Old 07-24-2014, 04:11 AM   #1821
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by Model Citizen View Post
Hmmm, good info sir, thanks. I have been tempted to get a spare oem beader for gutting, may have to actually track one down now.
Oem design isnt bad and would prefer to maintain the oem heat sheilding.
Exactly, my thoughts that's the reason why I didn't want to get an aftermarket one
glamcem is offline   Reply With Quote
Old 07-24-2014, 05:39 AM   #1822
CSG Mike
CSG Mike's Avatar
Originally Posted by glamcem View Post
OEM header failed on me after the 5th event because of the cats having a freer flowing catless or gutted OEM header makes sense I think
The cats shouldn't be failing on you, even with track time. Our setup has more than 5 track days on it, and it's still there.
We'd actually be pretty upset if we destroyed our OEM cats, cuz we need to smog at some point...
It really hurts that you don't have logs, because the logs can probably point you in the direction of what caused the failure.
Old 07-24-2014, 10:59 AM   #1823
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
You recently mentioned destroying an OEM cat on an OEM tune. That failure shouldn't have happened either, obviously. What was the cause?
Sellout is offline   Reply With Quote
Old 07-24-2014, 02:19 PM   #1824
CSG Mike
CSG Mike's Avatar
Leaning out and EGT being too high; the two go hand in hand.
Old 07-24-2014, 02:58 PM   #1825
glamcem
glamcem's Avatar
cats didn't fail on me but it might be the root cause of the failure of the header.. it may also be a defective unit according to my tuner but since you previously mentioned you saw a few OEM failures at the track I think it's common. I have been logging but coincidentally I didn't log that day
Old 07-24-2014, 03:05 PM   #1826
Model Citizen
Lacking brains
Drives: frz
Whats the reccomended logs in this situation?
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 07-24-2014, 04:01 PM   #1827
CSG Mike
CSG Mike's Avatar
Ignition timing, injector duty cycle, and cat1 temperature, all of which is available via OBD2
Old 07-24-2014, 08:18 PM   #1828
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Originally Posted by j.F.c.R.a.S View Post
well I almost got through the install, until i realized I was missing the charge pipe for the hot side of the kit. Pretty bummed, and I have yet to hear from the dealer or kraftwerks on getting me the piece. I have no car until then.
Please check both your PMs here and Instagram Account.
KraftWerks is offline   Reply With Quote
Old 07-24-2014, 08:29 PM   #1829
Sellout
Mr. Cranky Pants
Sellout's Avatar
Oh the cat failed due to the DI seal failure. Got it.
Kinda forgot that even happened...
Old 07-25-2014, 09:20 AM   #1830
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Any other owners out there in San Diego?
nlowell is offline   Reply With Quote
Old 07-25-2014, 10:39 PM   #1831
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Question to every owner... using torque, does your catalyst show incomplete/not ready or ready.
I need to get a tune that shows ready or I can't pass inspection.
post_break is offline   Reply With Quote
Old 07-26-2014, 02:05 AM   #1832
D-VO
Drives: Whiteout FR-S, Evo 8 RS
What happens if you flash it back to stock?
D-VO is offline   Reply With Quote
Old 07-26-2014, 10:53 AM   #1833
Model Citizen
Lacking brains
Drives: frz
what tune are you using?
The kit tunes should be fine from the information that was relayed to me.
If you're using delicious paid tune contact zach or bill and they'll sort you out. Apparently they leave the cat and evap off typically since in most states that works out fine. Can't comment on any other tuners.
I contacted both kw and zach about the same matter this week (i have kit tune and paid delicious), both responded to me with solutions in a very short timespan. A+ service for everyone.
Been driving the last few days on the new in house kw tune, its a big improvement over the original delicious kit tune. Not sure what I like better between the paid delicious and in house kw though. With just street driving its hard to make a real comparison.
Old 07-26-2014, 11:31 AM   #1834
post_break
post_break's Avatar
Looking at the visconti tune it only shows O2 as not ready, and I should pass. I think with the delicious tune I had 2 not ready and would fail. I emailed bill but I don't think I'll get the tune in time. Going to get it inspected today.
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
