Old 03-30-2014, 10:56 PM   #99
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
So far I have no issues with mine but for the price this piece is probably worth it as a cautionary measure.
XanRules is offline   Reply With Quote
Old 04-01-2014, 12:27 PM   #100
CrazyClover
CrazyClover's Avatar
Drives: 2013 FRS RAVEN
Just had mine installed. Haven't smelled anything since. Plus it's looks nice.
CrazyClover is offline   Reply With Quote
Old 04-01-2014, 12:32 PM   #101
was385
Drives: MT WRB BRZ Limited, 2007 911s
Originally Posted by subiestyle View Post
How widespread is this problem?
Besides the foul smell, how would you know you had a problem? Many owners complained of a foul smell coming from the car and blaming it on the "break in". I'm wondering if this is the culprit?
You can just reach down under the plate with a paper towel and wipe to check. It certainly seems to be fairly prevalent, however I have a pretty early 2013 model and after 23k miles, there is still no leak on the stock part.
was385 is offline   Reply With Quote
Old 04-19-2014, 11:26 PM   #102
XanRules
XanRules's Avatar
Aaaaand yup, mine just started right around when I hit 2000 miles.
Old 04-28-2014, 07:42 AM   #103
sshole
Weird. My BRZ has nearly 40,000 miles and not a single drop of oil from this plate.
sshole is offline   Reply With Quote
Old 05-03-2014, 11:55 AM   #104
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Maybe you have a 2013 build brz ?
Young_makaveli is offline   Reply With Quote
Old 05-03-2014, 11:58 AM   #105
sshole
Manufacture date 04/12, delivered July 2012...
Old 06-02-2014, 09:29 PM   #106
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Question about the dabs of permatex...should they be squarely on the mating surface or slightly toward the center (slightly overhanging such that some of it, when mated, will go into the inside?). I find in @Dezoris video, his was squarely on the mating surface, pretty tidy and on @FT-86 SpeedFactory's video it was more toward the inside (particularly top dap). Planning on installing tomorrow afternoon Thanks!
Edit: I guess ultimately, is there such a thing as too much permatex in this situation? I typically go a bit more in these type of situations.. @Raceseng would love your opinion on this!
1Cor10:23 is offline   Reply With Quote
Old 06-02-2014, 10:22 PM   #107
Dezoris
Dezoris's Avatar
You will see on the mating surface there is seam at the top and bottom thats what you are putting the permatex on. Follow the instructions from raceeng and let cure overnight with car cooled off and you should be golden.
The Following User Says Thank You to Dezoris For This Useful Post:
1Cor10:23 (06-03-2014)
Old 06-03-2014, 12:15 PM   #108
1Cor10:23
1Cor10:23's Avatar
Just installed - found that o-ring kept on wanting to pop out, first time it moved out of slot before I finished putting rest of bolts on, 2nd time around seemed like it stayed out. Anyone else experience this?
Edit: also, how important is it to be exact with the torque? I found that 12 lb came up quite suddenly and it didn't have any additional movement to 14lb when I came back to tighten.
Old 07-20-2014, 05:21 AM   #109
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
I was able to get the extra two lbs after 45mins as per instruction. However 2lbs is not anything to worry over chances are your TQ wrench could be not perfect calibration so if all are equal and tight enough leave it IMO.
As far as dabs of RTV go I got a fair bit inside the lip to, doing it from top not so easy to see/feel on the amount accurately but given you just need to cover the seperation point of where O ring meets I can not see any amount RTV being inside an issue either. My stock one started to seep and there was a ton more of RTV sealant near inside bore then I expected to see...so should be fine anyhow.
My car was a May 2013 with 9k miles on it for record.
Old 07-20-2014, 08:44 AM   #110
Raceseng
Raceseng's Avatar
You can be generous with the Permatex, no worries!
Jarrett Seng
Raceseng | Owner
610.336.0206
Raceseng is offline   Reply With Quote
The Following 2 Users Say Thank You to Raceseng For This Useful Post:
1Cor10:23 (07-20-2014), Clipdat (07-28-2014)
Old 07-28-2014, 02:30 AM   #111
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
It looks like some of my photos aren't showing up in my first post anymore. I'll try to edit my original post or re-upload them in the next day or so.
Originally Posted by humfrz
I'm old and lazy
Old 11-02-2014, 12:28 AM   #112
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
I didn't have the gray RTV so I used the black/high oil resistance. Full cure says 24h. I waited a few hours and hoped it was enough. Still got some leaking tonight.
Noted, let it cure as per the RTV instructions!
Removed, reseated, re-RTVed, curing as we speak.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
The Following User Says Thank You to Superhatch For This Useful Post:
jcw99 (11-02-2014)
Raceseng | Billet Aluminum Caster Camber Plates Raceseng Suspension | Chassis | Brakes -- Sponsored by 949 Racing 162 12-29-2014 10:32 AM
Raceseng | Billet Aluminum Engine Pulleys Raceseng Engine, Exhaust, Transmission 174 07-24-2014 12:24 AM
Raceseng | Lightweight Billet Aluminum Tow Hook Raceseng Cosmetic Modification (Interior/Exterior/Lighting) 13 08-27-2013 01:48 PM
SRP Billet Aluminum Door Sills pedalpusher Interior Parts (Incl. Lighting) 2 09-20-2012 10:25 PM
SRP Billet Aluminum Door Sills pedalpusher Cosmetic Modification (Interior/Exterior/Lighting) 2 09-20-2012 06:44 PM
