| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: car
Priming the oil filter
Hi doing an oil change today. Do I need to prime the oil filter or can I just put a little oil on the seat and screw it on?
| The Following User Says Thank You to radroach For This Useful Post: | ZionsWrath (07-25-2014) |
#2 |
Thanks
I just fill it with oil before I put it on. Very easy on this motor since oil filter is directly on top, won't even spill a drop.
Overall though I don't think it matters too much or manufacturers would specify to do it in the shop manuals.
| The Following User Says Thank You to ZionsWrath For This Useful Post: | gramicci101 (07-25-2014) |
#3 |
Drives: 13 Subaru BRZ, 02 Audi TTQ
Considering the filter location and position when installing all priming it will do is make a mess.
| The Following User Says Thank You to Scenic Driver For This Useful Post: | evan (07-25-2014) |
#4 |
Drives: fr-s
#5 | |
Thanks
#6 |
i always prime my filters. just fill it and let it soak up for a few mins. Youll be amazed on how much it can hold then quickly install. without spilling. it can be done. This is really important on turbo cars so the turbo bearings dont go starved for oil.
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
#7 |
Drives: car
Hi priming the filter worked. No mess! Yay.
I used about 5.5 quarts of synthetic total in the oil change, a little less than the 5.8 quarts subaru specifies. People are saying this is ok. OK? |
#8 |
Drives: 2013 Firestorm FRS
check your fluid level, only way to be sure.
There are a bunch of idiots on this forum(myself probably included lol) so don't just follow blindly, plus its super easy to check. |
#9 |
I always prime and wet the gasket, but never fill it up completely, maybe half. With motorcycles, some people have had issues where not enough oil pressure is generated because of a big air bubble stuck in the filter, and it either remedied itself after 10-20 sec of idle or a throttle blip, or it had to be burped, can't remember... May be apples and oranges, but I don't like the idea of leaving any potential for that.
#10 |
Drives: BRZ DGM Limited
if you fill the filter with oil and then turn it over to install, how can it not result in a mess?????
| The Following User Says Thank You to BRZnut For This Useful Post: | stugray (07-25-2014) |
#11 |
Drives: 2014 FR-S Whiteout
#12 |
Drives: fr-s
#13 |
Drives: car
| OEM Subaru engine air filter + cabin air filter | autobrz | Mechanical Maintenance and Tools | 6 | 03-09-2014 09:28 PM |
| FS: Oiled Panel Filter + AFe Oiled Filter & Kit | JPxM0Dz | Canada Classifieds | 0 | 01-27-2014 11:48 AM |
| Does anybody know exactly what filter the injen Sri uses? I want to get a new filter | Frsexxxy | Engine, Exhaust, Transmission | 13 | 02-19-2013 10:04 AM |
| WTB: TRD oil filter | 86_ZN6 | Engine, Exhaust, Bolt-Ons | 0 | 08-26-2012 12:50 AM |
| Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 02:40 PM |
