Old 07-21-2014, 03:40 PM   #1
MrTranxD
MrTranxD's Avatar
Drives: Scion FR-S
Mixing Coolants
Everyone always says to use only the blue OEM Subaru coolant, but noone ever explained why. Well in the auto tech class I'm taking, I was informed that the blue coolant will turn into a jelloy type substance when mixed with other coolants. I can confirm that this is true because when I went to look at my car, which I topped off with some random other fluid, there was a bunch of jelly type thing at the spout of the radiator cap. Just explaining why everyone is so worried about the coolant thing! If you did mix coolants, I think its best to go and do a flush and refill.
2013 Ultramarine FR-S 6MT
MrTranxD is offline   Reply With Quote
The Following 3 Users Say Thank You to MrTranxD For This Useful Post:
Celadrielas (07-21-2014), daftpunk (07-27-2014), jcw99 (07-27-2014)
Old 07-21-2014, 05:29 PM   #2
v12
v12's Avatar
Drives: none =[[
And after flushing you can fill up with different coolant right?
v12 is offline   Reply With Quote
Old 07-21-2014, 05:46 PM   #3
Lawn_Mower
Lawn_Mower's Avatar
Drives: GTI, BRZ
If you mix coolant it will turn in to a nasty mud/jelly substance and clog the cooling system. Bad news. Don't do it.
Lawn_Mower is offline   Reply With Quote
Old 07-22-2014, 03:59 AM   #4
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
The manual states that the factory fill is good for 11 years or 130k miles or something. if you use other coolant, it shortens the life to like 75k miles or something. That's their reason to not mix coolant. But good to know about the the jelly thing.
N1rve
Old 07-22-2014, 04:43 PM   #5
MrTranxD
MrTranxD's Avatar
Drives: Scion FR-S
Well the only reason someone would mix coolant is to top it off. It seems that I wasn't the only one that had to top off the fluid.
Old 07-22-2014, 04:51 PM   #6
s2d4
s2d4's Avatar
You didn't listen until you saw jelly?
The Following User Says Thank You to s2d4 For This Useful Post:
nivek111070 (07-27-2014)
Old 07-22-2014, 05:07 PM   #7
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Topping off with distilled water was the preferred route I always thought.
Cheap too.
Old 07-22-2014, 10:59 PM   #8
N1rve
N1rve's Avatar
I was about to top off with another fluid until I read in my manual that mixing coolant decreases its life. spent 25 dollars on a bottle of 50/50 premix subaru coolant for the next topping off of 11 years lol
N1rve
Old 07-23-2014, 01:28 AM   #9
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
I have heard distilled water, something wetter and a cup of coolant keeps the engine cooler..
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 07-23-2014, 07:06 AM   #10
N1rve
N1rve's Avatar
Technically a 50/50 mix is best at keeping the engine cool and I think it was like 70/30 for places with actual winters. Straight antifreeze is not good for the car, I have heard of topping off coolant with distilled water is good because the evaporation is usually the water in the coolant. I've never tested out the theory if the evaporation is coolant (antifreeze and water) or just water, but I guess you would find out by testing the concentration if you extracted all of it
N1rve
Old 07-23-2014, 07:18 AM   #11
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
What about swapping the water for something like "Evans Coolant"? http://www.evanscooling.com/
They claim the engine will run allot cooler. Anyone ever use this?
Lunatic is offline   Reply With Quote
Old 07-23-2014, 07:59 AM   #12
Die$eL
Die$eL's Avatar
Drives: Toyota MR2 Spyder Turbo
As far as i know the thermostat controls the cooling.
If the temp gets too low the thermostat closes, preventing coolant from circulating around the engine.
When it gets hot enough the thermostat opens and it starts circulating again.
So, i ddoubt changing to a different type of coolant will change anything
Edit: I see you suggested changing from water to a coolant. my bad...
Die$eL is offline   Reply With Quote
Old 07-23-2014, 07:20 PM   #13
ka-t_240
Different coolant makes a difference; how big, I am not 100% sure. Running straight water your car will run cooler than straight coolant or even 50/50. In on of my old 05 STi, I was on track and the coolant started boiling when i came off. I checked everything out, flushed coolant and the problem went away the next track day. I figure the coolant was still the original fill, I filled it 60% water 40% coolant.
Your Thermostat does control the lowest temp that your car will run(after it warms up), that is why people will install lower temp thermostats. However, the thermostat temp is often 30-40 degree lower than the operating temp. Running a different fluid could make the car run at 200 vs 210 degrees.
ka-t_240 is offline   Reply With Quote
The Following User Says Thank You to ka-t_240 For This Useful Post:
strat61caster (07-23-2014)
Old 07-26-2014, 01:56 PM   #14
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Interesting, together with Mishimoto Race Thermostat it should have a good result.
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Mixing Oil Brands? 10Tim Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 06-02-2014 11:36 AM
Mixing Transmission Fluids? l0aded Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 06-27-2013 01:45 PM
What is it that makes people mixing up the GT86 with a Supra Killerbee Scion FR-S / Toyota 86 GT86 General Forum 31 12-20-2012 02:24 PM
