Old 07-15-2014, 11:36 AM   #57
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
Originally Posted by dradernh View Post
Will ice mode in this car stop if after inducing it the driver releases a slight amount of brake pressure, or maybe a bit more? If not, what do you do to get the braking back?
This is what I'd like to know as well.
BatStig is offline   Reply With Quote
Old 07-15-2014, 07:16 PM   #58
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by 7thgear View Post
if you're faster in the 914 you've either dumped many dollars into it or your FRS has the last 4 gears broken or you're afraid of the wind scratching your paint.
FYI:
Typical track times at High Plains Raceway (CO):
Formula Ford 2:00 +/-
American Iron 2:06
Acura '95 NSX (Kumho XS tires) 2:09.35
Nissan 350z (Nitto NT01 tires) 2:10
Porsche 944-Spec 2:13
Camaro Mustang Challenge 2:13
Spec Miata 2:18
09 Dodge Viper ACR 1:55
The 914s are the fastest cars in the Vintage small bore class (2.0L).
The fastest on the track in a 45 year old 914 is breaking 2:10.
At least 5 others are sub 2:20.
SO yeah 914s must suck since they are faster than miatas, and 944s.
And BTW - they are faster than 911s of the same era.
And I brought it up talking about rear diffs, and lifting a tire (or not).
How is your tirade relevant?
The 914s are very fast even though they are underpowered.
WHY? - because they are very light, low CG and make up for lack of power in the corners.
Sound familiar?
Old 07-15-2014, 08:06 PM   #59
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
I don't know, how is your success in a 914 relevant? You're defending electronic intervention by bringing to example a MR car with no electronics and a dinosaur suspension that works only because the car itself is feather light.
a paleoproterozoic-era formula ford is fast too, what's your point?
Sound familiar?
if you're trying to refer to an FRS then no, the FRS is a mid-weight car that isn't all that special in the grand scheme of things. They were 100 or so kilos off the mark I think... but then again, 25k car.
Old 07-15-2014, 09:36 PM   #60
CSG Mike
CSG Mike's Avatar
I don't know, but I'll do some testing when I get the chance!
Keep bugging me.
BatStig (07-16-2014), dradernh (07-16-2014)
Old 08-02-2014, 07:20 PM   #61
stugray
i'll just leave this picture here of a finely tuned, precision suspension design.
Just as a follow up to your naysaying. Took the 914 and the brz to HPR.
MY brz was 10 seconds faster than my 914.
HOWEVER my 914 was faster than a race prepared miata AND faster than a stock FRS.
I have track video to prove it. To be fair the 914 had Hoosiers while both twins were on street tires.
Old 08-02-2014, 07:58 PM   #62
mike the snake
My last 914 was faster than my BRZ.
The Following 5 Users Say Thank You to mike the snake For This Useful Post:
JoeC (08-20-2014), renfield90 (08-03-2014), stugray (08-02-2014), TrqlessWonder (08-03-2014), ZionsWrath (08-03-2014)
Old 08-03-2014, 11:40 AM   #63
renfield90
The Stig's German cousin
Car porn. Thank you sir.
The Following User Says Thank You to renfield90 For This Useful Post:
wparsons (08-05-2014)
Old 08-03-2014, 12:05 PM   #64
stugray
Beautiful! I am going for the Porsche viper green myself. Other 914s in my race group are orange so I need a little contrast.
Old 08-03-2014, 12:37 PM   #65
ZionsWrath
Thanks
ZionsWrath's Avatar
lmao I see what you did there
Nice [purple] car
Old 08-03-2014, 10:27 PM   #66
ddeflyer
Originally Posted by Slip Angle View Post
I completely agree that it is driver induced. When ice mode occurs, I am going very quickly from the throttle to the brake. I'll work on applying smoother input rather than stabbing at the brake. That said, the issue is certainly real. Especially with aggressive tires and brakes, if you move quickly from the throttle to the brake, the ecu of the car is prone to getting confused and going into "ice" mode which sucks.
It's a reasonable solution then to:
1) do the pedal dance to keep stability control from getting in the way
2) learn to drive around this issue versus going all in on a stand alone racing
brake controller
I do think that ice mode happens even when not stabbing hard enough to get into the abs. It also appears to be happen only when there is steering angle present as it has never happened to me under fast transitions to hard braking in a straight line.
Again, thanks for the help!
I've only hit ice mode once, but I'm pretty sure it was in a straight line. Late, hard braking going into turn 10 at T-Hill with good tires and DS1.11 pads in a essex sprint kit, I had some bumps (don't remember if it was from cresting the hill or if it was just pavement defects, was a while ago) and the braking power suddenly was cut in half or to a third of normal. Ended up taking a wacky line to acomodate it. Next turn everything was fine. Figured out later that it was ice mode. This was in VSC sport mode BTW.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
The Following User Says Thank You to ddeflyer For This Useful Post:
Slip Angle (08-08-2014)
Old 08-04-2014, 09:48 AM   #67
D K
Stig's dark passenger
That's not a 914.
Not a 916 even.
That's a track monster that still barely resembles a 914
D K is offline   Reply With Quote
Old 08-04-2014, 10:09 AM   #68
stugray
Nice [purple] car
Maybe now you will not make assumptions when someone says they are going to compare lap times between their 914 and their BRZ.
I have less than 10K in my 914 and I was cussing because the FRS in front of me would not get out of the way....
Old 08-04-2014, 10:55 AM   #69
ZionsWrath
Thanks
ZionsWrath's Avatar
I made assumptions? Please show me lol
I was just acknowledging a nicely prepped track car and the allusion to baseless comparisons when the amount of work done on the vehicle is unknown or not stated (i.e. my XYZ is faster than my ABC)
Old 08-04-2014, 06:05 PM   #70
stugray
So by adding ~$600 worth of rear shocks to that "precision" suspension must have made my lowly 914 into a supercar or something....
Your ASSumption was that just because a 914 is 70s tech, it is a POS.
The race prepared Miata that I passed, and the FRS that could not shake me would beg to differ.
My 914 has close to the same hp/weight ratio as the twins, but is mid engine.
And the reason the 914 even came up is that it is an Open diff stock, and "racers" make the mistake of thinking that a rear sway bar will make them faster. NOT if you have an open diff.
So if they think rear sway bars will help, then they better pony up the $$ for an aftermarket LSD.
because lifting a rear wheel with an open diff is not helpful.
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Vehicle Stability Control twostroke BRZ First-Gen (2012+) — General Topics 15 07-13-2014 11:10 AM
Stability Control? ashtray BRZ First-Gen (2012+) — General Topics 27 01-24-2013 05:32 PM
TPMS, LSD and Stability Control FRiSson Scion FR-S / Toyota 86 GT86 General Forum 4 11-05-2012 04:12 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
