Old 07-15-2014, 12:02 AM   #85
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
5.08 boost @2100 rpm.
http://datazap.me/u/robwbright/71414...zoom=8346-8392
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 07-15-2014, 01:58 AM   #86
DAEMANO
Time Traveller
Originally Posted by robwbright View Post
Old 07-15-2014, 10:27 AM   #87
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Damn.
Installed Mods:
Old 07-15-2014, 10:45 AM   #88
robwbright
Originally Posted by Sojhinn View Post
Damn.
I think it was a fluke sort of thing. If you look at the straight pulls, it's always in the 4.6-4.79 range. I happened to glance at the tablet right when I gassed it and let off in a 35 mph area and thought saw a 5 in the left column under boost. Then I found it in the chart. It doesn't appear that I ever get above 4.79 in a straight pull. But still...
By your silence, you guys apparently think I'm ok with flashing the ROM with the ignition on, then? I'm no expert at reading these charts, but the AFRs look pretty similar to others I've seen... so it seems to me like the tune is working properly.
Now, should I flash to the new beta ROM or just stick with this one?
2006 Saab 9-3 2.0t
Old 07-15-2014, 10:49 AM   #89
robwbright
Correction... here's a 4.94 at 2200 rpm - so it appears I do get over 4.79 more than once - but not in a straight pull.
http://datazap.me/u/robwbright/71414...zoom=8252-8283
2006 Saab 9-3 2.0t
Old 07-15-2014, 10:54 AM   #90
robwbright
2.03 @ 6782 and 3.05 @ 6022.
http://datazap.me/u/robwbright/71414...zoom=4602-4722
2006 Saab 9-3 2.0t
Old 07-15-2014, 11:27 AM   #91
raven1231
If everything looks good and it says youre running the tune on the oft, then I wpuldnt worry about it
Old 07-15-2014, 11:32 AM   #92
fenton
Hey Rob i would suggest not going WOT that low. Your car is freaking out and setting the engine load to 5(max) and also setting ignition timing to 0.
Is this on the new tune?
fenton is offline   Reply With Quote
Old 07-15-2014, 02:06 PM   #93
robwbright
The first tune in this thread. I didn't go with the new beta yet.
I don't normally go WOT at 2000 rpm (especially not in 3rd or 4th), but thought I'd try it on that run (partly because of the "turbo" lag). I'll avoid that in the future. The 5.08 boost was in second gear.
2006 Saab 9-3 2.0t
Old 07-15-2014, 02:09 PM   #94
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Pretty sure the oft does not tell you which tune its running once its on the ecu
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 07-15-2014, 02:11 PM   #95
robwbright
Originally Posted by Boofneenee View Post
Pretty sure the off does not tell you which tune its running once its on the ecu
Yes it does.
2006 Saab 9-3 2.0t
Old 07-15-2014, 02:13 PM   #96
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Why is it bad to go WOT at 2k?
FRS
Old 07-15-2014, 02:53 PM   #97
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Yes it does.
Where?
Once I tried to flash a new tune on my car and must have accidently flashed the stock tune. I new something was not right so I flashed again and noticed a huge difference. I called the guys at open flash so I could find out which tune I had on the ecu and they told me the only way was to open the Roms and compare tables. Maybe updates changed that?
FRS
Old 07-15-2014, 03:12 PM   #98
robwbright
Where?
I don't have it in hooked up and in front of me, but if I recall how I found it, there's a selection titled "Info" that you can push which shows which ROM is installed in the car. Has to be hooked up to the car.
2006 Saab 9-3 2.0t
Phantom TQ250 Dyno FBO (Dual Battery Pack) Shiv@Openflash Forced Induction 23 04-29-2014 01:40 AM
Clutch dump at 5000 RPM? fasteddy BRZ First-Gen (2012+) — General Topics 20 08-22-2013 12:55 PM
External dump and under tray? mrk1 Forced Induction 5 07-30-2013 08:43 AM
Photo dump. CanibeatNoel FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 07-17-2013 01:47 AM
Ricepuddin Picture Dump Ricepuddin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 12-02-2012 11:18 PM
