Old 07-18-2014, 12:30 PM   #15
FRS_FIEND
Whats next?
FRS_FIEND's Avatar
Drives: '13 Asphalt FRS MT
I still have no idea what you guys are hearing lol I never hear my frs' pump make any noises that calls for me being super irritated lol i guess i got lucky ? lol 5600~ mi. 91 octane no ethanol
Life is too short to drive a boring car...
Instagram: @angelb_af
FRS_FIEND is offline   Reply With Quote
Old 07-18-2014, 02:20 PM   #16
swpbrz
Drives: swp brz limited
Its the ethanol or other additives places that use ethanol are likely to use.
swpbrz is offline   Reply With Quote
The Following User Says Thank You to swpbrz For This Useful Post:
FRS_FIEND (07-18-2014)
Old 07-18-2014, 06:19 PM   #17
Gabster
Drives: '13 BRZ
Originally Posted by Marchy View Post
You may need to cycle a tank of it to take effect.
Yep, took me 2.5 tanks to get rid of them.
Gabster is offline   Reply With Quote
The Following User Says Thank You to Gabster For This Useful Post:
Marchy (07-19-2014)
Old 07-19-2014, 12:08 AM   #18
extrashaky
Drives: 2014 BRZ Limited
But that doesn't make sense to me, because the few times I've gotten a good tank of E10 that gave me no crickets, the change was almost immediate. I filled up with E10 from a Chevron station over in New Iberia, LA and heard the crickets die when I cranked the car and the new gas hit the HPFP. The exact same thing happened again at a Marathon station in lower Alabama. If the problem is cavitation in the fuel, filling the car with a full tank of fuel that resists the cavitation problem should cause an immediate change as soon as the new fuel reaches the pump. The E0 produced no change whatsoever.
I am still convinced that ethanol has nothing to do with it, especially since some E85 users are still reporting that their crickets go away when they switch over. I still think it's the additive package. When you get ethanol-free gas, it's coming from a different distribution system from regular tier 1 gas, and I think it lacks the additives in the tier 1 gas that contribute to the cavitation.
And speaking of cavitation, if that's where the pressure behind the plunger in the HPFP drops low enough to pull gas bubbles out of the fuel, could that be eliminated mechanically by raising the pressure behind the HPFP? I'm wondering if replacing the other fuel pump with a higher flowing model might pump enough pressure into the HPFP that the cavitation doesn't happen. Is anybody here running an aftermarket fuel pump under the rear seat?
Old 07-19-2014, 08:57 AM   #19
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
i dont see what the problem is. 50k miles on my OEM crickets. Never had the crickets replaced or serviced. car preforms just fine.
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
The Following 2 Users Say Thank You to carbonBLUE For This Useful Post:
extrashaky (07-19-2014), Marchy (07-19-2014)
2013 Subaru BRZ Limited Late Apex Cars for Sale/Trade 7 03-05-2014 12:19 AM
WTS: 2013 Subaru BRZ Limited $22,000 smmmurf Cars for Sale/Trade 10 12-09-2013 03:19 PM
WTS: 2013 Subaru BRZ Limited $22,000 smmmurf Northern California 13 12-09-2013 03:18 PM
2013 Subaru BRZ Limited 6MT phiberoptik BRZ First-Gen (2012+) — General Topics 51 09-13-2013 12:37 PM
WTS 2013 SWP Subaru BRZ Limited MT jrodz09 Cars for Sale/Trade 18 03-04-2013 04:11 PM
