Old 07-15-2014, 01:18 PM   #323
FRSGeek
Drives: UltraMarine 6 Spd MT
bump
Still don't have anyone speaking up on the 3" Alu DS (and maker) with the TRD QS installed.
'13 Ultra Marine 6MT:AVO Stg 1.5 T, Berk Tech Cat'd FP, Perrin OP & 2.5" cat back, WinMax W3F/W2R, 18x8.5et44 Rota, 245/35R18's, Drift-Office EcuTek Tune, Cusco Strt Twr & Rear brace and Grimspeed hood struts.
FRSGeek is offline   Reply With Quote
Old 07-16-2014, 11:34 AM   #324
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Originally Posted by Ds3ire View Post
very very short throws...
Has it gotten rid of the 2nd gear grind as well?
You mean the reluctance to go into 2nd when cold? That's still there for sure.
JohnJuan is offline   Reply With Quote
The Following User Says Thank You to JohnJuan For This Useful Post:
Ds3ire (07-18-2014)
Old 07-16-2014, 12:54 PM   #325
kasikuusi
kasikuusi's Avatar
Drives: 2014 FRS
Originally Posted by FRSGeek View Post
bump
3" aluminum DSS shaft seems not to work with this short shifter due to clearance. Check post 222.
kasikuusi is offline   Reply With Quote
Old 07-17-2014, 02:37 AM   #326
FRSGeek
Begs the question of which one does?
Old 07-18-2014, 02:47 PM   #327
eazyace
Drives: wish
I thought I was the only one with this issue. Glad to see its no me going crazy. I'm a bad driver but I always thought I was extra bad from 1st to 2nd when cold.
eazyace is offline   Reply With Quote
Old 07-18-2014, 03:01 PM   #328
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Does the shorter shifts and harder to change gears take the fun away from shifting?
Carlitoz3 is offline   Reply With Quote
Old 07-18-2014, 05:41 PM   #329
BRZYOLO
Drives: 14 BRZ, SC300
No. But that depends how u define "fun" in shifting...lol if u like long a** throw like the w58/r154 then yes this is different.
BRZYOLO is offline   Reply With Quote
Old 07-21-2014, 01:02 AM   #330
JohnJuan
JohnJuan's Avatar
If anything, I'd argue that this makes shifting even more fun. You can just click so fast from gear to gear.
Old 07-21-2014, 01:34 AM   #331
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
Correct CF 2.75" aluminum 3".
The one thing I did hear was that if you were driving with any aftermarket driveshaft that if you bottomed out there was a chance that the TRD short shifter may hit it still.
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline   Reply With Quote
Old 07-21-2014, 01:45 AM   #332
kasikuusi
kasikuusi's Avatar
Drives: 2014 FRS
I haven't had any issues with it hitting the driveshaft. Anyway I really like the feel of this short shifter. Maybe I just need to drive little harder to try to bottom it out. 😜
The Following User Says Thank You to kasikuusi For This Useful Post:
Xerious (07-24-2014)
Old 07-24-2014, 01:53 PM   #333
FRSGeek
I know this is moving off topic title.
Do we have 'which' short shifter works with 3" alu DS?
Old 07-24-2014, 02:38 PM   #334
Whitesoul
I'm assuming this is for manual only?
Whitesoul is offline   Reply With Quote
Old 07-24-2014, 04:06 PM   #335
JohnJuan
JohnJuan's Avatar
This is correct. The TRD Quickshifter is for manual only. It even says so on the instructions.
Old 07-25-2014, 04:20 AM   #336
Snowblind
Seriously?
The Following 8 Users Say Thank You to Snowblind For This Useful Post:
-Tom- (09-04-2014), brianhj (08-02-2014), DC2R (07-25-2014), DustinS (08-28-2014), KpAtch3s (01-19-2015), raven1231 (07-25-2014), RJ_203 (09-04-2014), wootwoot (07-25-2014)
TRD Quickshifter lovebeingbleu98 Brakes, Suspension, Chassis 3 02-13-2014 01:14 AM
Amazing Wax geb2391 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-12-2013 05:42 PM
The most amazing thing I've done with my BRZ so far azngolfur BRZ Photos, Videos, Wallpapers, Gallery Forum 8 01-09-2013 09:23 PM
Concept-Three-LED's DRL's are AMAZING! soros151 Cosmetic Modification (Interior/Exterior/Lighting) 4 11-09-2012 02:42 AM
