Old 07-17-2014, 01:01 AM   #1
ikeryder13
Drives: 2013 GBS BRZ
Looking for exhaust advice...
I have a invidia n1 and catless front pipe... I'm looking to see if anyone has the same PLUS a el or uel header? Need advice on performance... Sound isn't as much of a factor... I am intersted in buying one but I want some advice first.
Is there that much difference in the hp gain and torque dip ?
ikeryder13 is offline   Reply With Quote
Old 07-17-2014, 01:35 AM   #2
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
I didn't notice a difference in performance n1 vs q300. I ran both setups when NA(borla uel, perrin over pipe, invidia catless non resonate front pipe), the only difference is the N1 being way louder.
Build Thread
Instagram
Old 07-17-2014, 01:49 AM   #3
ikeryder13
Yeah it is pretty loud but I do sorta like it... I know the subie burble is only really heard in the uel header
Old 07-17-2014, 02:13 PM   #4
ikeryder13
Bump
Old 07-17-2014, 04:17 PM   #5
ikeryder13
I already have a catback... I just wanna know the difference in gain between uel and el header
Old 07-17-2014, 04:42 PM   #6
kayoh
kayoh's Avatar
Drives: 2014 SWP Limited BRZ
Ohh man, here we go again. Please don't take this the wrong way, but did you even try searching? This topic has been discussed so many times it's sickening...
It's too easy for people to click that "New Topic" button because they are too lazy to do a little research.
Type this in google: "site:ft86club.com EL vs UEL" and take a look around.
kayoh is offline   Reply With Quote
Old 07-17-2014, 08:31 PM   #7
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
To generalize (note: not true in every case), EL is the way to go if you intend to do forced induction at any point, otherwise the performance gains from the header alone (UEL or EL) are fairly similar depending on brand and tune obviously.
It really comes down to your preference in sound, price and plans for the car down the road.
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline   Reply With Quote
Old 07-18-2014, 12:05 AM   #8
ikeryder13
Yeah no forced induction...just want some good gains while staying NA
Old 07-18-2014, 12:07 AM   #9
ikeryder13
I know I hated to ask it lol... But I just wanted with my mods of being catless with the n1 what would be the best gains...
I also wanted a suggestion on a UEL brand or EL brand... I plan on trying to do the most mods I can to get the most hp without going FI
Old 07-18-2014, 12:47 AM   #10
steve99
Drives: FT86
El or UEL headers does not really matter power wise as others have said
Best you going to do without FI and just bolt on mods is about 35-40 wheel hp over stock on E85 fuel take off 10-15 without E85 ie on petrol.
Catless EL or UEL headers
Tune
E85
Drop in filter
Don't bother with intakes stock intake with drop in filter will do.
Cheapest way
Open flash Tablet (includes tunes for petrol & E85) + openflash header and E85 tune = $1015 US (always use new gaskets for header install)
http://openflashtablet.com/products/OFH/index.html
If your after more than about 40Hp gain just go FI from the start.
Plenty of other tuning options available with proper flex fuel kit/sensors and specific dyno tune, you might get a few more hp with a personalized dyno tune as opposed to a "canned" or off the shelf tune but their is not much in it and it will be more expensive.
Old 07-18-2014, 10:26 AM   #11
ikeryder13
Thank u for the advice sir! Is there any header that u suggest more than the others...
My mods are as follows
K&N drop in
Invidia catless front pipe
Invidia n1
I don't plan on going FI because I'm buying a STI anyways again...
I am torn between the unichip and the OFT...
Old 07-18-2014, 11:46 AM   #12
kayoh
kayoh's Avatar
K&N drop in
Invidia n1
Pick up an overpipe because that's a bottle neck in the exhaust system as well, don't get the Invidia overpipe because it bangs against the sub frame.
Regarding headers,if money is no issue get the Tomei or the JDL Header and a tune to go along with it. If money is an issue then pickup the OFT/OFH.
Old 07-18-2014, 04:34 PM   #13
steve99
Drives: FT86
K&N drop in
Invidia n1
I would agree with @kayoh post above.
The OFT/OFH header combo is probably the cheapest way to go as long as you like UEL header sound. They seem to be good quality units. and since its their headers they have worked the tune for them pretty well and its "free" with the OFT, they also have tunes for EL headers and E85 ect incuded
I would go the OFT or other tuning device such as ecutek/tactrix/brzedit ect that flashes a ROM to car rarther than a unichip that is a piggyback and requires wiring in. also unichips far more limited in in parameters they can alter.
It much simpler to just flash rom to stock than unwire unichip for dealer visits
Old 07-18-2014, 06:27 PM   #14
ikeryder13
Do any of u guys have the crawford power blocks? They seem interesting to me
TRD Exhaust Sound and any further advice Freedom AFRICA 49 06-18-2015 03:59 AM
Exhaust System Advice NIKOLA Engine, Exhaust, Transmission 5 02-11-2014 06:59 PM
Exhaust Advice ChandlerSwyng Engine, Exhaust, Transmission 15 01-24-2014 05:46 AM
Exhaust pick advice hanabie Engine, Exhaust, Transmission 38 08-06-2013 10:50 PM
California Exhaust Advice Pneub Southern California 1 05-27-2013 06:30 PM
