Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
07-26-2014, 10:55 AM | #1 |
Drives: 16' WRX
Transmission fill and drain plugs
Does any one know the parts # for both the fill and drain bolts of the transmission? When I was swapping transmission fluid I accidentally stripped mine a bit so I want to get new ones. I know that the drain plug is magnetic but I'm assuming the fill plug isn't and is different. Where can I buy them?
07-26-2014, 12:21 PM | #2 |
Senior Addict
Drives: 86 GT
Here are the Subaru part numbers...
MT fill plug: 17007AA060 MT drain plug: 17007AA070 Gasket/washer: 17008AA050 (same for fill and drain) You're welcome |
The Following User Says Thank You to Fizz For This Useful Post: | ProjectD (07-27-2014) |
07-26-2014, 02:23 PM | #3 |
Drives: 16' WRX
07-26-2014, 02:33 PM | #4 |
Just a dude
Drives: Scion FR-S 2013
That or Subaru parts online..
07-27-2014, 12:26 AM | #5 |
07-27-2014, 12:37 AM | #6 |
Senior Addict
Drives: 86 GT
Good idea. But it depends if he actually stripped the threads or just the hex head part. If it was the threads I'd actually prefer proper thread sealant like permatex or loctite 507.
The Following User Says Thank You to Fizz For This Useful Post: | humfrz (07-27-2014) |
Similar Threads | ||||
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-04-2016 07:36 PM |
Factory Transmission Oil Fill - UOA | R2 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 04-14-2014 01:50 PM |
First fill-up... | mit_peid | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 01-20-2013 05:46 PM |
>>>Oil Change?<<< We have you covered. Oil --- Filters --- Drain Plugs | FT-86 SpeedFactory | Mechanical Maintenance and Tools | 7 | 11-14-2012 10:56 AM |
MT fill and drain washers | diirk | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 10 | 11-09-2012 12:24 AM |
