Old 07-12-2014, 10:36 AM   #309
TM
TM's Avatar
Drives: DGM BRZ 6MT
A bit of a late update. Finally went back under my car after a long vacation. Fixed/tightened the adapter bolt.
Now the shifter is nice and tight, just the way I like it
TM is offline   Reply With Quote
Old 07-12-2014, 02:30 PM   #310
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Has anyone done an install video of this yet?
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 07-12-2014, 04:40 PM   #311
BRZYOLO
Drives: 14 BRZ, SC300
just installed mine, the shift is definitely tighter due to the change to the oem rear bushing to the one the kit provided. But as previously mention, it does take a little more force to shift into gear as the leverage length underneath is increased.
Regarding the install, it was pretty straight forward, I ripped the oem shift boot like everyone else. The shift position is also slightly changed from stock, overall very satisfied with the kit but it is on the expensive side for what we are getting.
I got my kit at fairfield momentum toyota for 150.
BRZYOLO is offline   Reply With Quote
Old 07-14-2014, 03:40 AM   #312
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
I had a problem getting the adapter's bushing to fit properly over the little peg thing. This coat me at least an hour of install time and a trip to the store for an 8" channel lock to help me squeeze it together. Shifts like a stream, though. Totally worth the slightly difficult installation.
Be sure to check that the adapter's bushing for a fit before you commit.
JohnJuan is offline   Reply With Quote
Old 07-14-2014, 04:02 AM   #313
Ds3ire
Ds3ire's Avatar
Drives: Toyota 86
very very short throws...
Has it gotten rid of the 2nd gear grind as well?
Ds3ire is offline   Reply With Quote
Old 07-14-2014, 05:49 AM   #314
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Any QS out their that won't have a problem with an aftermarket shaft? Looking into getting a cf shaft later in the year.
Carlitoz3 is offline   Reply With Quote
Old 07-14-2014, 11:01 AM   #315
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
Anybody in Northern Cal that has this upgrade where I can feel the shorter throws? Thanks in advance!
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline   Reply With Quote
Old 07-14-2014, 11:04 AM   #316
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
I'm am interested to know as well if the CF shaft will not have an issue with the shifter.
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 07-14-2014, 11:11 AM   #317
FRSGeek
Drives: UltraMarine 6 Spd MT
Do we have a concise answer on which if any 3" Alu. Drive-Shafts work with the TRD QS?
'13 Ultra Marine 6MT:AVO Stg 1.5 T, Berk Tech Cat'd FP, Perrin OP & 2.5" cat back, WinMax W3F/W2R, 18x8.5et44 Rota, 245/35R18's, Drift-Office EcuTek Tune, Cusco Strt Twr & Rear brace and Grimspeed hood struts.
FRSGeek is offline   Reply With Quote
Old 07-14-2014, 11:13 AM   #318
kasikuusi
kasikuusi's Avatar
Drives: 2014 FRS
I have DSS CF shaft no issues.
kasikuusi is offline   Reply With Quote
The Following User Says Thank You to kasikuusi For This Useful Post:
Xerious (07-14-2014)
Old 07-14-2014, 11:14 AM   #319
Xerious
Xerious's Avatar
The diameter for the CF one is smaller than the aluminum version, right?
My Build
Old 07-14-2014, 11:17 AM   #320
kasikuusi
kasikuusi's Avatar
Drives: 2014 FRS
Correct CF 2.75" aluminum 3".
Xerious (07-21-2014)
Old 07-14-2014, 11:47 PM   #321
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Curious, is the stock driveshaft the same diameter as the CF?
JDKane527 is offline   Reply With Quote
Old 07-15-2014, 02:14 AM   #322
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I have this mod, maybe on the next 86drive event, if I can make it out.
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
TRD Quickshifter lovebeingbleu98 Brakes, Suspension, Chassis 3 02-13-2014 01:14 AM
Amazing Wax geb2391 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-12-2013 05:42 PM
The most amazing thing I've done with my BRZ so far azngolfur BRZ Photos, Videos, Wallpapers, Gallery Forum 8 01-09-2013 09:23 PM
Concept-Three-LED's DRL's are AMAZING! soros151 Cosmetic Modification (Interior/Exterior/Lighting) 4 11-09-2012 02:42 AM
