Old 07-14-2014, 11:58 AM   #57
paulca
Drives: Toyota GT86 Coupe Red (UK)
Originally Posted by Jyn View Post
I started lol'ing at my desk because of the mental image of me trying this on the street. I'd lurch so hard into the intersection that I'd probably just do the awkward Napoleon Dynamite runaway
Yep. Which is why I stay away from people who do this on hills.
paulca is offline   Reply With Quote
Old 07-14-2014, 12:05 PM   #58
paulca
Originally Posted by Phantobe View Post
I will literally practice this haha.
So the idea with Hills is to hit the friction point as soon as possible to prevent rollback, right? I've been getting better at Hills still just a bit of a nervous thing with the car behind me, trying to just forget about it.
At least at first put your hand on the hand brake for when it goes wrong?
Hint: You don't need to use the handbrake as "on/off", you can hold the button in and vary it.
Don't treat it as a weird thing manuals have or an emergency brake, it's a second brake that you use with your hand, perfectly fine to use it whenever it's appropriate like when your feet are busy. Obviously at speed or in corners for the lolz on private roads only! You can duct tape the button in
Old 07-14-2014, 12:06 PM   #59
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
On smaller hills, I've gotten better to where I can find the clutch engagement point with minimal rollback. On steeper hills, I engage the handbrake until I feel confident I've found the clutch engagement point. The only problem is that I usually chirp the tires and scare the person in front of me
Jyn is offline   Reply With Quote
The Following User Says Thank You to Jyn For This Useful Post:
Frishkorn (07-14-2014)
Old 07-14-2014, 12:10 PM   #60
Zelica
Zelica's Avatar
Drives: 10 Series Silver Ignition FR-S; M/T
When I'm in heavy traffic and steep hills, is it bad to have my regular break in still, while finding the friction point and THEN moving my right foot onto the gas?
Zelica is offline   Reply With Quote
Old 07-14-2014, 12:11 PM   #61
Jyn
Noob
Jyn's Avatar
No, that's actually what's being suggested here. It minimizes rollback.
litemup (07-17-2014)
Old 07-14-2014, 03:43 PM   #62
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Originally Posted by DarkSunrise View Post
Exactly. And bringing the clutch out to 0.5" before engagement point while still on the brakes minimizes your roll-back (removes the guesswork in finding the engagement point and reduces the time needed to reach it).
It takes a little practice, but this works for me.
I like the idea, do you do this on a regular basis? Or just situational like hills.
I feel like one of the problems with our clutches is that there isn't a whole lot of feel to them. To me the pressure feels fairly linear and its sometimes hard to define when I'm getting close to the friction point.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 07-14-2014, 04:25 PM   #63
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
For most mild to moderate hill starts, I just do a variation of heel-toeing. Instead of using the heel-toe to downshift, I'll use it to get on the gas while having the brake to hold myself in place until I can get the clutch to bite and set off.
It made for some pretty good practice for when I started using the heel-toe for what it's actually for.
Anything more than a moderate hill, I'll use the handbrake. Sure it might be a little bit slower and can be a little bit jerky if you rush things... but you won't roll back and it's by far the easiest method in my opinion.
Manic is offline   Reply With Quote
The Following 2 Users Say Thank You to Manic For This Useful Post:
litemup (07-17-2014), schmearcampain (07-15-2014)
Old 07-14-2014, 05:02 PM   #64
DarkSunrise
DarkSunrise's Avatar
Yep, I do some variation of it on a normal basis.
On hills, there's a split second of overlap between the clutch and brakes to make sure the car doesn't roll backwards. And I concentrate a bit more.
Once you have the engagement point down, starts in 1st gear are much easier. You can even bring the clutch to just prior to the engagement point, quickly rev to 3000+ RPM and engage the clutch for a faster start. This was useful at an autocross where the start was on a slight incline, for example. I would not do that on a regular basis though because of wear on the clutch and shock to the drivetrain.
2022 BRZ Build
2013 FR-S Build
Old 07-14-2014, 08:06 PM   #65
Ubersuber
Drives: BRZ Pearl White
Wow, a mind reader too.
Give this up.
Most of the posters here are North American and we drive differently.
You would too if you tried to drive over here.
At least I hope you would.
Remember the bumper sticker from California read:
Cover me while I change lanes
Wry sense of humour those Californians, my sister received a bullet hole in the side window when driving down the California freeway East of the Bay, fortunately it went through the rear side window.
Not sure you should worry too much about drivers who roll a little backwards when starting on hills. You should also know that the few people who actually drive a manual transmission car over here generally know what they're doing. People who roll back are pretty rare over here since they drive automatics.
Ubersuber is offline   Reply With Quote
Old 07-14-2014, 11:00 PM   #66
jonboy99
jonboy99's Avatar
Drives: Black Panda BRZ
Just to add my 2 cents as a long time (20 years) stick driver. This car is definitely not easy to be smooth with -dead clutch and DBW see to that. Even after nearly a year with it i'm not as smooth as I am after half an hour in most Fords etc.
And to those criticising using the handbrake to hill start - lol. If you DON'T use the handbrake for hill starts in the UK, you will fail your driving test. It's one of the main reasons it's there.
jonboy99 is offline   Reply With Quote
The Following User Says Thank You to jonboy99 For This Useful Post:
strat61caster (07-15-2014)
Old 07-15-2014, 02:15 AM   #67
schmearcampain
Drives: 2014 Argento FRS 6MT
What can help is instead of giving it gas and letting go of the clutch at the same time from idle (600rpm), is blipping the gas pedal just a bit before hand to bring the revs up to about 1500 and then going from there.
Edit: Some more thoughts.
This car can actually start in first without giving it any gas at all on level ground. So think more about releasing the clutch cleanly than how much gas to give it. Just a little will work.
Personally, I don't find this car particularly hard to drive. It's certainly not harder than older manuals that only had 100 HP or less that would stall really easily.
schmearcampain is offline   Reply With Quote
The Following 2 Users Say Thank You to schmearcampain For This Useful Post:
#maverick# (07-15-2014), Ubersuber (07-15-2014)
Old 07-15-2014, 02:34 AM   #68
paulca
Give this up.
I meant over here. If you come up a hill to a set of red traffic lights or a junction and a stationary car in front has it's brake lights on, then they are most likely sitting on the foot brake and will need to transfer to clutch/throttle. If they don't have brake lights on, they are either clutch holding (most likely) or have the handbrake on.
Old 07-15-2014, 03:15 AM   #69
litemup
Drives: around
Haha it sounds much harder when I try to explain it in writing.
Quite the opposite. I was struggling with how to explain the technique and you nailed it. OP, practice how D-S explained this. Practice maintaining a constant engine speed around 2K RPM by increasing the throttle while letting the clutch bite harder. That's the sweet spot. Work the opposite direction too. When you're in the sweet spot, disengage the clutch a little while releasing the throttle.
Be careful not to overheat the clutch. The idea is to use as little power as possible to get the car rolling until the clutch is fully engaged.
litemup is offline   Reply With Quote
The Following 2 Users Say Thank You to litemup For This Useful Post:
DarkSunrise (07-15-2014), Ubersuber (07-15-2014)
Old 07-15-2014, 03:21 AM   #70
paulca
It will roll without throttle, but it's a very fine line (on the UK model). In mine I really have to wait until the ECU kicks in to lift the revs or it will stall. Of course the first drive of the day while it's still on the auto choke it works great.
My old french Clio could work it's way all the way up to 20mph in 5th without touching the throttle and would hold on clutch only on slight hills at 700rpm.
This made the first week or two with the GT a bit of a bitch as I used clutch drag only a lot for maneuvering in my last car and my GT just doesn't have the idle pull for it and needs you to "crack" the throttle open a hair.
It really just depends on the ECU of the car and how much it wants to aid the driver regards stalling etc.
how many rpms do you rev at starting off first gear? 2isballer Scion FR-S / Toyota 86 GT86 General Forum 84 08-03-2015 06:40 PM
Starting in 2nd Gear? Manic Scion FR-S / Toyota 86 GT86 General Forum 61 11-03-2013 03:55 PM
starting in second gear cantaloupe BRZ First-Gen (2012+) — General Topics 38 03-11-2013 07:18 PM
Another way of starting from 1st gear..help tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 32 09-24-2012 01:14 AM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 02:21 PM
