Old 07-22-2014, 10:37 AM   #1
Lord Peth
Drives: 2014 BRZ
Exhaust Upgrade questions
Ok, I have done extensive research looking into upgrading the exhaust system, and due to the incredible market saturation I am at an en pass. Eventually I want a full header back replacement, but my end goal is still to maintain at least one cat for the smell, while making what power gains are possible as well as increasing sound of the painfully quiet OEM system. For the present time I'd like to keep my budget to about $750 for a cat back system that will not need to be replaced when it comes time to replace the OEM heads and front/over pipe. The main problem comes in because my wife and I sold her awful ford sedan, and she took my 128i, and I got the BRZ. Now I have to listen everyday while she drives off with her M exhaust and the BRZ is painfully quiet.
Basically I'm looking for a catback, that won't break the bank, but will not need to be replaced when I get around to the rest of the exhaust system.
Lord Peth is offline   Reply With Quote
Old 07-22-2014, 10:44 AM   #2
Shady195
Drives: '13 10 Series FRS #1203
AFAIK just about every catback out there will bolt up with an aftermarket header and overripe. That doesn't seem to be an issue. I could be wrong, but ive seen it mentioned a few times.
Shady195 is offline   Reply With Quote
Old 07-22-2014, 11:00 AM   #3
Lord Peth
Drives: 2014 BRZ
To clarify, I don't mean that they'll physically connect, but that the components will work well.
Also the immediate goal is sound, not sure if an axle back will be enough
Old 07-22-2014, 11:06 AM   #4
Cliu91
Cliuless
Cliu91's Avatar
Drives: Whiteout Scion FRS 2014
What type of sound are you looking for? We can't really help you decide on that. Do you want something loud?
Need more information.
Cliu91 is offline   Reply With Quote
Old 07-22-2014, 11:13 AM   #5
Lord Peth
Drives: 2014 BRZ
I want loud, but no unpleasant drone for dd. I don't want to go so loud that when I get to upgrading the rest of the system it gets ridiculously loud
Old 07-22-2014, 11:40 AM   #6
Brinks
Brinks's Avatar
If your going for sound, just get a 3" catback. Leave the stock mid and header.
Brinks is offline   Reply With Quote
Old 07-22-2014, 11:44 AM   #7
Cliu91
Cliuless
Cliu91's Avatar
If it is just sound, I was told the Berk Muffler Delete sounds pretty good. Check that out. Alot cheaper than an exhaust... maybe save up for a full upgrade in the future?
The Following User Says Thank You to Cliu91 For This Useful Post:
Lord Peth (07-22-2014)
Old 07-22-2014, 11:45 AM   #8
kayoh
kayoh's Avatar
Drives: 2014 SWP Limited BRZ
Borla takes my vote, if you stick around you can find one used around 400-500. No drone no rasp, and has a nice deep tone when you step on it.
Sent from my PC36100 using Tapatalk 2
kayoh is offline   Reply With Quote
The Following User Says Thank You to kayoh For This Useful Post:
Old 07-22-2014, 12:36 PM   #9
Lord Peth
Drives: 2014 BRZ
Muffler delete looks to be about $300, rather spend a few hundred more and at least have a portion of the exhaust done
Time to scope out the classifieds I guess
Old 07-22-2014, 12:39 PM   #10
Cliu91
Cliuless
Cliu91's Avatar
Really? thought I saw some floating around for $125.
But you're right, if money isn't an issue, go spend a bit more!
Old 07-22-2014, 03:27 PM   #11
J_kennington
Drives: 2013 asphalt scion FRS
Nameless
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 07-24-2014, 11:32 AM   #12
Lord Peth
Drives: 2014 BRZ
So I've looked around more and it seems like an axle back is the way to go first and then upgrade the rest later. However none of the compilation lists I've looked at have any MSRP at all. Just a bunch of dubious quality YouTube links.
Sound System Upgrade - Lots of Questions from a Relative Newbie Stang70Fastback Electronics | Audio | NAV | Infotainment 15 06-08-2016 01:17 AM
Pondering audio upgrade options; have questions, want recommendations SilverlightPony Electronics | Audio | NAV | Infotainment 17 05-11-2014 06:38 AM
Exhaust Questions? 636 Engine, Exhaust, Transmission 6 10-19-2013 05:14 PM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 10:45 PM
Exhaust Mod/Upgrade 101? Re~Mix Engine, Exhaust, Transmission 1 07-02-2012 06:23 PM
