#323 | |
#324 | |
Drives: 2013 Black FR-S
#325 | |
PhoneFlash by EcuTeK
Sincerely, Zach Delicious Tuning |
#326 |
Boosted Member
Drives: 2013 SWP BRZ Limited
as ambient temps continue to climb, I'm really having some heat issues in traffic or stop and go driving. If I don't turn on my heater full blast, I see coolant temps to 218F. Once the car gets moving on the freeway, everything is fine.
What are people seeing temp wise in traffic in hot weather? I'm going to get a vented hood soon but I have a feeling that is not going to be enough. I saw a heat shroud thing on the engine forum, do you think that will help?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
#327 | |
I want both fans to kick in. hmmm |
#328 |
in orbe terrum non visi
Drives: violent
rewire. Ill work on it when I get my car back from paint.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#329 |
I have my fans set to run basically all the time while the car is running.
Temps stay steady at 200-204 regardless of load or conditions, even in 100 degree heat in traffic.. I have the FB radiator, Spal fans, and FB shroud. |
#330 |
#331 |
Drives: violent
that depends. If the factory wiring/fuse/relay can handle double its intended load then sure, slice the other fan into the first fans wiring harness but I doubt it. You would most likely have to either run a new wiring harness with a relay that is triggered by the primary fan OR removing the trigger wire for the secondary fan and splice the primary fan relay trigger wire into it so the thermostat triggers both relays. The aforementioned probably the best-easy options. The best hard option involves wiring it in a way that turns on both fans with the thermostat and one fan when the ac is on. I need the car to figure that one out as electrical stuff isn't really my favorite thing to do.
#332 |
Junior
Drives: a car
Has anyone thought about louvers on top of the front fenders?
#333 | |
#334 |
Boosted Member
well if I put my heater on full blast without the A/C, i can get my coolant temp to hover around 190 ~ 195F which is awesome for the motor but not for me lol. I've been driving with the heater on HI and full blown and it sucks bad.
How do you rig the fan to stay on? I think when the heater is on, maybe both fans are on full blast?
#335 |
The AC triggers one of the fans.
Running the AC (and subsequently, the other fan) helps keep the temps down better than running the heater. I think the AC fan also is triggered by higher temps as well. Not sure, but Ecutek might be able to turn both fans on at a low temp. With both fans running all the time your temps will stay solid and not go up or down. Especially on a front mount turbo car, both fans running really helps. |
#336 | |
| any serious benefit Heat Tapes? | Djen | Engine, Exhaust, Transmission | 22 | 02-18-2014 03:20 PM |
| Heat bad for your car? Ways to cool it? | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 08-01-2013 10:15 PM |
| Misfire with heat? | bigjake | Issues | Warranty | Recalls / TSB | 2 | 04-28-2013 09:02 PM |
| Do I Need a Heat Shield? | arleewa | Engine, Exhaust, Transmission | 1 | 01-08-2013 06:37 AM |
| Overpipe Heat question | Amadeus | Engine, Exhaust, Transmission | 5 | 12-19-2012 01:18 AM |
