Old 07-09-2014, 11:04 PM   #169
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by coupeae86 View Post
Thanks for the reply although this does not answer my question. I plan on getting the cheapest supported(jvc smart music control) jvc head unit to connect with my tablet. And from what i understand in order to change sources on the head unit it's gotta be done through bluetooth.
So to rephrase my question: will I be able to switch sources on the radio from the jvc app on my tablet, and then switch back to the torque app on my tablet without having to switch the bluetooth sourcing in between?
Or can I switch sources on the head unit through the jvc app via the usb port?
Haven't tried it as my head unit doesn't support it. From my understanding torque likes a lot of bandwidth so it may not work. However there is a bit of a crack on the a/c vent that allows you to control the head unit via remote.
I would recommend the Sony head units though.
Installed Mods:
Old 07-09-2014, 11:40 PM   #170
coupeae86
Drives: 2013 FRS 1986 Corolla GTS
Thank you, well I already started ordering my parts. I will chime back in with my conclusion when my galaxy tab 3 and the elm327 module comes in.
coupeae86 is offline   Reply With Quote
Old 07-10-2014, 06:02 AM   #171
labskaus
labskaus's Avatar
Drives: Toyota GT86
Originally Posted by dz93 View Post
It utilizes apples Air Port Express (APE).
How do you controll Volume?
labskaus is offline   Reply With Quote
Old 07-10-2014, 11:05 AM   #172
dz93
Drives: toyota 86
because i have the audison bit 1 processor that has a volume knob on it so i can control volume from there (next to push start button). however volume can still be adjusted on the tablet so i have my tablet at about 85/90% and then control using my processor knob. could work vice versa
if i didnt have the processor control unit, simply just use the nexus. The rom installed on my tablet creates volume buttons along the bottom as you cant access the physical buttons.
dz93 is offline   Reply With Quote
Old 07-10-2014, 11:31 AM   #173
Sojhinn
Sojhinn's Avatar
As he said I never use the head unit for volume control. I just use the nexus. You set it once and forget it.
Installed Mods:
Old 07-15-2014, 04:23 AM   #174
bebopblues
5th Hairpiner
bebopblues's Avatar
Drives: 2015 FR-S RS 1.0
Does Timur's kernel allow nexus 7 to auto power-ON when power source is connected? The reason I ask is in case the nexus 7 battery is drained, it would suck to have to open the dash just to push the power button.
2015 FR-S RS 1.0
bebopblues is offline   Reply With Quote
Old 07-15-2014, 11:26 AM   #175
Sojhinn
Sojhinn's Avatar
I had my car sitting for 12 days and the battery in the nexus 7 was not drained. Do you have plans of having it sit longer?
Installed Mods:
Old 07-15-2014, 01:53 PM   #176
bebopblues
5th Hairpiner
bebopblues's Avatar
Only if I take off on vacation, then yes, possibly. But does the kernel support auto power-ON when it detects a power source?
2015 FR-S RS 1.0
Old 07-15-2014, 02:33 PM   #177
Sojhinn
Sojhinn's Avatar
I think the nexus will power on automatically from a complete drain with charge but never had it happen. At the 12 day mark my nexus still had 40% charge so it would be difficult toc completely drain it.
Installed Mods:
Old 07-21-2014, 11:03 PM   #178
coupeae86
Although, my current head unit is not supported with the jvc smart music control, I had no issues running music in the background to my head unit and torque on the tablets screen. Just an FYI for everyone
The Following User Says Thank You to coupeae86 For This Useful Post:
Sojhinn (07-21-2014)
Old 07-21-2014, 11:04 PM   #179
Sojhinn
Sojhinn's Avatar
Thanks for the heads up!
Installed Mods:
Old 10-11-2014, 03:14 AM   #180
choyr
choyr's Avatar
Drives: Toyota 86
what is the current best head unit now for the nexus 7 (2nd gen)? or is it better to get the old nexus 7 and still use the rom. i'm getting my car this week. thanks!
choyr is offline   Reply With Quote
Old 10-31-2014, 01:05 AM   #181
kgc
Drives: 2013 Subaru BRZ Limited AT
+1
Also, why is it even necessary to get a head unit? Can't the Nexus + DAC go directly to the speakers in the BRZ?
kgc is offline   Reply With Quote
Old 10-31-2014, 01:37 AM   #182
Sojhinn
Sojhinn's Avatar
Originally Posted by kgc View Post
+1
Doesn't work without an amp
Installed Mods:
Well that was easy... FRyeS Scion FR-S / Toyota 86 GT86 General Forum 17 10-15-2013 12:04 PM
Nexus 7 in FR-S/BRZ DjDATZ Electronics | Audio | NAV | Infotainment 4 06-09-2013 09:10 PM
Nexus 7 Car Audio DIY thejevans Electronics | Audio | NAV | Infotainment 32 05-10-2013 04:55 PM
How easy/difficult is it to keep WRB "clean"? ayau Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 32 06-17-2012 11:17 PM
