Old 07-16-2014, 09:54 AM   #1
Raven604
Metal shavings in oil after change.
So last hight I noticed some grain of sand sized metal shavings in my oil after I changed it. Changed it after 6.5kkm, mobile 1 afe. Normal? Probably 10 or so grains of metal total. Pretty sure I heard my car knock once extremely loud last week. It's never happened before.
Sent from my SGH-I337M using Tapatalk
Raven604 is offline   Reply With Quote
Old 07-16-2014, 10:09 AM   #2
sluflyer06
Drives: 2014 BRZ Ltd - DGM
Save any of the oil for a analysis?
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
Old 07-16-2014, 10:17 AM   #3
AJPG
Drives: 22RE, FA20, 4G63
That doesn't sound right.
Take an oil sample and if you could use other car until find out were the particulate came from.
Any modifications? FI?
Check compression and pay attention to any different or new sound(noise).
Keep post.
AJPG is offline   Reply With Quote
Old 07-16-2014, 12:14 PM   #4
Dezoris
Dezoris's Avatar
Yep, best way to get answer.
Old 07-16-2014, 01:25 PM   #5
Raven604
I have the oil still. Transfered from my new plastic oil pan to the new oils 4.4l empty jug. Is it still good for analysis? I've never sent an oil sample out before. The engine sounds and runs fine.
Old 07-16-2014, 01:25 PM   #6
Raven604
Still completely stock other then an air filter, shift Springs, tranny moubt and shifter bushing.
Old 07-16-2014, 01:27 PM   #7
Raven604
Any help with sending oil samples out would help. Thanks.
Old 07-16-2014, 01:32 PM   #8
TM
TM's Avatar
Drives: DGM BRZ 6MT
You can request a free test kit from BlackStone: http://www.blackstone-labs.com/free-test-kits.php
Put your oil in the kit when you receive it and then send it back to them for analysis. I think it's around $25?
Not sure of a quicker method.
TM is offline   Reply With Quote
Old 07-16-2014, 01:33 PM   #9
eric6
eric6's Avatar
Drives: 93 MR2 Turbo; 2014 BRZ
Blackstone laboratories is where to send oil for analysis.
However, if the sizes are as large as you state, I'm not sure an oil analysis will do much. They read parts in PPM, large parts are brushed aside for this testing. Post up some photos, that may be able to help us narrow down where the metal came from.
eric6 is offline   Reply With Quote
Old 07-16-2014, 01:37 PM   #10
TM
TM's Avatar
Drives: DGM BRZ 6MT
Btw, is this your first oil change? Metal shavings are common during the break-in period.
Old 07-16-2014, 01:49 PM   #11
Dezoris
Dezoris's Avatar
As mentioned go to Blackstones website. Request sample kit, you should have it within a week or so.
For now pour about 1 - 2 cups of oil out of your jug into a clean glass and cover it with plastic wrap until you get the collection container from Blackstone.
They will remove chunks for analysis but will still tell you what metals are in large quantities. Help you figure out if it's bearings etc.
Old 07-16-2014, 02:12 PM   #12
Raven604
I have 32,000km on the engine but this was the first change I did myself. I didn't clean out the oil pan with the shavings still in it. I'll post pics when I get home from work.
Old 07-16-2014, 09:31 PM   #13
Raven604
Old 07-17-2014, 09:06 AM   #14
sluflyer06
was your oil pan clean before you drained it? you didn't "rinse" anythign off the bottom of your pan and into the container did you?
2014 BRZ Ltd. - DGM
E46 323ci vert
Looking For Metal Fabricator rb6freak Southern California 2 03-04-2014 09:05 PM
Anyone into folk metal? Anthony Off-Topic Lounge [WARNING: NO POLITICS] 32 09-20-2013 03:06 AM
Scraping metal noise? Gost Issues | Warranty | Recalls / TSB 0 03-14-2013 09:11 PM
If you love vintage metal... Turbowned Other Vehicles & General Automotive Discussions 6 11-30-2012 10:04 PM
I've seen the GT86 in the metal and... Craikeybaby Scion FR-S / Toyota 86 GT86 General Forum 37 12-13-2011 03:57 AM
