Old 07-22-2014, 04:04 PM   #1121
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
Originally Posted by SPT Legacy View Post
It'd be my luck to get the only lemon too. lol..
you could try asking support for a pinout of the harness to see what should go where and compare it with what you have. because maybe your wires got swapped somehow?
phanguy is offline   Reply With Quote
Old 07-22-2014, 04:50 PM   #1122
mackdaddytran
mackdaddytran's Avatar
Drives: Toyota Skyline Type-R
How does this get navigation and internet to run pandora? Does this unit have to be tethered to your cell phone?
mackdaddytran is offline   Reply With Quote
Old 07-22-2014, 05:18 PM   #1123
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
For an extra $40 or 50, you can get a combination Wi-Fi/Cellular dongle instead of the normal Wi-Fi only dongle, that will allow the unit to connect directly to a cellular network for data access (you'll still need to sign up for service on that dongle, though). Otherwise, it needs a mobile Wi-Fi hotspot of some sort (either a dedicated mobile hotspot or a phone running in hotspot mode).
SilverlightPony is offline   Reply With Quote
The Following User Says Thank You to SilverlightPony For This Useful Post:
mackdaddytran (07-23-2014)
Old 07-22-2014, 06:03 PM   #1124
SPT Legacy
Drives: 2014 Lightning Red BRZ
I asked them and they said everything should be normal. It should've been a plug and play setup.
SPT Legacy is offline   Reply With Quote
Old 07-22-2014, 06:20 PM   #1125
phanguy
phanguy's Avatar
well should have been, yes, but if somehow when your harness got made and the wires got swapped... i think i read somewhere in this thread that something similar happened with the harness and they(the company) had to send out an e-mail to all the people that bought it explaining to swap the wires. i think it was related to the ipod connector. so maybe a mistake was still made?
if you swap your stock stereo back then at least for sure you can eliminate the speakers and car harness from the equation right? and while you have it out then you could check the ca-fi harness. compare the pinout with what the pinout of the cars harness is supposed to be to make sure that left and right match up correctly. it's a lot of work, but it's better(to me) than waiting for a solution to pop up.
Old 07-22-2014, 06:22 PM   #1126
SPT Legacy
Also I'm reading the BRZ has a different wiring than the FR-S...might be why it's messed up, I got the wrong wiring harness...
Old 07-22-2014, 08:24 PM   #1127
SilverlightPony
The Dashlinq4 "Toyota Universal" model comes with the same parts no matter which car you have; I hooked it up in my BRZ no problems (well, no wiring problems).
The HU should have a pinout for the main connector on the top of the HU itself--one diagram with the pins shown in the actual layout and numbered, and then a chart with descriptions by those numbers.
Old 07-22-2014, 08:37 PM   #1128
SPT Legacy
Then could the harness be messed up while being made?
Old 07-22-2014, 09:42 PM   #1129
phanguy
phanguy's Avatar
like i said with the ipod harness yeah it could be. the wires themselves i'm sure are probably fine, but if they are in the wrong position then that could be causing screwiness.
Originally Posted by Deathalo View Post
Wait, what do you mean when using poweramp? I have poweramp installed (but the volume control is disabled so Viper can power the audio). I also have tasker installed, but how would I fix that other than set the volume at a different level everytime the car turns on. This issue is less of what level it goes to, and more that I want it to go back to whatever it was last set at.
i just tested mine and my volume didn't change from where it last was. i had it around 10/11 though. i didn't try it at a higher setting.
Old 07-22-2014, 10:09 PM   #1130
SilverlightPony
Yeah, if it's lower, it stays there. If it's higher than 14, it gets kicked back down to 14 when it goes to sleep/wakes up.
DC2R (07-23-2014)
Old 07-22-2014, 11:15 PM   #1131
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Worked. thanks!
now if we can get the insufficient space thing worked out then i can try installing tablet talk again...
Did you delete the apk files in the downloads folder?
Prog is offline   Reply With Quote
Old 07-23-2014, 01:33 AM   #1132
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
So who's rooted it and enjoying the benefits from it?
It was briefly discussed on page 13...
Couple of questions ..
If I root it then mess it up can I just use the sd update folder method to put it all back to normal?
Can the launcher be disabled so it can just start in the android app select screen?
86•BRZ is offline   Reply With Quote
Old 07-23-2014, 03:14 AM   #1133
DC2R
Drives: 2014 Scion FR-S
From all I've seen unless you mess with recovery partition you should be good by just hitting reset button with update on sd in case of a meltdown.
They did send out the latest update with CarHome disable. I rather enjoy it.
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 07-23-2014, 03:15 AM   #1134
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Wait what? How do I disable car home? I applied the new update. It wasn't disabled?
Ta
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
