Old 04-18-2012, 05:20 PM   #85
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by LSxJunkie View Post
What's the compression with the milled heads, what's the LSA on that cam, and what cam profile did you go with?
I didn't build it, so not 100% on specifics. The L92 heads were shaved to 64cc, supposedly 11:1 CR.
Cam was by PatG, 222/230 .597", lobe separation 114 I think...
We took it to the San Antonio drag strip when I was down to pick the car up , PO did a 11.69 @ 129.16mph
Neither of us is a drag racer, and the car is a daily-driver/HPDE compromise, so highish ET for the mph...
Old 04-18-2012, 06:00 PM   #86
serialk11r
Drives: '06 AM V8V Coupe
Yurp. Who needs more than one cam?
Really? :P
People are quick to criticize the torque delivery of small displacement Japanese engines, but if you look at that torque curve, it's not exactly what you'd call good. You are seeing 75% peak torque at 2000rpm on a 5000rpm peak, which is rather pathetic. A 2GR-FSE has almost 100% torque at 2000rpm with a similar peak. People are complaining about a ~10% dip in the midrange on the FA20, whereas that LS2 never even hits 90% peak torque until over 4000.
Old 04-18-2012, 06:38 PM   #87
ZDan
ZDan's Avatar
Drives: '23 BRZ
Very one-dimensional view there, serialk11r...
Flat torque curve isn't as important as making as much torque/power as you can, wherever you can make it, while maintaining streetability (in this engine's case, anyway). Would it be "better" if it simply plateu'd at 2000rpm? According to you, I guess it would be. For me, NOT.
Suffice it to say, there's plenty of oomph at all rpm...
Old 04-18-2012, 06:59 PM   #88
serialk11r
What I'm getting at is peak torque is making the most power at a given engine speed. Sure, flatter torque curve isn't better if it's overall less torque, obviously, but specific torque on the LS2 isn't any better than said Japanese motors, so the Japanese motors are making better specific torque most of the time, despite having the big rev range disadvantage. That's what "torque delivery" is right? It's not about "enough power" or not, it's how much of the engine's potential is being extracted across the rev range. The LS2 is obviously much more powerful than a F20C, but if the car's size is matched so the peak acceleration is the same, the F20C will feel more consistent than the LS2.
Not to diss the LS motors, it's very admirable that GM understands that cost effective >>> bragging rights (I think Japanese companies sometimes need to get their priorities straight, Honda S2000 would be a good example, they want to use a 2L engine to get huge amounts of power, and then they toss the only advantage a small displacement engine has out the window by giving it gearing unsuitable for the street), funny saying that about the company that is staying afloat on taxpayer money.
Old 04-18-2012, 08:12 PM   #89
EJ20
EJ20's Avatar
Drives: NA8C, GDB, and R50
EJ2x all the way
EJ20 is offline   Reply With Quote
Old 04-18-2012, 08:26 PM   #90
Dimman
Kuruma Otaku
Dimman's Avatar
What he's getting at is that displacement being equal a 4v head will rock a 2v head in torque output. Has to do with flow area (which is based on valve circ.) which requires less cam duration and pushes up the low and midrange. Plus add in tech like cam phasing which gives dynamic LSA control and it's no contest.
But GM is quick to point out that all that stuff is expensive and also bulky (ohv heads are surprisingly small).
Always the damn compromises...
Because titanium.
Old 04-18-2012, 09:00 PM   #91
ZDan
ZDan's Avatar
Drives: '23 BRZ
No reason it should be, of course. Smaller combustion chambers should have a specific torque advantage due to higher CR. But hey, this big-cylindered LS made 79 rwlb-ft/liter to the wheels!
(To be honest, I think the 517hp/473 lb-ft numbers are really closer to flywheel than actual rear-wheel)
First I've heard having a big rev range being a *disadvantage*! FWIW, the FR-S/BRZ's rev range advantage over my LS is only 200-400rpm, I'm limited to 7200 in 1st-3rd, 7000 in 4th-6th (as if it could get to 7000 in 6th!).
If you only have 2.0 liters, n/a, there's a much greater NEED to make near peak torque everywhere. It's no secret that multivalve cylinder heads have an advantage filling cylinders over a broader rpm range. You can get relatively more flow per engine size with less valve lift and overlap.
Well, now, *that's* no fun, now is it! That would be about a 6000 lb car, btw...
Don't get your point here, really. Don't really care what my LS2 feels like in a 6000 lb. monster. It feels pretty sweet in a car that weighs barely any more than the S2000
*ALL* cars are compromises, *ALL* engines are compromises. The LS happens to be a *brilliant* compromise. With DOHC and 4v/cyl, they could get closer to peak torque over a broader range. But that doesn't only add to cost, it would add significantly to size and weight and c.g. height. ALL BAD THINGS! Another way of looking at it: for the same V8 engine size and weight, you could have 4 liters with DOHC/32 valves, or 6+ liters cam-in-block/16 valves. The 4 liter might make closer to its peak torque over a broader range, and rev higher, but enough to make up for the displacement disadvantage? No...
I like it the way it is: uncompromised. Plus you get decent passing acceleration without downshifting
Anyway, I'm a HUGE fan of GM's approach with the LS engines, vs. Ford's monstrously huge, heavy, and high-c.g. V8s. When I get around to doing a Factory5 Daytona Coupe, it's definitely going to be with an OHV 347 stroker, noy a DOHC/32-valve mod motor.
Old 04-18-2012, 09:08 PM   #92
ZDan
ZDan's Avatar
Drives: '23 BRZ
Just saw this, but addressed it above I think...
EXACTLY. The 90's "ZL-1" learned them their lesson: A few more ponies for a LOT more weight in all the wrong places, for a lot more $$$, ain't worth it. There are better ways to making more power if you aren't displacement-limited.
I love it! It gives rise to a VARIETY of different approaches.
Like when F1 didn't suck and featured V8s vs. V10s vs. V12s. They all had their strengths and their weaknesses.
Old 04-18-2012, 09:11 PM   #93
serialk11r
You think 2 liters is not a compromise ZDan?
The only reason they made the F20C 2L was because Japan has displacement tax. If they wanted no compromise they would've given it a bigger bore from the start. Don't get me wrong, the S2000 is awesome, but it's definitely got a bit of a conflict in design philosophy. It's like a racecar on one hand with extremely short gears, fantastic performance, on the other hand it's massively handicapped by a displacement chosen for tax reasons. No replacement for displacement is sadly true.
Rev range is a disadvantage for torque delivery, but not power, of course. The bigger the difference in engine speeds that you have to run at, the harder it is to optimize things.
And no duh, the LS2 will feel great despite less than ideal torque characteristics because it's just got SO much power, and knowing how compact and light the engine is for its size, that's definitely something to brag about. Personally I think a street performance engine shouldn't go the brute force high displacement method, but it has very strong merits for sure.
My personal engineering perspective preferences are ~8500-9000 rpm, light boost, low displacement, and moar gears in any transmission that lets me control the clutch. SCed 2ZZ with slightly tightened up 1-6 gears and a quiet and extremely efficient 7th
Old 04-18-2012, 09:13 PM   #94
Dimman
Kuruma Otaku
Dimman's Avatar
32v ohv SBC??? Could they fit in 16 more pushrods? Or split the rocker arms to push 2 valves? Someone somewhere must have tried this...
Super compact large displacement with better filling, cam phasing be damned.
Because titanium.
Old 04-18-2012, 09:19 PM   #95
ZDan
ZDan's Avatar
Drives: '23 BRZ
What gave you that idea, was it where I said:
"*ALL* cars are compromises, *ALL* engines are compromises."
No, they would have done the 2.5 liter I-5!
I think it's the best sports car on the market since the 240Z. 240hp isn't much of a compromise for a street car if you ask me.
Old 04-18-2012, 09:22 PM   #96
serialk11r
Okay, or an I5. But really, strictly speaking if you can enjoy the full power output of an LS2 then a displacement bump on an F20C should be very welcome, not saying that it's necessary of course.
Old 04-18-2012, 09:41 PM   #97
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Yep.
[u2b]vRKTRLD2h8k[/u2b]
old greg is offline   Reply With Quote
Old 04-18-2012, 10:37 PM   #98
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by old greg View Post
Yep.
Now only if they weren't $7500-8500...
Because titanium.
Engine Swap ... Macavely Engine Swaps 220 07-25-2012 03:58 AM
Engine swap question koyv90 Engine, Exhaust, Transmission 4 03-22-2012 01:08 PM
4U-GSE: the new engine swap for old Toyotas no_name Engine Swaps 17 12-19-2011 09:50 PM
engine swap thread aspera Engine Swaps 231 03-15-2011 05:10 PM
YOU MUST CHOOSE # 2 Calais Other Vehicles & General Automotive Discussions 16 07-22-2010 12:30 AM
