php?t=41770
The Following 2 Users Say Thank You to limitedblkwrx For This Useful Post:
Kerber23 (08-07-2017), ppbiggums (05-13-2015)
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
