Old 07-23-2014, 04:31 AM   #1135
DC2R
Drives: 2014 Scion FR-S
Originally Posted by 86•BRZ View Post
Wait what? How do I disable car home? I applied the new update. It wasn't disabled?
Ta
Was sent to me by another member....May still have link around here somewhere.....
Sent from my GT-N5110 using Tapatalk
DC2R is offline   Reply With Quote
Old 07-23-2014, 05:23 AM   #1136
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Cheers. Please let me know!
86•BRZ is offline   Reply With Quote
Old 07-23-2014, 06:27 AM   #1137
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Just rooted mine successfully. And have google contacts syncing correctly so that I can use a dialler and not rely on the horrible and flakey bluetooth syncing.
There was a google doc with links and how tos posted earlier. I'll update, post and link to that later.
Old 07-23-2014, 09:51 AM   #1138
SPT Legacy
Drives: 2014 Lightning Red BRZ
Originally Posted by phanguy View Post
like i said with the ipod harness yeah it could be. the wires themselves i'm sure are probably fine, but if they are in the wrong position then that could be causing screwiness.
So would it be as easy as just pulling the pin from the harness and swapping it with the correct one?
SPT Legacy is offline   Reply With Quote
Old 07-23-2014, 11:05 AM   #1139
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
If that's indeed the problem, yes.
SilverlightPony is offline   Reply With Quote
Old 07-23-2014, 11:29 AM   #1140
SPT Legacy
Good, don't want to cut all of those wires if I don't have to lol.
Old 07-23-2014, 11:42 AM   #1141
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
yeah you definitely shouldn't need to cut anything. like a few others i reused the steering wheel control pin to pin for my amp instead since we don't have swc. just grab pliers and push it out of there. it's scary, but not too bad. just find your pinouts so you can check all of your wires.
phanguy is offline   Reply With Quote
Old 07-23-2014, 12:15 PM   #1142
mackdaddytran
mackdaddytran's Avatar
Drives: Toyota Skyline Type-R
For an extra $40 or 50, you can get a combination Wi-Fi/Cellular dongle instead of the normal Wi-Fi only dongle, that will allow the unit to connect directly to a cellular network for data access (you'll still need to sign up for service on that dongle, though). Otherwise, it needs a mobile Wi-Fi hotspot of some sort (either a dedicated mobile hotspot or a phone running in hotspot mode).
thanks!
mackdaddytran is offline   Reply With Quote
Old 07-23-2014, 06:45 PM   #1143
Onelifeliveit
Drives: Toyota 86 GTS
I did a search on this thread and all that came up was to change th sync adapter??
Anyway I would appreciate if you post a how to...I am sick of the stock bluetooth app
Onelifeliveit is offline   Reply With Quote
Old 07-23-2014, 06:47 PM   #1144
Onelifeliveit
For all those who have horrible bluetooth connections - I disabled GPS and it seems to have fixed the problem. Still early days but the couple of calls I've had since have been trouble free.
Old 07-24-2014, 03:12 AM   #1145
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
yep i just added the GoogleContactsSyncAdapter.apk to the /system/app directory, then it just work, i had rooted it first. the link to it was somewhere buried deep in this thread, if you can't find it then PM me and i can email it to you!
I just need to figure out how to remove the std launcher screen and all will be well with it.
Old 07-24-2014, 08:08 PM   #1146
SPT Legacy
Yeah it looks like the front right speakers are in the wrong spot..
Strange though that since the FR-S and BRZ wiring is the same, why did the harness that came with it not work?
Old 07-24-2014, 08:11 PM   #1147
SilverlightPony
Accidentally miswired at the factory, maybe? It happens sometimes.
Old 07-24-2014, 09:56 PM   #1148
SPT Legacy
Only lemon...haha.
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 07:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 04:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 05:58 AM
