Old 04-18-2012, 11:09 AM   #29
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Godzpeed View Post
I'm sure STI engineers would put stuff that "doesn't work" on their cars.....
seriously, how much on hand experience did you have with aftermarket and retro fitting braking systems??
I've seen concept cars with calipers that didn't even have pads, lines, etc hooked up so I'm not sure how that's evidence of it being the best idea ever.
Again, doesn't work PROPERLY and it not being IDEAL compared to thought out upgrades (assuming it's even needed, I highly doubt I'll find a need for a BBK for the car under track use).
You could do the opposite and get rear calipers from a base 1988 Civic to work also, but just like current STI brakes that wouldn't be ideal either.
If you just want them for looks then by all means install them. No one here really cares but let's keep factual information alive and not just say "they are so much better than stock" when the evidence doesn't support that.
You could make them work correctly, retap them like Greddy may have done (assuming those are even STI calipers, I'm not convinced of that myself) and get 04 STi rotors for the front, the rear is a little more complicated and you'd want to address the rear if you want properly functioning brakes.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-18-2012, 02:21 PM   #30
Turbowned
Turbowned's Avatar
I'll wait to see if GReddy has anything to say - Still not gonna put 'em on my car. Next discussion: Porsche Cayenne brakes - will they fit the BRZ?
I actually have a set of these in my garage. Absolutely ridiculously huge! I'm hoping to find someone with an Audi who wants to try bolting them up under 19" wheels. Have fun with that!
Old 04-18-2012, 02:44 PM   #31
nibor33
nibor33's Avatar
Drives: SSM BRZ-L 6MT (gone)
Originally Posted by Turbowned View Post
I find it rather silly that Porsche and others still use cross-drilled rotors these days. A drilled/slotted rotor may weigh less, but there is also less rotor surface for the pad to bite down on. Since most pad compounds don't produce the gases they used to, it is my understanding that drilled/slotted rotors are functioning strictly for looks because the holes aren't needed to dissipate gases. The worst part is that when you replace pads, you can't machine the rotors on a lathe so they usually have to be replaced, too.
I was under the impression that Porsche was still supplying rotors cast with the holes in place, i.e. not cross-drilling. This would negate many of the drawbacks of cross-drilling. There is a minimal decrease in swept area, and the theory goes that it aids in dissipating the layer of gas that can get trapped between pad and rotor.
Anyway, surprised that an Audi salesman would criticize Porsche and claim that their rotors are crap... you can call Porsche overpriced, but they certainly are well engineered. Call me a fanboy if you wish.
Am I wrong about the Porsche rotors?
nibor33 is offline   Reply With Quote
Old 04-18-2012, 03:10 PM   #32
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Porsche Rotors are cast with holes in them. For many years however they uses blanks on race cars, not swiss cheese rotors. Now they are using dimpled ones and some with cast holes but unless it's changed recently the endurance racing P-cars use blanks. I haven't checked for a few years though, JRitt and some others probably know.
Rotors cast with holes do avoid some negatives, but the holes are still stress risers and they still remove mass.
The gas thing is true, if you find some new old stock race pads from the 50s. Modern pads simply don't outgas like the old pads do.
Generally speaking rotors with holes are for looks. For street use they will function the same, but many have had 911 GT3 and similar rotors crack to hell from the holes after one DE weekend. A lot of the Porsches I see at events are using j-hook slotted or blanks. Very few are running OEM/OEM style rotors, at least around here.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-18-2012, 03:31 PM   #33
Dimman
Kuruma Otaku
Dimman's Avatar
With regards to concept/demo cars having stuff. The early 'glass' BRZ concepts had the calipers on opposite sides, so take what you see with a grain of salt...
Because titanium.
Old 04-18-2012, 04:46 PM   #34
OrbitalEllipses
Drives: Attitude
*shakes head* Yes, it was, as I am trying to get to the truth. Is it necessary for you to get your panties in a bunch every time someone asks a question or makes a small error? Probably not. Please don't make this like the "Do a search n00b WTF amirite" Honduh forums. Moto-IQ is one of the few sources out there that takes the time to look into all the gritty technical details of cars, and includes the best and brightest in the industry, so I tend to trust them; You just let me know when you know more about cars then they do.
I know more about the car where the brakes came from than they do and I've repeated why it won't work properly a hundred times. If you could fucking visualize this differential bored caliper in three-dimensional space you'd have understood that ages ago rather than spamming your nonsense over and over about STI brakes, motoIQ this, Import Tuner that, GReddy this.
Old 04-18-2012, 04:59 PM   #35
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Relax.. step back from the ledge..
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-18-2012, 07:00 PM   #36
Turbowned
Turbowned's Avatar
Old 04-18-2012, 10:06 PM   #37
OrbitalEllipses
Drives: Attitude
Where's the :crazy: smiley? I think exams might break me.
If you could see your ignorance the way I do, you'd be mad too.
Old 04-19-2012, 01:14 AM   #38
Godzpeed
Drives: Nissan GTR
We've put on a 996 C4S front 4pot caliper on a Toyota Echo before...
Nothing can't be done!
and AFAIK, only the ceramic rotors crack after a few track days. I've taken my old 997 GT3 RS a few times to the track with the ceramic, and never had a crack. I've yet to take my RS 4.0 to the track. Most owners are recommending me to switch to steel rotors before I track my RS 4.0. But I don't drive as hard as some of the drivers, so I guess I couldn't have gotten it to crack yet.
Godzpeed is offline   Reply With Quote
Old 04-19-2012, 11:10 AM   #39
Turbowned
Turbowned's Avatar
Well then OrbitalEllipses, I think it might be in your best interest to create a sticky for all future inquiries, so that you don't have to give out 1,000 enraged replies when people inevitably ask if it can be done. It will benefit the community and keep your blood pressure lower! Perhaps include a cut-away diagram of a differential-bored caliper so us less-geometrically-inclined can visualize it, and stop calling us all ignorant. Win-win? I think so.
Old 04-27-2012, 04:46 PM   #40
Turbowned
Turbowned's Avatar
Well, this might be all the proof we need that they don't work right; WTF is up with those rotors?
Old 04-27-2012, 05:01 PM   #41
Racecomp Engineering
Holy carp! THAT is not a good look.
- drew
Old 04-27-2012, 05:02 PM   #42
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Backing plates of the pads grinding through the rotors.
Those don't appear to be differential bore calipers.. ie not STI calipers.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 02:06 PM
