Koji_Online
Old 07-25-2014, 03:41 PM   #491
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
If you lower it to 2-3 mm above the brake pedal, that should still be fine, right? Did it by spinning the clevis.
I haven't heard any chatter yet, knock on wood. Cruise control engages/disengages like normal, car doesn't move in 1st gear with pedal to the floor and revs applied.
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 07-25-2014, 05:14 PM   #492
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
I've put ~5k miles on my lowered clutch (2-3mm above break pedal) and haven't had any issues. Any idea how quickly after doing this mod people were having issues?
If you're like me and only read the last page of long threads, be warned: This mod is incredible. You won't ever go back to stock
xxBrun0xx is offline   Reply With Quote
Old 07-26-2014, 01:05 AM   #493
Stealthy
Drives: 2014 WRB Bravo Romeo Zulu
Originally Posted by xxBrun0xx View Post
Now you just have to pull the return spring out and it'll actually feel like a real clutch!
Any tutorial /instructions for that? :p
Stealthy is offline   Reply With Quote
Old 07-26-2014, 01:45 AM   #494
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
http://www.ft86club.com/forums/showt...ghlight=helper
The Following User Says Thank You to unsurety For This Useful Post:
xxBrun0xx (07-26-2014)
Old 07-26-2014, 11:14 AM   #495
Synack
Boosted
Synack's Avatar
Drives: Sideways
Maybe 5-10k. Honestly if you don't feel that your clutch's engage point is getting lower and lower the more you drive, then you're probably OK. If you do feel it, then I'd raise it back up to stock.
If you've got whistling and chirping or spinning grinding noises it's time to replace it.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 07-26-2014, 05:53 PM   #496
TCGMark
TCGMark's Avatar
Drives: 2014 FR-S
I Just did this adjustment today. Amazing what a quarter turn does.
TCGMark is offline   Reply With Quote
Old 07-27-2014, 07:09 PM   #497
aristo
aristo's Avatar
Drives: BRZ SWP 14
Originally Posted by Synack View Post
You can actually see this at a certain angle when underneath the car (with engine running). I think I also saw it through the clutch fork boot. As long as your throwout bearing is disengaged 100% after this mod, you're good to go. I just put my pedal level back up to stock height because the turbo setup and aftermarket clutch and flywheel isn't helping my throwout bearing any lol.
Sorry to bug you chief but could you provide more detail about where to look for the throwout bearing spinning? Or maybe what it looks like specifically, or from what angle it needs to be viewed
Here is a picture of the under body to use for reference:
Going to lift my car just to see if mine is engaging or not because my clutch pedal is adjusted a little lower than brake
aristo is offline   Reply With Quote
Old 07-27-2014, 07:52 PM   #498
TCGMark
TCGMark's Avatar
Drives: 2014 FR-S
So, behind the aluminum panel under the engine, there is a plastic one that has the exhaust coming out of it. Remove that and you will expose the underside of the transmission. There are open "vents" on the bell housing that you can look in to see the clutch assembly.
The Following 3 Users Say Thank You to TCGMark For This Useful Post:
aristo (07-27-2014), Synack (07-28-2014), xxBrun0xx (07-27-2014)
Old 07-28-2014, 01:57 PM   #499
Synack
Boosted
Synack's Avatar
Drives: Sideways
Yes this exactly, sorry couldn't reply sooner.
There are actually a few things you can see inside of there including the clutch assembly and the throwout bearing if you can see it at the right angle.
If it's difficult to see or you aren't entirely sure what you are looking for, have a friend in the driver seat pushing the clutch pedal down and up repeatedly until you can see how the system works. The throwout bearing is attached to the clutch fork (inside the trans) which is the big black metal piece that the clutch master & slave is pushing back and forth (at the very top of the transmission) to disengage and engage the clutch.
The throwout looks like this, probably not the same colors though after thousands of miles of usage.
The Following User Says Thank You to Synack For This Useful Post:
aristo (07-28-2014)
Old 08-01-2014, 08:43 PM   #500
Shady195
Drives: '13 10 Series FRS #1203
Just did this.
My biggest issue with the clutch was that everytime I felt I had it perfect, its like my muscle memory decided LOL not anymore you dont and I would disengage is sloppily and sometimes slip it. I've never had this issue on any other of my standard vehicles.
I did the initial just below the brake pedal, and while I really thought the engagement made for a much smoother shift especially when heel-toeing, there was a slight "slop" for the first little bit that I did not like. While it did not affect how the car drove, everytime i put my foot on the pedal, or took it off the pedal i could feel this "slop" and it drove me nuts. Now I have it just in line with the brake pedal and im getting used to that.
Shady195 is offline   Reply With Quote
Old 08-05-2014, 07:47 PM   #501
benlaz88
Drives: 2013 Asphalt FRS
So, i just adjust my clutch pedal today and put it to the same position as my brake and its feel so much better. Pedal are lower and no need to push gas to roll forward and reverse. Didn't smell any burnt for 20 mile ride, shifting are good, and no grinding while shifting to all gears. Seem like there are no problem so far.
Is there any other things i should be noticing or be aware of while testing the adjustment?
benlaz88 is offline   Reply With Quote
Old 08-06-2014, 05:33 AM   #502
xxBrun0xx
xxBrun0xx's Avatar
If there is just a hair of free play at the bottom of the pedal, you should be OK. That being said, you'll notice your pedal has much less resistance to being pushed in now. Remove that helper spring attached to the clutch pedal and enjoy!
The Following User Says Thank You to xxBrun0xx For This Useful Post:
benlaz88 (08-06-2014)
Old 08-06-2014, 08:17 AM   #503
aristo
aristo's Avatar
Drives: BRZ SWP 14
DIY - Easy clutch grab adjustment (~10 mins)
Just to make sure - what exactly is free play?
When you mean free play at the bottom is it the gap before the clutch begins to slip and engage the gear?
Likewise what would free play at the top be? The travel that occurs before the clutch disengages?
Thanks
Old 08-06-2014, 12:11 PM   #504
xxBrun0xx
xxBrun0xx's Avatar
Thanks
Top freeplay = "Clutch Disengaged" section - in this section, the clutch plate is completely pressed against the flywheel with enough force to prevent any slippage, therefore the engine and tranny are spinning together
Bottom freeplay = "Clutch Engaged" section 0 in this section, the clutch plate is completely disconnected from the flywheel, so regardless of how much the clutch plate is forced to move, the engine is spinning independently from the transmission
Think of the freeplay as safeties. Those areas are put in to ensure that all clutch pedals can be set to the same height regardless of manufacturing tolerances on the clutch plate itself. By lowering the pedal, you're effectively removing some of that safety margin, which is okay, as long as you leave a little bit. You just don't have to leave as much as the stock car comes with.
Correct me if I'm wrong, but I believe that over time, due to the clutch wearing, the section between "clutch starts engaging" and "Clutch fully engaged" will move downward towards the floor, requiring you to adjust the pedal upwards as needed to maintain your "Clutch Engaged" safety region.
aristo (08-09-2014)
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
