#15 |
Glorious BRZ Master Race
Drives: Subaru Libird
Here's my method to torque the rear top nut to OEM spec (18.4 lb-ft). Used a crow's foot socket on my torque wrench (easiest to position at 90 degrees according to http://www.motorcraftservice.com/ren...la_main_en.asp) which torqued the pass-through extension attached to the 14mm pass-through socket which attaches to the top nut (supposed to be where my finger is), and extra long hex bit to hold the rod. All tools were *in stock* at Harbor Freight for reasonably cheap.
| The Following 2 Users Say Thank You to switchlanez For This Useful Post: | Createddeleted (07-20-2014), ThatManAnt (08-03-2014) |
#16 |
Señor Member
Drives: 2013 Raven, Drifty things
Any clunks? My front and rear are both impacted on but I still occasionally have a clunk...Probably going to raise mine up, I'm sitting about where you are ride height wise. Feels pretty rough to me, idk if I'm too low or something but it feels like I have no absorption lol.
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris '13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross. |
| The Following User Says Thank You to 6-Shift For This Useful Post: | newports (07-23-2014) |
#17 | |
Drives: 2013 Scion FRS
Also will 17x9 wheels not make the wheels sunk in if the coilovers do make it like so? |
#18 | |
Señor Member
TL;DR: just set the coils out of the box to where you have shock travel left even with the helper spring compressed and work up from there until you're happy. As far as the wheels, depends on offset.
#19 |
Señor Member
@newports here's a better picture (from last night actually) of how my car sits right now:
![]() ![]() Edit: camber info: front is -1 both sides rear is -2.3 both sides (stock RLCAs)
#20 | |
Most of the wheels I want are either +35 or +38 offset. |
#21 |
Señor Member
+35's should fit pretty well. You won't be hellaflush by any means but it'll look really good. Friend of mine has some 18x8 +35's and they look awesome on his lowered FR-S.
#22 | |
As long as the wheels are not sticking out it's all good. I would rather be it sunken in because you can fix those with spacers at least. |
| RS-R* Sports i Coilovers installed!!! | eddieEndo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 12-10-2014 12:25 AM |
| installed BC Racing coilovers =D | carlitosway6891 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 43 | 10-13-2014 08:53 PM |
| BC Racing coilovers installed | KAB-FRS | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 33 | 06-07-2014 12:11 AM |
| KW V3 Coilovers Brand New in box never installed | deedz | Brakes, Suspension, Chassis | 14 | 06-06-2013 02:03 AM |
| BC Coilovers, installed today | Jesse | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 12-16-2012 11:07 PM |
