Old 07-15-2014, 08:16 PM   #659
CSG Mike
CSG Mike's Avatar
I'll go with slow stig lol
Old 07-17-2014, 01:57 PM   #660
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Just make sure everything is tightened to spec, and you shouldn't see any seepage. It's a bit awkward to tighten without the proper tools.
So after my oil change and tightening everything to the proper specs, I'm still getting some oil seeping through...
Any other ideas and thoughts on how to fix this?????
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 07-17-2014, 02:20 PM   #661
CSG Mike
CSG Mike's Avatar
Take off the sandwich plate and make sure it's clean on the bottom. The rubber seal should be making clean contact with the base.
Old 07-17-2014, 02:29 PM   #662
*LongFella
*LongFella's Avatar
Jackson Racing Supercharger Owners Thread
I gave it a good cleaning when I changed the oil, but I'll give it another try!
Would the oil type make a difference? Doubt it... but trying to think of other reason if this attempt doesn't work.
Maybe it's the sandwich plate?
Old 07-17-2014, 04:20 PM   #663
CSG Mike
CSG Mike's Avatar
Possible, but unlikely.
Any pics?
Old 07-17-2014, 08:08 PM   #664
Calum
That Guy
Drives: 2013 asphalt FRS MT
Did you lubricate the seal before you screwed everything together?
Take a really careful look at the seal. When synthetic oil eats a seal it either dissolves it, leaving the rubber to smear away, or the rubber stretches and expands so it doesn't fit properly. I highly doubt JR spec'd a seal that wasn't safe for all oils, but that doesn't mean they weren't shipped one by accident.
Another possibility is that the seal is just old, it might have sat on a shelf too long. If possible, turn it inside out to see if there's any cracking in the rubber.
The Following User Says Thank You to Calum For This Useful Post:
*LongFella (07-17-2014)
Old 07-17-2014, 08:20 PM   #665
*LongFella
*LongFella's Avatar
Will do! Thanks for the advice!
Old 07-19-2014, 10:12 AM   #666
Parikh1234
Drives: Subaru BRZ Limited
Heres my dyno:
Also here is a link to the build. Still havent tuned for 93 or done any of the headers > back. Hopefully can get a couple extra hp with those tunes. Might go e85.
http://www.ft86club.com/forums/showthread.php?t=70240
Parikh1234 is offline   Reply With Quote
The Following User Says Thank You to Parikh1234 For This Useful Post:
CSG Mike (07-19-2014)
Old 07-19-2014, 10:55 AM   #667
Calum
That Guy
Originally Posted by Parikh1234 View Post
Heres my dyno:
Which tune is that?
Old 07-19-2014, 11:58 AM   #668
Parikh1234
Which tune is that?
Prime Motoring did the tune. They have a guy, Jr, there that does the tuning.
Calum (07-20-2014)
Old 07-19-2014, 01:41 PM   #669
gbrz
where can i buy a replacement hose for the oil cooler? autozone or is there somewhere better to buy online?
got a hole in my oil cooler line from rubbing against a bracket (my installation mistake)
gbrz is offline   Reply With Quote
Old 07-19-2014, 02:08 PM   #670
Squishy
Drives: 2013 WRB BRZ
I have better luck going to O'Reily's or NAPA to get generic fuel line / oil line hose by the foot. Autozone won't sell you anything unless it is a oem type of item replacement.
Second place is just the first place loser.
Dale Earnhardt
Squishy is offline   Reply With Quote
The Following User Says Thank You to Squishy For This Useful Post:
gbrz (07-19-2014)
Old 07-19-2014, 08:34 PM   #671
CSG Mike
CSG Mike's Avatar
Which line is it? We can help you with a replacement.
Old 07-19-2014, 09:46 PM   #672
*LongFella
*LongFella's Avatar
Took the JR oil cooler apart today and got everything cleaned and refitted. I'm hoping that solves everything!
It was probably a noob install because the center (long) bolt you use to attach the extension and lines too... wasn't that tight... My fault for sure...
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
