Old 07-23-2014, 01:23 AM   #15
kanundrum
Drives: 2013 Whiteout FR-S
Originally Posted by discretion View Post
What time is the meet? I work 11 to 7 on Wednesdays
07/09/2014
07/23/2014
08/06/2014
The location for the next is posted in a semi-professional way below!*
Meet location: Revolution Bar and Restuarant. (Formerly known as Fast Eddies)
Address: 9687 Fairfax Boulevard, Fairfax, VA 22030.
Time: 7:00PM
We usually get there a little before 7 traffic dependent and walk in weather dependent.
Old 07-23-2014, 01:25 AM   #16
kanundrum
Ask for Marcus Ahmed or Matt or pretty much anyone over there that should be able to help you out with a quick run thru of the car
The Following User Says Thank You to kanundrum For This Useful Post:
IloveBaldEagles (07-23-2014)
Old 07-23-2014, 01:38 AM   #17
IloveBaldEagles
IloveBaldEagles's Avatar
Drives: Gray.
Marcus here. I look forward to meeting you on Wednesday! (?today)
I am very insecure. I have no friends. I want people to love me
Old 07-23-2014, 02:40 AM   #18
limitedblkwrx
Ultimate Member
limitedblkwrx's Avatar
Drives: 2014 Satin White BRZ
I still need to come out to one of these meets, But I have class on Wednesdays
Maybe I'll just skip a day
07/09/2014
07/23/2014
08/06/2014
Time: 7:00PM
limitedblkwrx is offline   Reply With Quote
Old 07-23-2014, 08:51 AM   #19
A6M Zero
A6M Zero's Avatar
Drives: 2013 Asphalt FR-S (DD), 05 EVO V///
Basically just check for leaks, rust, make sure suspension components are in tact. Compression/leak down test if you're up for it. I have a compression tester I can lend if needed.
A6M Zero is offline   Reply With Quote
Old 07-24-2014, 02:32 AM   #20
discretion
Drives: Scion FR-S in Whiteout
Ah I woulda been there but had work till late. Next one for sure.
discretion is offline   Reply With Quote
The Following User Says Thank You to discretion For This Useful Post:
IloveBaldEagles (07-24-2014)
Old 07-24-2014, 03:48 PM   #21
IloveBaldEagles
Drives: Gray.
Always man. Look forward to meeting you!
Any good stereo installers in NY area that have worked on the frs? mikeg7827 NY / NJ / CT / PA 18 09-09-2013 11:07 PM
KEG LYPH MAFYA Flip Key - WORKED Lverasky Cosmetic Modification (Interior/Exterior/Lighting) 20 09-05-2013 06:53 AM
Car wouldn't start, and then nothing changed and it worked fine...wtf Spicer66 Issues | Warranty | Recalls / TSB 10 12-22-2012 11:25 AM
Track Video: BRZ Passes worked Miata, unable to be passed by prepped s2000 gmookher FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 11-06-2012 02:01 PM
