Old 07-15-2014, 01:31 AM   #29
Dipstik-sportech
Dipstik-sportech's Avatar
Originally Posted by Synack View Post
Honestly I'll probably never go back to Precision.
Were your results on 9:1 compression?
9.5
Old 07-15-2014, 02:11 AM   #30
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
For what it's worth, I'm personally a huge fan of the gtx28 series as well.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 07-15-2014, 02:39 AM   #31
Andre da gr8
Drives: Asphalt '13 frs mt/ five axis
Originally Posted by Manji View Post
I'm not saying that high comp is bad. I'm saying too many people are looking at their turbo builds through NA-knowledge-tinted sunglasses.
nice saying
asphalt frs, 5 piece 5 axis, n1 ti, perrin cold
Coming soon: getting hard to decide!!
"im not that guy everyone wants to be!!, hold ma beer and ill kick his ass tho"
Andre da gr8 is offline   Reply With Quote
Old 07-15-2014, 11:29 AM   #32
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I'd run more than 9.0:1 as well, but it's not like it'll be a dog of he does.
Static compression is over emphasised on here when it comes to turbo builds.
Unfortunately the masses of enthusiasts understand static compression whereas dynamic compression isn't as well known, or as well understood.
That's about 15psi, are you serious? That's crazy.
Yea you'll see a lot of PSI the lower the comp for pump gas. Technically you could run more than that if you wanted, but you'd be going past 400whp. Since the GTX28 is a relatively small turbo, I wanna say boost will be there at 2900-3000 rpm. Most people think that low comp will be bad response, but the response is offset from the amount of boost pushed. To make it better I would reccomend a twin scroll manny if they have one for the 28
Old 07-15-2014, 11:31 AM   #33
Synack
Boosted
Synack's Avatar
Drives: Sideways
I mean that's crazy low! I've been running 20psi so far! Although I can't really tell but it might be on a conservative tune. I'd be very happy with 15psi.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 07-15-2014, 01:45 PM   #34
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I'm not sure about 15 psi though... @woode made 412 whp on 93 on stock CR (I think) with 21 psi
Old 07-15-2014, 01:51 PM   #35
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Trying to decide which turbo to go with to get 400whp with 93 gas and meth BUT with 9:1 compression.
Let's not make this a discussion about why my compression is so low!
400whp on 93 is my ultimate goal, but of course I want the best possible dyno curve and response. I'm upgrading from a Precision that has some lag to it.
I do not plan on getting any more power out of it so I could care less about room for upgrading. I'm also trying to do this without E85.
All I know is that my turbo creates a lot of heat at 20psi and I'm trying to get something more efficient. So I want a GTX series turbo.
You still remembering your drive of my car? Remember that was only a lowly GT2871R.
Old 07-15-2014, 01:52 PM   #36
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Sure did. Although, I think the OP's goals are quite a bit different. I wouldn't take my current setup to a track - I think heat would kill it.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 07-15-2014, 01:53 PM   #37
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I like to think of him as being an outlier.
Old 07-15-2014, 01:55 PM   #38
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
So 12.5:1 CR with 21 psi on 93 pump gas only made 412 whp...yeah you'll need more than 15 psi
Old 07-15-2014, 02:00 PM   #39
Synack
Boosted
Synack's Avatar
Drives: Sideways
Could be a conservative tune. I've seen people with about the same psi making over 500whp.
Old 07-15-2014, 02:00 PM   #40
Synack
Boosted
Synack's Avatar
Drives: Sideways
Andddd now it's time for a GTX2867R!
How much did you sell yours for again?
Old 07-15-2014, 02:05 PM   #41
King Tut
NASA SpecE30 Racer
King Tut's Avatar
$32.5k. My M3 is sold, and it is time to build another turbo 4 cylinder.
Old 07-15-2014, 02:06 PM   #42
woode
Boosted Member
woode's Avatar
Timing. Pump gas with that high of CR and that much boost needs more timing to be pulled to keep knock away, which results in more heat. A lower CR could surely run less boost and more timing and make similar numbers more safely even.
There are so many different approaches to tuning and engine building.. everything is a compromise.
Low compression? Venator Engine, Exhaust, Transmission 4 06-17-2014 10:37 AM
Why aren't some concerned about putting a turbo on a high compression motor? dave77 Forced Induction 50 01-13-2014 02:22 AM
Dynosty Tuned FR-S yields 355WHP with GTX28 Turbo and E85 Hal@Dynosty Forced Induction 14 12-21-2013 03:49 AM
Low Compression - 10:1 // 9:1 1086 Engine, Exhaust, Transmission 12 12-13-2013 05:46 PM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
