#309 |
On my car, with FB radiator, Spal fans, and shroud, IMO the majority of the cooling is coming from the fans and shroud. Quite a bit of air is moved by the fans and the shroud utilizes All of the radiator. I feel a LOT of hot HOT air being blown by the fans.
This is fine for street and canyon driving, but I think when we get to extended WOT conditions (track use) it is a Lot more important to re-install the ducting/air dams. It becomes super important for air-exchange, and proper pressures to help draw cool air in, and exhaust hot air out of the engine bay. I've installed a different crash bumper bar that lets a lot more air in, along with cutting holes in my bumper, which helps with air IN at the high pressure area, and my skidplate and trip-strips mod helps with the low pressure air-OUT area. Once I install the air dams/ducting around the radiator I hope my car will be able to handle track duty without cooling issues. For me, it's about addressing ALL aspects of cooling. Simply bolting in a big radiator won't cut it I don't think. |
#310 |
Junior
Drives: a car
But, in modifying the radiator, such companies (possibly assuming the wrong way) would think that the customer would say "hey my old radiator had these ductile thingys on both sides of it, why doesn't this one? Maybe I should go buy one."
But yes, always assume the customer is an idiot. At the same time it's like knowing that all the vaccum hoses will pop off >10 psi. No one knew that until the inspection was taken place, maybe they thought the increased size would negate the need for ducting? Idk I like playing devils advocate.
#311 |
Drives: 2013 Black FR-S
Any ideas on how to duct the front radiator/condenser with a crash beam and intercooler/piping in the way?
#312 |
I'm planning on just getting in there with pieces of foam, cutting them oversize and stuffing them into position. Maybe using some adhesive to hold the foam in place.
This is what the factory uses on the OEM radiator. |
#313 | ||
Boosted
Drives: Sideways
Before ![]() After ![]() ![]()
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
#314 |
in orbe terrum non visi
Drives: violent
you can now reach your hand into the interior of your car from your engine bay. I drove with that piece off for a day and although it works very well my catch can is there and my car still smells like ethanol. Its also louder when you have the air set to outside. I removed all my clips and slotted my cowl around the wipers so if I ever have on overheating problem somewhere I can slide the entire cowl out. But I don't dd it like that. And theres the water issue.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#315 | |
Boosted
Drives: Sideways
Overall I'm happy. Especially because the turbo is right there.
#316 |
Drives: violent
what i was getting at is thats the intake for your blower motor (HVAC). Turn your air to vent from outside and there will be a flap in there near your battery and the cut you made that opens. You will be venting your turbo heat into your blower motor. It was sucking vapors from my catch can into my car interior in the same spot.
#317 | |
Boosted
Drives: Sideways
On a side note, my normal drive from Buckhead to Alpharetta this morning showed 10 degrees Fahrenheit colder in the engine bay. And the car didn't feel as bad as it normally does in the summer.
#318 |
Drives: violent
well thats good. Ive said it over and over and over again that removing that cowl works. It just also sucks engine bay fumes into the car.
#319 | |
Boosted
Drives: Sideways
My hot weather traffic with little movement test also saw about 6-7 degrees cooler too. It hasn't really been a concern yet, just the car acts more sluggish in traffic. I'm interested to see how this holds on a track.
#320 |
Does anyone know where that post is of the AVOturboworld car showing the foam ducting they did for the radiator? @AVOturboworld
#321 | |
Have you tracked the car with the cowl removal? Does it truly evacuate hot air? |
#322 |
Drives: violent
I will say yes from highway tests, but im pretty sure I ended up trying to defrost my window with hot ethanol vapors
| any serious benefit Heat Tapes? | Djen | Engine, Exhaust, Transmission | 22 | 02-18-2014 03:20 PM |
| Heat bad for your car? Ways to cool it? | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 08-01-2013 10:15 PM |
| Misfire with heat? | bigjake | Issues | Warranty | Recalls / TSB | 2 | 04-28-2013 09:02 PM |
| Do I Need a Heat Shield? | arleewa | Engine, Exhaust, Transmission | 1 | 01-08-2013 06:37 AM |
| Overpipe Heat question | Amadeus | Engine, Exhaust, Transmission | 5 | 12-19-2012 01:18 AM |
