Best Slicks / Race Tires for the Money
Hey guys,
I'm currently running Dunlop's Direzza Z2 on a stock set-up, and looking to take it to the next level at the track. What's the consensus on the best value for money track-only tires? I'm currently looking into Hoosier A6, R6, and NT-01. Also, is the 17 inch rim the smallest rim we can fit on the car? I'm trying to go with the smallest rim for the track to minimize rotating mass as well as tire cost. Assuming 245 is the widest that will fit without rubbing (stock alignment/ride height)? Thanks all.
#2 |
Drives: 2013 FRS / 2013 427 Vert
Khumo 710's or Hankook Z214's are very similar to R6's at 60% of the cost.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#3 | |
Long tire life? Fastest single lap time? Budget? Also, stock alignment with these tires will not be a good thing. - Andy |
#4 |
Drives: Used to Drive:Grand-Am GS #54 E36M3
Add BFGoodrich R1s in 235/40-17 to your list. Or in 245/40-17 if you want 3/10" wider tread. Excellent pricing and service can be found at Phil's Tire Service in Cragsmoor, NY: http://www.philstireservice.com/. Phil has the concession for all of the NASA Northeast and NASA Mid-Atlantic events.
#5 | |
Will you be driving on them to the track? How much are you willing to spend? |
#6 | ||
Drives: 2022 BRZ Limited
I prefer Nitto NT01 for now since it's widely available, cheap, last longer, you can drive them on the street or to track, and people on rennlist forums and a few other forums also seem to like them ..they even run them to the cords.. you can even flip them on the same wheel and run inside and out (not in the rain of course since you change the tread directions) For the record I had some minor rubbing with stock suspension and ride height and that was with 235/40/17s, you will definitely rub them if there are some serious elevation changes at the track you use them.. Quote:
People seem to like the Z214s, I heard nothing but good things about them and it's similarly priced with NT01s ( costs about $25-30 more than NT01s)..Did you get a chance to compare Z214s to NT01s? Are those light years ahead of the NT01s? heat cycled out quickly? Also, not really popular but Ventus TD Z221 also looks like another nice option but I don't think it's widely available in the U.S as of now.. in a recent test it showed some serious gains against to NT01s http://ventustd.com/technicaldata.php the guy who ran the test was on the renntrack forums see his impressions http://www.renntrack.com/forums/show...4559#post24559
#7 |
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
I know people in the time trial community that like the Maxxis RC-1. I plan on giving them a go next season.
http://www.maxxis.com/catalog/tire-450-107-victra-rc-1
![]() Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication STX Build thread 14th/67 SCCA Nationals (2014) |
| The Following User Says Thank You to SubiePig For This Useful Post: | glamcem (07-15-2014) |
#8 |
I'll group the tires by category (no particular order within a category)
"R-comp" 100TW Toyo R888 Toyo RA1 Nitto NT01 Maxxis RC1 "R-Comp" 80TW Hankook TD "R-Comp" 60TW Toyo RR "Slick" 40TW or lower Hoosier A6 Hoosier R6 Kumho V710 BFG R1 BFG R1S |
| The Following User Says Thank You to CSG Mike For This Useful Post: | glamcem (07-15-2014) |
#9 | |
also heard about these too, it seems like they come in both Soft and medium compound http://www.federaltire.com/en/produc...ts_detail_sn=3
#10 | |
| The Following User Says Thank You to CSG David For This Useful Post: | glamcem (07-15-2014) |
#11 |
How would you compare them against the NT01s or R888s?
#12 |
NT01 requires a little warm up time, but grip is comparable. NT01 strives better in hot situations, RC-1 is better for cooler situations. Either way, you shouldn't be overheating either tire. If you are, you are over-driving the car.
R888 are not as consistent as the NT01 or RC1. |
#13 | |
if you saw the comparison between the Hankook TD and NT01s that I posted above, TD might be another good alternative ..since I do care about the tread when I drive to closer tracks within 100 mile radius. too bad there are not so many places offer the Ventus TDs and I don't hear as much feedback except that test
#14 | |
![]() We do our best to post positive results and suggestions based on our findings, experiences, testings, and data.
| How to warranty your stock tires and save money on Pilot Super Sports | SpeedR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 81 | 03-31-2016 10:48 PM |
| Slicks upgraded axles 1/4 mile? | Fabron757 | Forced Induction | 13 | 06-29-2014 07:25 PM |
| Track-only Race Compound Tires recommendations & Q's. On stock wheels. | fooddude | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 03-27-2014 12:47 AM |
| Auto-x, slicks & tire temps | mtimney | Tracking / Autocross / HPDE / Drifting | 6 | 10-19-2013 10:30 PM |
| Choice of slicks for HPDE | CB762 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-02-2012 10:25 PM |
