Old 04-16-2012, 07:38 PM   #71
Allch Chcar
Drives: N/A
Originally Posted by old greg View Post
The bellhousing bolt pattern is different unfortunately.
How do you know this, little detail?
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 04-16-2012, 07:44 PM   #72
Dimman
Kuruma Otaku
Dimman's Avatar
What that article is describing is using sintering to create a solid intermediate form for forging. The term "powder forged" is quite disingenuous, at no point is the powder itself forged. It is instead formed into a shape which, once sintered and subsequently pressed between a set of forging dies, will have little or no extraneous material needing to be removed.
And the rapid prototyping process you are referring to is called Selective Laser Sintering (although it can be done with electron beams instead).
In either case, it still involves sintering.
I didn't invent the term, but that's how they're advertised probably to differentiate them from cheap OEM sintered rods (Focus I believe had sintered rods), and the conventional rods. And at the same time, their process has to start with the powder. I imagine that they are a pretty good value as they can probably maintain closer tolerances on their weights than ordinary forged rods. BMW's M V10 used this tech apparently.
Point is basically that the options available to the SBC community kick our ass. They are getting application-specific parts at OEM level manufacturing at good value. Whereas most import stuff is more expensive and machined from generic 'close enough' forged blanks, or from billet.
(Also: Selective Laser Melting... http://www.crptechnology.com/sito/en...lting-slm.html)
Because titanium.
Old 04-16-2012, 09:31 PM   #73
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Droo-P drift car build thread, iirc.
old greg is offline   Reply With Quote
The Following User Says Thank You to old greg For This Useful Post:
Allch Chcar (04-17-2012)
Old 04-16-2012, 10:48 PM   #74
Sasquachulator
Pavement Grey
Originally Posted by uspspro View Post
Here is the dyno chart at the wheels from my 2GRFE powered MR2 Spyder.
It's a great engine with excellent throttle response, once it's coupled to a light flywheel and proper manual transmission, along with good flowing intake/exhaust.
In the BRZ you could use the 2GRFSE version, since it is designed for longitudinal mounting. Only thing that sucks is you will have check engine codes, since it expects and automatic gearbox (no MT in the IS350).
What about the IS250's tranny? or the one in the Tacoma? They're bolted to variants of this engine (4GR-FSE and 1GR-FE respectively). Could those work? Or heck do what Lotus did and jack a toyota 6 speed diesel transmission for it lol.
Old 04-16-2012, 11:43 PM   #75
mact
Drives: 13 GTI
I believe the starter is mounted on opposite sides on the FA and EJ.
mact is offline   Reply With Quote
Old 04-17-2012, 10:30 AM   #76
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
Drives: 2015 Series Blue BRZ
TwinTurbo H6 from the 997 GT2, not sure what the engine designation is.
"Sweet Subaru, sweet Subaru, send your BRZ unto me, for the roads of the unworthy must be baptized in speed and glory." ~Zaku
SVTSHC is offline   Reply With Quote
Old 04-17-2012, 01:00 PM   #77
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Haha.. "cost no object"
Actually I would grab that new 4L NA H6 from the new GT3
For a more realistic swap for a DIY-er.. if these bell housing rumors are true, the 2GRFSE would be wicked in a BRZ/FRS
uspspro is offline   Reply With Quote
Old 04-17-2012, 01:03 PM   #78
ZDan
ZDan's Avatar
Drives: '23 BRZ
Regarding LSx wonderfulness:
Stock LS2 bottom end, shaved stock L92 heads, 222/230 .597" cam.
Total street build for daily-drivable street car.
Just passed RI emissions with two high-flow catalytic converters.
Did 462 miles on one tank when I brought it up to RI from TX, fill took 15.9 gallons (that's 29 highway mpg, folks).
Yee haw...
LSxJunkie (04-17-2012)
Old 04-17-2012, 01:07 PM   #79
bimmerboy
Drives: 2009 135i
If money were no object: Lexus LF-A V10 engine. \thread
Realistic swap: EJ207 JDM STi engine + basic bolt-ons+tune,
bimmerboy is offline   Reply With Quote
Old 04-17-2012, 05:05 PM   #80
Racecomp Engineering
Rollin....in my five point oh.
- drew
Old 04-17-2012, 07:48 PM   #81
DOTman05
Drives: Evo 8
2uz would be cheap any seen this done yet?
DOTman05 is offline   Reply With Quote
Old 04-17-2012, 11:56 PM   #82
3MI Racing
Pro Subie Engine Nerd
3MI Racing's Avatar
Drives: empty spot for an FR-S/BRZ
Originally Posted by LSxJunkie View Post
Nice thing about those Fox body motors, you blow one up and you get another one for like 150 bucks.
I'm hoping he meant the Coyote
3MI Racing is offline   Reply With Quote
Old 04-17-2012, 11:58 PM   #83
Dimman
Kuruma Otaku
Dimman's Avatar
Vanilla Ice's 5 point Oh didn't have overhead cams...
Because titanium.
Old 04-18-2012, 12:41 AM   #84
fatoni
dont be stupid. every body knows ice rides a bike
Engine Swap ... Macavely Engine Swaps 220 07-25-2012 03:58 AM
Engine swap question koyv90 Engine, Exhaust, Transmission 4 03-22-2012 01:08 PM
4U-GSE: the new engine swap for old Toyotas no_name Engine Swaps 17 12-19-2011 09:50 PM
engine swap thread aspera Engine Swaps 231 03-15-2011 05:10 PM
YOU MUST CHOOSE # 2 Calais Other Vehicles & General Automotive Discussions 16 07-22-2010 12:30 AM
