Old 07-21-2014, 12:42 PM   #1107
DC2R
Drives: 2014 Scion FR-S
Damn lazy troubleshooting in my off time. Figured out issue with Pandora skipping. Only happens when tethered to phone. Tried on two separate note 3 touchwiz 4.4 ROMs. Tried turning off add blocking on phone but not sure where else to go....
As far as limited system storage will has told new they are working on it but I think we should all ask for it. I'm good with just a gig or two partitioned for internal sdcard.
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 07-21-2014, 01:06 PM   #1108
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
Originally Posted by bwthor View Post
Yeah, that hiss is driving me crazy. Open up a music player, and turn the volume up. Hit pause, and the hiss is there for a couple seconds, then silence. Hit play and it starts back up again.
Like you said, it is there for any program that uses the audio.
yeah. changing the poweramp settings made a very big difference at least.
phanguy is offline   Reply With Quote
Old 07-21-2014, 05:34 PM   #1109
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Anyone know how to prevent an app auto launching via usb insert? This means dashcommand opens every start or at least asks the question because the usb is re-detected on wake. Is there no way to select no and have the system remember?
I can only choose yes or cancel to the following..
86•BRZ is offline   Reply With Quote
Old 07-21-2014, 05:54 PM   #1110
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
I'm going to assume if you check that box and press cancel it wont work?
Pwolf is offline   Reply With Quote
Old 07-21-2014, 08:32 PM   #1111
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
Nope
Old 07-21-2014, 09:29 PM   #1112
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Has anyone figured out how to get the volume to stay at whatever volume you left it at when you shut the car off? I hate that it always goes back to level 14.
Deathalo is offline   Reply With Quote
Old 07-21-2014, 10:02 PM   #1113
morphius88
R0GUE
morphius88's Avatar
Drives: 2013 Whiteout Scion FR-S
+1
Sent from planet Mars using HTC One
morphius88 is offline   Reply With Quote
Old 07-21-2014, 10:20 PM   #1114
phanguy
phanguy's Avatar
you could probably do it with tasker if you are using the stock app, but if you're using poweramp then i don't think that's an issue? at least not that i noticed. but even if it is then tasker can fix that too.
Old 07-21-2014, 10:35 PM   #1115
Deathalo
Wait, what do you mean when using poweramp? I have poweramp installed (but the volume control is disabled so Viper can power the audio). I also have tasker installed, but how would I fix that other than set the volume at a different level everytime the car turns on. This issue is less of what level it goes to, and more that I want it to go back to whatever it was last set at.
Old 07-21-2014, 11:14 PM   #1116
phanguy
phanguy's Avatar
fair enough. i would think that tasker can do such a thing, but i haven't tried anything quite that complex before. maybe it's a poweramp setting though? have you tried asking on their forums?
Old 07-22-2014, 01:39 AM   #1117
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
It's got nothing to do with PowerAmp. I don't use PowerAmp (so far, at least), and it does the same for me. Seems to be a "feature" of the ROM or something bundled with it.
SilverlightPony is offline   Reply With Quote
Old 07-22-2014, 10:27 AM   #1118
SPT Legacy
Drives: 2014 Lightning Red BRZ
I've been talking to Will about a problem my HU has had. The left and right channels are inverted, and the left channel is getting a weak signal...anyone else have this issue?
He said to test with a different speaker but I'd like to not tap into the factory harness any more than I already have..
SPT Legacy is offline   Reply With Quote
Old 07-22-2014, 12:05 PM   #1119
SilverlightPony
That's an odd one.
Old 07-22-2014, 01:37 PM   #1120
SPT Legacy
It'd be my luck to get the only lemon too. lol..
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
